02-11-2015, 01:51 PM | #1 |
45
Rep 202
Brakes, and what to do if you mistakenly use them
I had the impression I could get one track weekend out of the brakes without trouble but I seem to have been mistaken and now my car has a really wicked vibration under braking at all speeds but especially slow although I am finding new rattles. Obviously the dealer will have nothing to do with the car while the tires look feathered.
The rotors are clearly not warped, but they are not true either. Stoptech has an interesting article at http://www.stoptech.com/technical-su...nd-other-myths that says you can either true them or try to grind them with garnet paper. Has anybody had luck with sanding them? I tried last night with the wheels off but rotors attached for about 15min per rotor and while its better, its not great although I still have the stock pads on the car waiting for some rs29's to show up. |
02-11-2015, 02:09 PM | #2 |
Go Spurs Go
3885
Rep 2,872
Not sure if the M rotors can be resurfaced on a lathe by any machine shop with one. As long as it is within minimum thickness you can have most brake shops perform this for about $20 per side. Just be sure to sand down the pads before install in case there are foreign materials imbedded in them that can score the surface of the rotors you just had redone.
02-11-2015, 02:22 PM | #3 |
21115
Rep 20,741
Drives: 2021 911 turbo
Just run them on the street normally, the shudder should eventually go away.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
02-12-2015, 09:53 AM | #4 |
531
Rep 1,152
This is not a problem with your rotors but rather uneven deposition of brake pad material, especially common if you ran with the OEM brake pads. Go out and (safely) do some high speed decelerations from say 60 mph down to 5 mph. Really hammer on the brakes but do NOT allow the ABS to kick in. A couple of stops like this should even up things again.
02-12-2015, 11:55 AM | #5 | |
45
Rep 202
02-12-2015, 02:44 PM | #6 |
3187
Rep 10,509
02-12-2015, 03:09 PM | #7 |
1231
Rep 1,789
Drives: wife crazy
Garage List 2019 Ford Raptor [0.00]
2016 Porsche 991.1 ... [0.00] 1987 Chevy Camaro I ... [0.00] 1972 Chevy Corvette [0.00] 1999 BMW M3 race car [0.00] |
x2, I don't understand why dealer would care what the tires look like?
When you get those RS29's in, they'll scrape those deposits right off.
Road course laptimes for BMW M4 2015 6MT
WHP East Track: 1:04.880, Arizona Motorsports Park: 1:54.352 Road course laptimes for Porsche 911 991.1 GTS 7MT WHP East Track: 1:02.770, Arizona Motorsports Park: 1:48.889 |
02-12-2015, 03:34 PM | #8 | |
Sunburnt Member
158
Rep 525
2019 Deep Blue Tesla Model 3 Performance | 2015 Mineral White F82 M4 | 2010 Burnt Orange Lotus Exige S2
Past: 2009 Ibis White S5 (APR Supercharged V8) Past: 2004 Imola Red M3 Convertible |
02-12-2015, 04:19 PM | #9 |
45
Rep 202
Southbay BMW (LA) is considering the car to be driven past what is reasonable for an M car. The initial suggestion was new pads and rotors all around on my tab, something in the 2 grand area.
I recently joined BMW land from Porscheville and the GT3 was just more up to the task from the beginning although even it required RS29's and rotors after multiple days. I have some new pads and tires coming for next weekend though, the rest of this chassis is amazing but those two points really hurt the car. |
02-12-2015, 05:32 PM | #10 |
531
Rep 1,152
Find a new dealership to service your car. These guys are idiots. I fear that the whole of BMW is moving quickly away from the whole essence of what an 'M' meant; from the designers, engineers, sales and service. Very depressing.
Bish |
02-12-2015, 08:31 PM | #11 | |
1231
Rep 1,789
Drives: wife crazy
FWIW the brakes on the M4 were giving me some grief at the track initially, but I've finally got them sorted. My advanced instructor drove it on the track this past weekend and said the brakes were "amazing". My brake setup is: SRF fluid SS brake lines Carbotech XP12 front / XP10 rear
02-13-2015, 12:25 AM | #12 |
721
Rep 2,342
OP. Get a Rotor Hone.
I grabbed three In Course, Medium, and Fine. They're about $30 each. You may only need Coarse and Medium. They'll knock those deposits off. Then take the pads off and Scuff them up with some 220 Sand paper. I had this happen on my GTR, and this is the best fix if you can't replace your hardware. Also happened on my F80, but I have bad ass tech and SA at my dealership that got me all new pads and rotors all around. |
02-13-2015, 02:38 AM | #13 | |
45
Rep 202
I will deal with the dealership issue later.. In Houston, Porsche of North Houston had no trouble what so ever with the fact that I damaged a differential while I was at the track or the fact that the car came in for service with Hoosiers every time. I even took their loaner cayman to the track while the GT3 was in the shop with no complaints afterwards. Any recommendations around Los Angeles? |
02-13-2015, 02:44 AM | #14 | |
45
Rep 202
02-19-2015, 11:59 PM | #15 | |
45
Rep 202
All is well again |
02-20-2015, 04:23 AM | #16 |
21115
Rep 20,741
As I posted in post #3, the pad deposit would have eventually scrubbed off with normal street driving. It just takes longer (a few weeks) with street pads. The abrasive Pagids accelerated the process .
02-20-2015, 10:27 AM | #17 | |
875
Rep 3,450
just throw some more aggressive semi-metallic track pads on there (the RS29's will work) and that should take care of it. I did the same thing after my first track day in my e92 at Road America. felt like the car was limping home with the brake shudder, but totally worth it. |
02-20-2015, 12:08 PM | #18 |
136
Rep 504
Regarding your dealer: The first time this happened to me (and I thought the rotors were warped). I just dropped it off with a dumb "I dunno - there's a weird vibration on braking".
The dealer immediately called me and said "Were you tracking this thing?" before I could answer he said, "we know you did - we can tell by the tires". So I admitted I did (heck I thought he could tell because I removed the numbers and didn't wash the car - totally visible on the doors). Anyway, I thought they were going to tell me to shove it. He said "No worries - we just wanted to ensure that was what happened. Brakes are covered though, the rotors are warped and we're putting on new ones". When I picked it up they totally said something to the effect of, "it's an M car, should be able to do that". And they also replaced them twice more at BMW's expense. Same thing. So, 1: your dealer sucks. "Driven beyond what is reasonable for an M car" is basically in direct contradiction to all of the marketing materials and what the salesman eagerly tells you when you're buying it, "This thing is basically a race car!" 2: I also agree with the rest of the thread here, in that my dealer was wrong, and it is just pad deposits, and they do go back smooth after some time. Happened to me after the car went out of the warranty/maint period and eventually it went back to normal. |
02-24-2015, 08:30 AM | #19 |
1570
Rep 8,075
Drives: 11 E90 M3 Individual
Stop crying about the dealer...hose down your wheels and rotors with water in the evening and then let the surface rust up a little. Drive it. Fixed.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
