Misfire only during WOT pulls?
02-12-2015, 08:24 PM | #1 |
15
Rep 68
Ok guys, I installed the JB4, and almost like clockwork, I killed the #5 ignition coil. No biggie, swapped, and we were off again. Now I have a curious problem. I get a #3 cyl misfire code, but only if I go WOT. The car throws a code, and JB$ does its job and reverts to map 4. Is this common to only get the misfire under WOT? The car is perfectly fine under normal driving conditions, and if I ease into the throttle, I can get into 120ish MPH without the misfire code being thrown. But the second I try to floor it from rolling, I get the code. So, whats up? Maybe a spark plug, or am I replacing another coil?
2013 F350 37 inch tires, and go fast parts
2008 335i JB4, FBO (Powered by Hopes and Dreams) [SOLD] 2002 F-250 40" tires, and other goodies (toy) [SOLD] USAF, Support the Troops |
02-12-2015, 08:44 PM | #3 |
15
Rep 68
I don't have replacements, but I can acquire a few!
Quick Questions: Wheres a good place to pick up that BMW spark plug socket locally? I'd like to put hands on it, rather than wait on shipping and silliness...
02-12-2015, 08:50 PM | #5 |
15
Rep 68
I want to grab it locally. Like at an autozone, or somewhere similar. I want to do this project this weekend, and shipping isn't gonna put that in my hand come Saturday afternoon...
02-12-2015, 08:50 PM | #6 |
202
Rep 449
The more cylinder pressure there is (higher boost) the harder it is to jump the gap on a spark plug. This is most likely when a coil will misfire. I had this happen twice and had to replace two different coils as they were originals. When the misfire happened it would continue to misfire until I shut the car off and restarted. After the restart the car would run perfect under low load. Never did understand why the coil would continue to misfire once the load was removed however.
335i FBO,Meth,JB4,Sutphin flash,LSD,GCLites 11.25@127.4 on NT05R
335xi FBO,Meth,JB4,Sutphin flash,VTT stage1 11.38 1/4 - 7.30 1/8th - 3.35 0 to 60 @ 0C |
02-12-2015, 08:53 PM | #7 |
need4speed
510
Rep 1,903
No idea where you can buy it locally. If you do find one local make sure it's magnetized so that the spark plug doesn't fall out of the socket. Good luck
02-12-2015, 09:01 PM | #8 | |
15
Rep 68
02-12-2015, 09:08 PM | #9 |
15
Rep 68
Went ahead and ordered the tool, and it'll be here next week, while I'm leave. Now to do a search on exactly which spark plugs these things take. It's been three years since I drove something with spark plugs...
02-12-2015, 09:42 PM | #10 |
69
Rep 404
02-12-2015, 10:16 PM | #11 |
318
Rep 516
You can buy the coils and vanos solenoids (sometimes issue if misfire code with vanos code) at autozone and they are covered under lifetime warranty. I am fitting 21psi high rpm misfires and already replaced all could and plugs and checked injectors. May be cam bearing ledge in my case.
02-12-2015, 10:20 PM | #12 |
100
Rep 1,040
It's 100% spark plugs. Coils are bad from start and spark plugs are bad under WOT usually. I couldn't find a place locally to buy the tool, but the BMS one came in like two days. I don't think the dealer sells them, Sears doesn't stock them in store, just online...
02-13-2015, 06:41 AM | #13 | |
141
Rep 989
Here is a set from ECS. http://www.ecstuning.com/BMW-E90-335...3.0L/ES257800/ I love their website because they have everything very organized and its very easy to find. |
02-13-2015, 09:01 AM | #14 | |
202
Rep 449
02-13-2015, 09:57 AM | #15 |
16
Rep 185
i have been chasing a #6 misfire. didn't matter what i swapped around still misfire in #6. I found that i was over boosting post shift which causes timing and fuel to cut off. without seeing a log i can't say this is whats going on, but might be something to look into. I had to adjust my "autoshift boost reduction" setting from 60 (default) to 80. Also check your boost fail safe setting to be sure your not going over that set point...
2008 335i MHD e40 Flash,VRSF FBO,255 Walbro,Alpina Flash
11.993@119mph |
02-13-2015, 09:59 AM | #16 | |
3441
Rep 79,211
You can buy OEM Bosch plugs or aftermarket NGK which most of us vendors sell. The NGK need to be manually gapped. Otherwise OEM/BMW Bosch plugs are perfectly fine. It's typical for these misfires to happen at WOT. This sounds like an interesting story, how did you get around for the past 3 years before this vehicle? |
02-13-2015, 10:37 AM | #17 |
30
Rep 780
i started to get misfires once i went to e50..... knew it was coil right away swapped one out then another started to misfire. Swapped that one as well and then another one misfired ended up just relpacing all of them no misfire since
02-13-2015, 11:50 AM | #18 | |
141
Rep 989
02-13-2015, 06:16 PM | #19 | |
15
Rep 68
This is my previous Daily Driver. Needless to say, getting a 335i is a drastic swing for me. 8 MPG just wasn't cutting it for my daily commute...
02-13-2015, 06:17 PM | #20 | |
15
Rep 68
02-13-2015, 06:19 PM | #21 |
15
Rep 68
Originally, when the coil went bad for me, it threw a specific code related to the coil pack. This one is only for a misfire, not specific to the coil pack. Thus why I am after a spark plug theory.
02-13-2015, 06:20 PM | #22 |
15
Rep 68
