2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes EDC Delete question
      02-15-2015, 08:02 PM   #1
jbeemer13
252
Drives: 2012 BMW 535i, 2018 BMW M3 CP
2018 BMW M3  [0.00]
EDC Delete question
A few question for those of you that are running KW coilovers with the EDC delete module.
1. Does is completely disable the EDC control inside the car?
Reason I am asking is that EDC control has several settings, most of them suspension related. However there are 2 which are not completely just suspension related. Sprots + which I use a lot and ECO. I'm considering going the coilover route but did not want to lose those functions. Seems like my car is fastest when i have it in sports mode, manual, with sports + activated using the EDC module.
2. Instead of using the edc delete, can you have it coded to remove any errors thrown. Is this a better option?
Any info on this will be appreciated. Thanks!
      02-16-2015, 10:41 AM   #2
remmib
remmib's Avatar
Norway
1569
Drives: 2013 F10 520d M-Sport
I don't have EDC, but I'd assume the EDC delete module only eliminate the error codes, and not the actual functions of the EDC buttons in the car.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      02-16-2015, 08:03 PM   #3
jbeemer13
252
2018 BMW M3  [0.00]
Thanks for the feedback remmib! Thats what I was hoping for.
Can any other member that is running the KW coilovers with EDC delete confirm this?
      02-16-2015, 08:13 PM   #4
lsturbointeg
lsturbointeg's Avatar
9161
Drives: 2011 535i Jet Black
I inquired about the KW V1's and they said I needed the EDC module even tho I don't. Have EDC to eliminate the error codes that will pop up.
      02-17-2015, 12:30 AM   #5
laissez_Faire
laissez_Faire's Avatar
Drives: 2014 550i M-sport
Its my main concern as well. Sport and sport plus mode does give better throttle response as compared to comfort mode with traction off and and manual/sport shifting.
I highly doubt the functions are retained because I believe the EDC control is disconnected when the shocks are replaced.
      02-17-2015, 01:11 AM   #6
zugellos
91
Drives: 535i M-Sport
Back about 6-7 months ago when I was contemplating getting these same coilovers, a rep from KW said I wouldn't be able to run these at all.
That's why I had to opt for the H&Rs.
      02-17-2015, 10:52 AM   #7
remmib
remmib's Avatar
Norway
1569
Weird, did he say why?
      02-17-2015, 12:22 PM   #8
jbeemer13
252
2018 BMW M3  [0.00]
Weird you need the module even though you dont have EDC.
Yeah its a feature I dont want to give up. I dont want to lose the added throttle response. Might have to stick to my H&R setup that I currently have on my car. Just wish it was just a little bit lower!
Thanks for the feedback. I currently have H&Rs and it looks like I might have to stick with it. Wish they offered a sleeve kit that utilized the stock shocks.
      02-17-2015, 01:21 PM   #9
remmib
remmib's Avatar
Norway
1569
You don't. I don't have EDC and I've got KWv3 without the module.
      02-17-2015, 02:33 PM   #10
lsturbointeg
9161
Good to know as I will be ordering a set soon!
      03-12-2015, 12:16 AM   #11
jbeemer13
252
2018 BMW M3  [0.00]
Just a quick update on this thread. I ended up installing the KWv2s with the EDC delete module.
I am happy to report that the edc control in the car is still fully functional and I am still able to switch between all the modes with no issue. The sports + and ECO mode still are functional for the drive trian and traction control options . The only thing that obviously will not work is the Electronic dampening.
      03-13-2015, 08:28 PM   #12
lsturbointeg
9161
Good news !
      03-13-2015, 10:38 PM   #13
AZ_Bmw_550
52
Drives: 2015 BMW 650i GC
2011 BMW 550i  [0.00]
How does the ride compare to before? Played with the settings on the KW yet?
5post
