"Slight" Transmission Slip
02-05-2015, 12:53 PM | #2 |
GoofBall
50
Rep 1,055
Its more likely the torque coverter unlock then locking for the throttle request. The higher the throttle the faster it makes the switch to give you more immediate power, where under lower throttle if you are doing this its still trying to accomplish a smooth shift but doing it the way you are isnt exactly the ideal use for the paddle shifters.
02-05-2015, 01:44 PM | #4 |
324
Rep 2,014
Is your car stock? I really doubt your tranny is slipping unless you're well over 400whp.
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3 Michelin PSS | M3 Control Arms LUX v4 LEDs | Shadowline Grills | Lip Spoiler |
02-05-2015, 02:22 PM | #6 |
24
Rep 150
I'm stock. its weird cuz this started happening after i flashed to alpina then back to OEM flash. what i mean by slip is that i would try to shift gear (push down shifter knob or pull paddle), instead of the revs holding then backing down, the rpm would raise a bit then come down.
02-05-2015, 02:23 PM | #7 |
BimmerPost Supporting Vendor
24199
Rep 190,807
What are you mods ? do you have any logs you can share with us?
02-05-2015, 02:28 PM | #8 |
24
Rep 150
only mods are afe stage 2 and vanguard. No tune. i dont have any logs unfortunately
I'm starting to feel like the next step is just to get the fluids changed and see if anything changes. |
02-05-2015, 02:31 PM | #9 | |
138
Rep 2,731
this has to do with the clutches not engaging correctly due to low atf pressure from a bad internal seal or a bad solenoid. overlap control works like this (from bmw): Overlap control provides gentle shift characteristics as follows: With overlap control, several multi-plate clutches are in use at the same time. Here, pressure is reduced in the active multi-plate clutch and at the same time built up in the clutch that is about to be activated. The reduction and build-up of pressure is maintained until a synchronised speed is reached. At this point, the hydraulic pressure for the multi-plate clutch to be activated can be built up completely. Overlap control is active for all gearshifts from 1st to 6th gear and from 6th to 1st gear. have you been into INPA and checked a module called EGS, that where you will find tranny codes. there should be 4f85, 4f80, 4f82, 4f8something codes. ratio mismatch anyway if this gets worse, expect a red dash light and it to lock into 3rd gear until you restart it. this is normal when it detects a bad slip. if it continues you will want to start thinking about replacing the solenoids and the seals. (not just the mechatronic seal but several inside). the transmission is savable. if it gets worse don't ignore. my thread about chasing down my problem.... http://www.e90post.com/forums/showthread.php?t=1055457 another thread that followed.... http://5series.net/forums/diy-do-you...thread-137584/ if it gets worse, fix it before the transmission is damaged. |
02-05-2015, 02:40 PM | #10 |
86
Rep 1,849
The automatic transmission in my 2011 E90 335i has been having some jarring clunks primarily in stop'n'go traffic. When going from 3-2 it will clunk and even lurch a little, and do the same when going from 2-3.
The oddest feeling is when I sometimes come to a stop, there will be a lurch as if it wants to keep going even though I have already completely stopped. Anyway, it's at the dealership and they've confirmed the odd shifting. Next up is to reset the TCU and see if the problem goes away. Haven't heard back yet and it's been a couple days.
2011 E90 / Premium Package / Stage 2 PPK / Performance Suspension
02-05-2015, 02:41 PM | #11 |
86
Rep 1,849
Thing is, it's always smooth under strong acceleration. And the lurches don't happen all the time in start and stop traffic, only occasionally.
02-05-2015, 02:44 PM | #12 |
24
Rep 150
im not there yet^ it stop smoothly for me. i think the lurch after stop is definitely a warning sign. keep me updated on what dealer says! haha
also. mike, i dont have any warning signs on the dash so wouldn't that mean if i went into the EGS module, there wouldn't be anything there either :/ |
02-05-2015, 04:21 PM | #13 | |
138
Rep 2,731
02-05-2015, 04:45 PM | #14 | |
Rep 65
02-05-2015, 05:44 PM | #16 | |
need4speed
510
Rep 1,903
N54
02-05-2015, 05:51 PM | #17 | |
138
Rep 2,731
i think i will stick to changing out some solenoids and seals once every 200,000 miles. |
02-05-2015, 05:54 PM | #18 | |
24
Rep 150
hahaha has anyone on the forums even done the swap from auto to manual? |
02-05-2015, 05:55 PM | #19 | |
432
Rep 1,602
Leave the auto's for drag cars, trucks and the ladies. |
02-05-2015, 05:57 PM | #20 | |
138
Rep 2,731
02-05-2015, 06:19 PM | #21 | |
Rep 51
Drives: 09 BMW 328i xDrive
02-05-2015, 06:29 PM | #22 |
24
Rep 150
i actually just changed the battery from non-agm to agm, when i was getting the alpina flash, i also registered the new battery.
