F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > '15 435i GC - 20" BMW 361 style wheels - best spacer size(s)?
Extreme Powerhouse
      02-07-2015, 11:40 AM   #1
sheriffd2
Twisting Your Mind
sheriffd2's Avatar
13
Drives: 2015 435iGC
Hoping for some expertise and advice....
I've got a set of black 20" 361 style wheels incoming for my 435iGC (can't wait!), and want to grab a set of spacers to install as well when they arrive. Obviously I'd like to have the flushest/most aggressive look, but it is a daily driver and both backseats and cargo are regularly loaded, so I don't want to encounter any rubbing issues. Car is stock height on stock sport suspension, although a future conservative drop may happen down the road.
So, what do you think in the best spacer combo? 10mmF - 12mmR? 10/15? 12/15?
Thank you in advance for any help!
2015 F36 435i Glacier Silver
      02-07-2015, 11:41 AM   #2
betlion
83
Drives: bmw
      02-07-2015, 11:44 AM   #3
sheriffd2
Twisting Your Mind
sheriffd2's Avatar
13
Drives: 2015 435iGC
Wow, thanks for the fast reply!
So I'll not encounter any rubbing with those?
These are the wheels/tires....
http://www.shopbmwusa.com/PRODUCT/37...RE-SET---BLACK
      02-07-2015, 03:40 PM   #4
Jimminez
Jimminez's Avatar
179
Drives: 2014 F31 M-Sport
You'll be fine with the 12/15 even if you get lowered.
Martin
Past - F31 M Sport Estoril Blue - Thread - Pic
Current - 2021 Audi RS6 Avant
      02-07-2015, 10:12 PM   #5
Engelb
Engelb's Avatar
11
Drives: 2012 BMW 335
I'm picking up a set myself this week and I have some bms spacers ... 10/15 I'll take some pics once i get them on.
Just hoping there's no rubbing ...
      02-07-2015, 10:16 PM   #6
sheriffd2
Twisting Your Mind
sheriffd2's Avatar
13
Drives: 2015 435iGC
Cool - looking forward to your pics!
      02-08-2015, 10:12 AM   #7
tboooe
tboooe's Avatar
925
Drives: F36 428i GC, E36 M3 - gone :(
I am assuming those wheels are the same width and offset as the standard wheels that come on our GCs?
I have 10/12 Burger spacers and lugs (their lugs are really really nice btw). That being said, you need to also consider the sidewall look of your tires. With Pirelli run flats I noticed that the sidewall sticks out past the edge of the wheel. On the other hand, Hankooks have a very vertical sidewall that is flush with the wheel. If I had a tire like Hankooks I would have used 12/15 spacers.
      02-08-2015, 10:51 AM   #8
sheriffd2
Twisting Your Mind
sheriffd2's Avatar
13
Drives: 2015 435iGC
The wheels/tires are:
Front: 8" x 20", Offset 36 - Pirelli P-zero 225/35 R20 90Y XL
Rear: 8.5" x 20", Offset 47 - Pirelli P-zero 255/30 R20 92Y XL
From what I've researched and has been suggested so far, I'm leaning towards 12/15mm spacer combo, but after your post I'm interested in your 12/12mm thoughts further...
      02-08-2015, 10:56 AM   #9
tboooe
tboooe's Avatar
925
I think those tires are the run flats right? In that case I would go with 10/12 or 10/15. That being said, I am very conservative and do not like any poke at all. To me, on stock suspension 10 up front is perfectly flush. 12 at the rear is nearly flush but I think 15 would create a little poke which I absolutely do not like.
      02-09-2015, 01:21 AM   #10
SourD
SourD's Avatar
No_Country
31
Drives: G82 / X3MC / M3LR
I have 10/15 right now with same wheel/tire specs in 19 (442m). 12/15 is perfect.
      02-09-2015, 06:01 AM   #11
StreetLegalR
Netherlands
18
Drives: 420I GC/M5 E60/M3 E46/CLK55AMG
German Spacer Company told me with OEM wheels you can go till ET19 front and rear, and that was on the 442M 19" wheels, those share the same wheel sizes and offsets like the 20" only 1" smaller. So Max in front will be 17mm and 28mm rear. But this is on OEM M Suspension. A guy here in the Netherlands drives a 418d GC with Breyton wheels : 8.5x20 ET35 and 10x20 ET35, in front he uses a 10mm spacer, so it's 8.5x20 ET25 and 10x20 ET35, this is with H&R Springs. With 4 person in the car no rubbing issues.
f30post
