My 335 caught on fire while drifting!
02-09-2015, 01:40 AM | #1 |
104
Rep 1,059
Hey guys, so I was drifting with some friends on a plaza and my friend noticed that my car was on fire, I got out and saw flames that were coming from what looked like underneath the turbos. My car has aftermarket downpipes. I got super scared and we started throwing snow on it and put it out pretty quickly. I turned it off and let it sit and cool down, then I started it up and everything is fine, no check engine light, no leaks, nothing... My question is what could it be? The oxygen sensor wires are totally fine and all the little rubber tube protectors are fine too... Any idea what it could have been? I think that the gasket after the downpipes is busted and the car got pretty hot maybe some flames seeped through and caught the plastic under tray on fire? I also saw a bunch of oil residue near the downpipes..
Also, drove home another 30 mins and no problems. I feel like if something serious caught fire, or some fluid, we wouldn't be able to put it out with just snow. I didnt use much brakes either, so they couldn't overheat.. Last edited by SM335i; 02-09-2015 at 01:50 AM.. |
02-09-2015, 01:50 AM | #2 |
233
Rep 738
Drives: '11 328xi |'18 440xi GranCoupe
Wow, scary stuff. Glad everyone's okay!
02-09-2015, 01:56 AM | #3 |
Where'd my VTEC go?
481
Rep 6,067
Get it on a lift and see where the damage is.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
02-09-2015, 04:30 AM | #5 |
30
Rep 209
My 2008 e90 335i caught fire leaving my driveway just over a year ago. I couldn't put it out in time so it was written off. But the fire seemed to have started in the same area of the engine bay you're describing. Damage was too extreme on mine to tell where exactly it started but I now carry a fire extinguisher in the trunk of my 2007 e92 335i
02-09-2015, 06:50 AM | #6 |
4542
Rep 11,903
You were super lucky dude ... go buy a lottery ticket
02-09-2015, 07:12 AM | #7 |
127
Rep 865
Drives: BMW X3 35i, Porsche Macan S
Are you using meth?
MOTIV 750 ST | MOTIV PI | 100% E85 | Fuel-it Stage 4 LPFP | MOTIV Boost Box + MHD Protune | Quaife | Öhlins | Brembo | Akrapovic
02-09-2015, 08:18 AM | #9 |
711
Rep 3,251
Get it on a lift and see where it started. My guess is that you caught something in your undertray and that started the fire by rubbing on the super hot down pipes or exhaust manifold.
09 BMW E92 335i: Top Mount EFR 7670 / Dinan / AP Racing / Wavetrac / TC Kline [Full Mod List]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins 19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization |
02-09-2015, 08:26 AM | #10 |
12
Rep 294
If your windshield washer fluid has a decent amount of ethanol in it then that could have spilled from the cap and down the tray.
When the WW meth kits were catching fire I saw few people post that BMW changed the washer fluid cap to make it less prone to open while driving. |
02-09-2015, 08:29 AM | #11 | |
DOPE
148
Rep 758
02-09-2015, 10:30 AM | #12 |
91
Rep 610
02-09-2015, 10:42 AM | #13 |
533
Rep 2,872
My guess is the revs were high for a long period of time which super heated the downpipes, and that oil residue or any other flammable liquid that was down there just went up. Drifting around or even driving at a high speed would mean there's a lot of oxygen and air in the bay to make the heat to air mixture more suitable. Just a guess, but hopefully it doesn't happen again!
02-09-2015, 11:05 AM | #14 | |
294
Rep 922
02-09-2015, 12:45 PM | #16 |
BimmerPost Supporting Vendor
24198
Rep 190,805
Glad to hear no one got hurt
02-09-2015, 04:10 PM | #19 |
104
Rep 1,059
Update: So I was under the car for 30 minutes trying to find anything that looked out of ordinary and did not find much. The rubber hoses and wires seemed fine, all the plastic trays are perfect, no burns, no melting spots. All the rubber bushings are in normal condition. The only thing that looked odd was residue on the downpipes near the gaskets following the downpipes and also same residue on the rest of the downpipes. Looked like fire corrosion residue or something. Gaskets are toast, but they were already done prior.. Saw oil residue around the turbos, but looked same from last time I checked. Nothing leaking either..
02-09-2015, 04:28 PM | #20 | ||
3441
Rep 79,211
Honestly, I never used my WW fluid as I clean my car once a week, I'd sooner tell you all to leave it empty if it wasn't for the low fluid level light. My suggestion would to be to put 99% water with a dash of alcohol or methanol so it doesn't freeze. BMW should recall the entire WW reservoir as it's a fire hazard. As far as the OP, I'm thinking unburnt fuel or oil leaked out of the downpipes and caught fire, that's my only guess. |
02-09-2015, 04:47 PM | #21 |
148
Rep 965
Drives: e92 m3
theres no way any ww fluid will catch fire,my car caught fire due to the old caps it opened while sliding/drifting but i had 100% methanol n slightly overfilled.
e92 m3 dct
gintani stage 2+ full ethanol custom pulley and meth kw clubsport,ap racing radical,volk te37sl,akrapovic rear,recaro profi xl,voltphreaks battery |
02-09-2015, 05:33 PM | #22 | |
3441
Rep 79,211
Why do you think BMW redesigned their WW cap and put a flame symbol on it? I can assure you it's no coincidence. There is also WW fluid available over the counter with up to 40% methanol which is strong enough to go up in flames. |
