Engine shuts down after stumbling RPM
02-15-2015, 05:19 PM | #1 |
19
Rep 317
So the the first time that my car engine turned off by itself was when I was reversing out of my drive way (about 8 months ago). Today, I was on my way home from the store, after turning on the car, the RPM stumbled, goes to zero, and the engine shuts off. I turned it back on and it was fine. The car starts up normal when it's cold, but when it's already warmed up, the RPM stumbles.
I just pulled some codes off it just now. P0174 P0171 P0001 (this is new to me) P0003 (this is new to me) C0300 (this is new to me) P0306 (this always come back when I clear the code) P0303 (this always come back when I clear the code) I'm not sure why there's misfire, but I had all my spark plugs changed 15k miles ago, and all my ignition coils 5k miles ago. Has this happened to anyone? |
03-02-2015, 08:39 AM | #4 |
Rep 12
Check if all your valve cover bolts are there they tend to brake. Look lower down into the motor to see if u have leaks. I just did my gasket yesterday took 3ish hours but now I'm back and running better than ever if there's a leak it might fix your problem then again if ur leaking oil u should replace your gasket anyways
03-02-2015, 01:02 PM | #5 | |
Rep 18
03-03-2015, 02:13 AM | #6 |
299
Rep 2,015
I had the same thing happen to me in reverse also, about an year ago.
Now I had changed my plugs and coils also and had a walnut blast fine about 14k ago. And yes I had a miss fire code on one cyln only. So instead of changing out injectors, tried something cheap .....and 1 year later still no issues. Not saying my problem is like your problem but worth it if it works. Try fuel injector cleaners. And if youv have not got a walnut blast yet, get it done. Fuel injectors of choice on this forum are: 1 - techron concentrate ( not the one from costco) 2 - BG44k I ran 2 cans in 2 tanks back to back, one after the other. Then using USB to obdii cable and bmwloger - reset all adaptations. DN |
