02-04-2015, 12:27 AM | #1 |
335
Rep 737
What does "balanced chassis" mean ?
A LOT of M235i review videos on YouTube say that its chassis is balanced. Please tell me how you would interpret "balanced chassis". And, feel free to share any other thoughts or observations you have about the M235i's handling, steering, etc.
Thanks very much !!!
02-04-2015, 06:17 AM | #2 |
3077
Rep 5,577
It can mean literally; the full weight of the car is split nearly evenly between front and rear axles/tires or a descriptive that at high cornering speeds the tires break away in an even controllable yaw - that steering and suspension provide very intuitive controllable performance.
02-04-2015, 09:05 AM | #3 |
1539
Rep 3,332
When driving a vehicle at the limit it weight distribution becomes very obvious. It's one of the reasons tail heavy older 911's were very hard to control at the limit, the weight would make the car want to rotate around.
Likewise a very front heavy car will have more tendency to plow or understeer, making turning into corners more difficult. Since all BMW's are much better at having near perfect front/rear weight distribution the car is neutral/balanced. It doesn't exhibit either of those characteristics which is why it's such a delightful thing to throw around corners.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette |
02-04-2015, 09:28 AM | #4 |
3077
Rep 5,577
For the second part of your question;
I'm running the PSS summer tires throughout the winter. When the rear tires slip laterally on ice - you feel it immediately in the steering wheel. It's hard to describe but it's as though the steering gets light. And it's very informative and gives confidence and control. And it's one of the factors that make it a great daily-driver. In warmer temps and high-speed cornering I think the car is tricky. The cars narrow track/width and upright seating and cars body upright design means you really need confidence in the mechanical grip of the tires. The car is fast and even on the highway you can find yourself entering what seems like a sweeping broad bend at supercar speeds. And the car pushes to the outside of the curve with slight under-steer / front of car running wide. I think it's the narrow track and weight up high that can make those situations heart dropping. But I think it the safe way to set up a car. And why the M2 with a wider track could be a little more confidence inspiring in those same turns. In tight turns the M235 is amazing, fast with large amounts of grip and great power to keep up or increase speed. I don't have enough or wish to thrash the car to comment on high-speed or repeated braking. |
02-04-2015, 10:30 AM | #5 |
269
Rep 470
2015 M235i | AW | 6MT | Tech | Heated Seat | Parking Assist | Fabspeed DP & Muffler Delete | Apex PS7s
1999 MX5 NB | Emerald Mica | 5MT | Sport Edition | Kosei K5Rs | Heated Rear Glass ig: @bee2ven |
02-04-2015, 10:58 AM | #7 |
3077
Rep 5,577
So the question is can a Ferrari 458 or Porsche GT3 never be a 'well--balanced' car?
If you can get the center of gravity low enough can you design a well balanced car. Porsche makes a well balanced car in the 911 by having a pivot point near the front axle line, 458 with pivot point near center and Miata and M235 with pivot point near center of gearbox. So maybe things like power to grip ratio mean well balanced. Really good question from original poster. |
02-04-2015, 11:00 AM | #8 |
3077
Rep 5,577
02-04-2015, 12:08 PM | #9 |
Mess Deck Commando
244
Rep 807
I've owned some 911s (air-cooled) in the past. One of was a 930 Turbo which I drove for over 15 years. One of the most significant handling mod I did to that car was going wide as in 315's at the rear from the OE 225s. That was a huge jump that necessitated custom made wheels to fit correctly. It was still a handful at top end but those wider rear wheels helped tremendously. Of course, I eventually had other suspension upgrades as available technology came to light.
02-04-2015, 12:22 PM | #10 | |
451
Rep 845
As mentioned, most cars (for safety reasons) are set up to "push" or understeer, as it is easy (easier) for most drivers to handle their car going off the road because they came in too quick. Some other cars (old Porsches, some mid-engined cars) have oversteer/snap-oversteer (the car is "loose") where the back end of the car breaks loose around a turn, and you spin out. This is a little harder to deal with, especially if you haven't been taught (opp lock, etc.) When they speak about the M235i (or any other good BMW, Porsche, Ferrari, whatever) having a "balanced" chassis, I think they mean that the car is "neutral" i.e. it doesn't really over or understeer, it just has a limit of grip generally. I had camber plates put in on Monday, and the alignment specialist asked me how I wanted my car set up -- did I want to keep "grabbing the tail" (i.e. oversteer) or something else? I told him I wanted balanced i.e. neural steering (the front has about the same amount of lateral grip as the rear). So I think that is what people talk about when they say "balanced," but I could be wrong. |
02-04-2015, 12:44 PM | #11 | |
1539
Rep 3,332
If you want to break out the engineers and track rats then we can start talking about polar moment of intertia and the benefits of shifting the weight around due to the fact that a car behaving dynamically is different than one sitting on a teeter totter (like the Miata ad). Either way, in very general terms chassis balance has to do with a car neither wanting to understeer or oversteer. The closer the car is to "Balanced" means you can add throttle to create oversteer in a controlled manner, vs snap oversteer which happens suddenly as the heavy mass of a rear engine car wants to overtake the front end. Porsche has done a great job of sorting that out with years of refinement in suspension, aero, and computer wizardry to build a car that can take advantage of it's extra traction and still handle phenomenally. With that said, there are non-super cars like the Miata, BRZ, or the 2 series which focus on the front-rear configuration and create very capable, fun cars that are easy to learn to drive fast because they have very predictable handling characteristics at and beyond the limit of grip. Theres a reason race teams pay brilliant engineers lots of money to sort all this out.
02-04-2015, 01:35 PM | #12 |
***** noob
1372
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
Chassis is basically the frame of the car. A well balance chassis will need good weight distribution. Good axle placements and a wider track is also good balance. So lets say if the engine is placed infront of the front axle, thats nose heavy. Well balanced cars uaually have the engine sit 60-90% behind the front axle.
Bmw have their engines sit around 65-75% behind the axle. RWD with some items placed in the trunk area (battery, hardware, etc)
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
02-04-2015, 01:44 PM | #13 | |
257
Rep 721
