Found a salvaged 08 328i, what to take for CCC retro?
02-07-2015, 12:22 AM | #1 |
Maximus Decimus Meridius
1130
Rep 4,584
I found a 328i sedan that's being parted out.. It has full navigation but it's CCC, however I'm thinking if I can snag a whole bunch of still to make my NBT retro easier, what all can I use from this car?? I have a E92 and from what I understand I can use any E90 or E92 dashboard to put navigation in my non idrive E92.. The guy told me for a veryyyy low set price I can take what I want he just wants it gone, haha so I don't wanna pass this up!!
Thanks! |
02-07-2015, 06:52 AM | #2 |
295
Rep 2,202
I'd say get the dash. Ask him if you could cut wires from it as well. Take wires for the controller, and for power to your new display.. Longest you can get. NBT controller will have more than the 4 wires required for CIC/CCC controllers tho.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
02-07-2015, 07:01 AM | #3 |
1130
Rep 4,584
Well I've contemplated on just doing CIC but it sounds like the NBT setup is significantly better then CIC, but I mainly just wanted to make sure it was compatible since its an E90 and I have an E92. And if it was, maybe someone who's done the retro can chime in on exactly what I need..
Thanks! |
02-07-2015, 07:18 AM | #4 |
Nomore
149
Rep 793
You could get everything he has. Do the retrofit using the CCC system. Then when its done you can change the connector ends and install either CIC or NBT without taking the dashboard off.
Find booster's idrive retrofit guide on here. It goes into detail what you need and what has to be done. If you can get everything cheap enough, thats what i would do. You can sell the CCC system when your done and get 200-300 maybe more. I completed the retrofit. I got the following from the donor car. Dashboard Headunit pigtail Video cable (specific to navi version) Controller knob pig tail Headunit dashboard mounting bracket Mounting Hardware Center speaker grill Hvac trim Headunit trim Center console trim Idrive controller knob Dont forget you also need: Fakra extension cable (trunk to headunit) Video cable for CIC or NBT or CCC Glovebox usb port for CIC/NBT Map dvd or software Coding cable |
02-07-2015, 03:12 PM | #6 |
1130
Rep 4,584
Funny that when I sent the complete list he wants to jack the price way up, but we'll see what I can get'm down to.. I wonder what's a good price to ask, for all that stuff.. Do you think $1k is to much for a CCC setup..???
02-07-2015, 03:31 PM | #7 | |
295
Rep 2,202
02-07-2015, 08:47 PM | #9 |
814
Rep 3,953
I would also say there is a chance this retro might not work at all. I would think the entire wire harness for inside the car is different.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
02-08-2015, 06:38 PM | #10 | |
Nomore
149
Rep 793
Fakra extension cable (trunk to headunit) - needed for any idrive retrofit Video cable for CIC or NBT or CCC -you buy video cable specific to model installing. Find part number for CCC, NBT, or CIC Glovebox usb port for CIC/NBT -only for CIC & NBT. Same for both Map dvd or software -Model specific Coding cable - needed for sure Its been done before. Ive done it. And alot of other people have done it. Theres a very good diy on here. It covers dissasembly, wiring, install, various part #'s. He does it exactly how it would have been done from the factory (wiring it in). |
02-11-2015, 01:52 PM | #11 | |
1130
Rep 4,584
02-11-2015, 03:45 PM | #12 | ||
Nomore
149
Rep 793
