2AA4 and 3100 codes weird
02-09-2015, 11:13 PM | #1 |
44
Rep 359
I'm having a little problem with my car and hoping you guys can help me out if it's something that you guys heard before.
So I started getting inlet vanos codes ( 2a98 2a7a 2a7c ), replaced the solenoids and it didn't do anything so I went ahead and got the cam ledges changed out. Everything was set with the timing tools and everything looked good. Now I'm having some trouble withe the 2aa4 code popping out and causing a limp mode but the engine runs smooth no rough idle no nothing just limp mode with no boost obviously. The thing is it's really confusing. The engine light comes on after 20 seconds of starting the car, if you start driving right before that the boost is there and everything is fine. Once the rpms drop to the normal idle value ( 600rpm ish ) let's say when you come to a stop light, the light comes on. I cleaned the inlet sensor and the connector and the impulse sensor too without any improvement, removed the jb4 completely to make sure it's not the harness but nothing. Can't figure out what does that 2AA4 code mean, the description says it's inlet camshaft sensor tooth failure... What tooth ? |
02-11-2015, 11:07 AM | #3 |
rallyroad.net
23
Rep 113
Did you ever resolve your previous problems?
I too had a "low oil pressure" warning once last week after letting the car sit for a week. Haven't had that low oil pressure warning since. Now that I have my JB4 installed with a pump gas backend flash, I'm getting the 2A7C and 3100 codes...along with a 29D2 - Misfire, cylinder 6. I'd rather not spend the money on new Vanos solenoids if that's not going to solve the issue. |
02-14-2015, 10:52 PM | #4 | |
44
Rep 359
In your case .. Do u have any oil leaks that show up under the car or anywhere that u noticed ? Did your serpentine belt break at some point ? |
02-15-2015, 12:58 AM | #5 | |
rallyroad.net
23
Rep 113
How the heck does a serpentine belt get inside the oil pan? I've never heard of such a thing. ....Did some reading on this and it sounds like a broken belt will wrap around the crankshaft and push the front seal into the motor and it gets shredded in the process. The N54 is the only engine I've ever heard of this happening to, but it seems that its somewhat common. Last edited by EMC; 02-15-2015 at 01:13 AM.. |
02-15-2015, 06:52 PM | #6 | |
rallyroad.net
23
Rep 113
At first he said he thought the car might have gotten a new serpentine belt. A few minutes later, he said the old belt had broken and was replaced. There's definitely more to the story. My car hasn't had a single code thrown since I got my JB4 and backend flash sorted, but the low oil pressure warning comes on for a few seconds about every other morning when cold starting in this nasty cold weather. I swapped the oil pressure sensor on the filter housing and also checked the small o-ring on the oil filter cap. No issues there. I'm starting to think that dropping the oil pan to check for debris in the pickup is in the near future. I'll be changing the oil and filter tomorrow since I don't believe it was changed after the serpentine belt "broke" on the previous owner. Other than this low oil pressure warning on cold start, the car runs flawlessly. |
02-15-2015, 07:05 PM | #7 |
Stupid Idiot
134
Rep 827
While I haven't personally come across that 2AA4 fault, it most definitely has something to do with the intake cam -- either the sensor gear wasn't aligned properly, or it was damaged. Did the shop have the tool to properly align the sensor gears?
02-15-2015, 07:40 PM | #8 |
44
Rep 359
Yes. I actually stopped by that same day and saw that the guy had the tool there, if he used it on the readings plates .. I don't know that. But I'm really thinking that it's the only thing left to do.
02-15-2015, 07:46 PM | #9 | |
44
Rep 359
The first time my belt broke, nothing happened I bought a new belt .. I removed the crankshaft pulley just to make sure nothing got in there and it was all good, next thing you know 3 months later it's leaking from there slowly and the oil pressure light is on every cold start. And sure enough a couple weeks after it broke again and the result wasn't pretty. 3600$ later the pan is clean and everything is back in order but this damn 2AA4 is making my life a living hell. |
02-17-2015, 02:23 PM | #10 | |
rallyroad.net
23
Rep 113
No low oil pressure light this morning. Keeping my fingers crossed, but will likely still pull the pan and remove the pickup for inspection about a month from now. That may be an excuse to install a set of AR Design downpipes...while everything is easy to get to. |
02-17-2015, 08:48 PM | #11 |
Stupid Idiot
134
Rep 827
There's a tool to pin the crank at TDC, there's a tool to block the cams in the proper location, and there's a plate to align the sensor wheels before you crank down the central vanos bolts. If he used all these tools, then maybe something got damaged. Lots of possibilities, really.
08-04-2016, 05:19 PM | #13 |
Rep 2
Did you locate/solve the problem (2aa4) 335 e90 n54
Hi! Thanks for sharing your issues with your car, it is so frustrating when you spend thousands $$$$ at the dealership only to still have the same problem. I was pretty bummed when I got to the end of the thread and there wasn't a follow up re: how/if you solved the issue. Did you give up and get rid of the car? I'm experiencing the same issues!!
2007 335xi e90 n54 100,000 miles REPLACED: 2 solenoids, 2 check valves, 2 camshaft sensors. *dealership then replaced camshaft bearing ledge and vanos unit. Cost ~ $2k it didn't fix the issue and it's throwing code 2aa4. symptoms: engine stalling, rough idle, limp mode. Any ideas? Thank you!!! |
