Coolant temp displayed on Cobb?
02-07-2015, 03:33 AM | #1 |
77
Rep 980
Drives: '08 BSM 335i e92
I would like to monitor the coolant temp of my car. As you know, the 335 doesn't have it on the normal cluster. However, I have a Cobb AP V3 installed, and I use it to monitor different parameters while driving. Boost, Lambda, Oil Temp, etc. I've searched through the settings and I'm able to display up to 6 of 88 possible parameters. However, in these 88 parameters I could not find engine temp, or coolant temp. I'm wondering if it has a weird name (like lambda vs AFR) or something like that. Surely with 88 parameters, coolant temp would be included. Or does Cobb not have the ability to display coolant temp? Anyone know how to display coolant temp? Please and thank you.
'08 BSM E92 335i 6MT/MHD stg 2+/VRSF 7" FMIC/VRSF CP/HKS BOV/VRSF catless DPs/BMS DCI/muffler delete/BC Extreme lows/OEM style 167s/BMS high side OCC/Mishimoto low side OCC/etc
02-07-2015, 03:56 AM | #3 |
77
Rep 980
For anyone unfamiliar with the Cobb, I'll provide a list of the 88 parameters that it can display. For anyone who has experience with Cobb, can you please explain with some of the acronyms stand for, and if I did decide to monitor them, what range I'd be targeting?
Here's the list: Accel Ped. Pos. (accelerator pedal position, pretty obvious, though when I monitor this, even if I go full throttle, it only displays 99.6% is this normal? Why doesn't it display 100%) Actual Load Air Temp TB (is this the correct air temp to monitor? Or should I measure the charge air temp) Baro Pressure Battery Volt (pretty obvious) Boost (pretty obvious) Boost Error (what is this and what are the differences?) Boost Error D-Fact Boost Error I-Fact Boost Error P-Fact Boost Mean Abs Boost Over Shoot Factor Boost Set Limit Boost Setpoint Factor Charge AF Rate Charge Air Temp (is this the air temp I should monitor, or the Air Temp TB) Cyl1 Timing Cor (it's my understanding these should all be 0?) Cyl2 Timing Cor Cyl3 Timing Cor Cyl4 Timing Cor Cyl5 Timing Cor Cyl6 Timing Cor Cylinder Temp Comp Dynamic RPM ECT (is this Engine Coolant Temp?) Fuel HPFP Fuel HPFP Req Fuel LPFP Fuel LPFP Req Fuel Mode Gear (obvious) IPW Cyl 1 (what's IPW?) IPW Cyl 2 IPW Cyl 3 IPW Cyl 4 IPW Cyl 5 IPW Cyl 6 Knock Volt Cyl 1 Knock Volt Cyl 2 Knock Volt Cyl 3 Knock Volt Cyl 4 Knock Volt Cyl 5 Knock Volt Cyl 6 LTFT Bank 1 LTFT Bank 2 Lambda Bank 1 Lambda Bank 2 Lambda Req Bank 1 Lambda Req Bank 2 Lambda Value (AFR, should be 14.7 at idle, right?) Load Max Load Request Pre Load Requested Load To Boost Factor Load/MAF Comp MAF MAF Req MAF Req WDGC MAP Oil Temp (pretty obvious) Pres to MAF Comp RPM (obvious) Req Boost Abs Req Bst Delta STFT Bank 1 STFT Bank 2 TPS Act Timing Cor CAT/ECT Timing Cyl 1 Timing Cyl 2 Timing Cyl 3 Timing Cyl 4 Timing Cyl 5 Timing Cyl 6 Torque Limit Active Torque Limit Modifier Torque Output (obvious, but doesn't help since it reads in Newton Meters) Torque Requested VANOS Exh Act CRK (Vanos exhaust actual?) But what's CRK? VANOS Exh Req CRK (Vanos exhaust required?) VANOS In Act CRK (Vanos intake actual?) VANOS In Req CRK (Vanos intake required?) Vehicle Speed (obvious) WGDC Temp WGDC After PID WGDC Bank 1 WGDC Bank 2 WGDC Base Value Ok, sorry so long, but those are all 88..... can anyone help me identify or explain what they are and what their range should be displaying if I choose to monitor them? Any help is appreciated, thank you
02-07-2015, 04:00 AM | #4 |
77
Rep 980
Thank you. Can you help diagnose any others?
02-07-2015, 05:08 PM | #5 |
91
Rep 817
Isn't there a way to get your stock display to also show coolant temp through some coding or something? I'm talking about the check display where you check your oil level etc.....anybody know how to do this?
