Time for new brake pads and new rotors?
02-03-2015, 08:55 PM | #1 |
18
Rep 118
So I originally had a post asking for brake pad recommendations. Now I'm seeing it may be time for new rotors as well. Because when you replace brake pads usually it means new rotors. I'm currently at 43k miles on my 2009 E92 335i. The dealership is having a special on rotors and pads for around $575-$625 which means they would be replacing with OEM rotors and pads. Are there better rotor/pad combos I could get with $575-$625? What do you all recommend I do?
Do i just go with these? because the dealership was charging this same amount as this complete set for only the rear rotors/pads. http://www.ecstuning.com/BMW-E92-335...Kit/ES2594689/ Or http://www.ecstuning.com/BMW-E92-335...Kit/ES2588538/ Last edited by Echo335; 02-04-2015 at 10:48 AM.. |
02-03-2015, 10:02 PM | #3 |
261
Rep 1,093
Nothing really special about the special as that's about $450 worth of OEM parts. Obviously OEM pads and rotors aren't going to be the best value. At oem $300 rotors, $130 pads and $20 sensor you have a multitude of equivalent and upgrades for the same or less money (ECS geomet, Centric/Stoptech cryo, R1, Zimmermann etc) and pads are even more plentiful. Your biggest savings would be removing the two caliper sliding bolts and two carrier bolts and DIY.
I personally went with ECS geomet drilled/slotted rear, ECS 2pc front rotors and Hawk HPS pads all around. |
02-03-2015, 10:15 PM | #4 | |
18
Rep 118
http://www.ecstuning.com/BMW-E92-335...nce/ES2587992/ |
02-03-2015, 10:28 PM | #5 |
287
Rep 1,710
I'm on the verge of needing new brakes, but I'm going to DIY route. I'm gonna give Stoptech pads a try. Turner Motorsport is turning out to be a great resource for parts shopping, I also crossshop with ECS Tuning, but I find their brake package a bit more pricey, but I love their tool selection.
DONE: Seibon CF Hood, M3 Rep, MSport rear w/DD CF Diffuser, M3 Rep Skirts, Seibon CSL trunklid, Forgestar F14 18s w/Michelin PSS, Eisenmann catback, AA Headers, BPC Stage 2, Charcoal Delete+revMotor+AFE Drop In filter
FUTURE MODS: LED headlights, CF rooftop, M3 Suspension Conversion, Dinan CAI Mod |
02-04-2015, 07:48 AM | #6 | |
261
Rep 1,093
02-04-2015, 07:50 AM | #7 |
261
Rep 1,093
02-04-2015, 08:46 AM | #9 |
74
Rep 776
You can get rotors/pads/sensor parts & DIY from pelicanparts.com for less than $300 per axle. That's $600 total for all 4 wheels. If you don't DIY then maybe try the regional forum. Find someone close to you who would be willing to spend an afternoon teaching you how to do this...its definitely not a difficult job. Offer them some microbrews or whatnot maybe.
Also, with regards to your question, once the sensor is replaced and you do the reset through the menu, the brake light on your dash will go away. For brand names I would recommend Akebono Euro pads and either Zimmerman or Brembo rotors. Call the guys at Pelican they can tell you what you need. |
02-04-2015, 09:36 AM | #11 | |
352
Rep 1,403
02-04-2015, 10:22 AM | #12 | |
149
Rep 1,995
Go with Meyle HD rotors.. Set of 4 cost less than 200. Then Hawk pads that cost about 65 a pair and comes with sensors. |
02-04-2015, 10:31 AM | #13 |
74
Rep 776
Its not a bad price but WHY do you want drilled & slotted rotors? Is this a track car? If not, then thats total overkill. If its just a daily driver then stick with something closer to stock parts.
02-04-2015, 10:32 AM | #14 |
149
Rep 1,995
drilled and sloted rotors just end up cracking on some bullshit if they get real hot and go through water.
02-04-2015, 10:43 AM | #15 |
18
Rep 118
Oops. I posted the wrong link. I wouldn't do both drilled and slotted. I would do either just drilled or just slotted.
What about that? The guides on websites like Turner motorsports say that Cross Drilled Rotors are simply aesthetic and won't contribute to greater pad wear. Last edited by Echo335; 02-04-2015 at 11:09 AM.. |
02-04-2015, 10:51 AM | #16 |
18
Rep 118
Edited the OP. Those are two options I saw. Also saw turner motorsports has just cross drilled with a choice of oem pads, hawks hps 5.0 pads, etc all for $650.
Here's the list: http://www.turnermotorsport.com/p-28...-e9x-335i.aspx Or http://www.ecstuning.com/BMW-E92-335...Kit/ES2594689/ Or http://www.ecstuning.com/BMW-E92-335...Kit/ES2588538/ |
02-04-2015, 11:01 AM | #18 |
105
Rep 955
There is a loss of mass with drilled/slotted rotors. Also not many companies drilled the holes into a cast rotor.
They will work but likely crack and not last as long as blanks do. But hey you will look cool. Now if you track your car sure but not if you are only using your car as a daily driver. Tracking has a special yearly budget, wear and tear includes rotors and pads. At least with me it does. By the way get the right brake pad don't go mixing semi metallic or you will wear does puppies in about 4 months. |
02-04-2015, 11:14 AM | #19 | |
352
Rep 1,403
02-04-2015, 11:39 AM | #20 |
18
Rep 118
Just as an easy kit just one easy buy,
http://www.ecstuning.com/BMW-E92-335...nce/ES2594689/ http://www.ecstuning.com/BMW-E92-335...uid/ES2072516/ |
02-04-2015, 11:59 AM | #21 | |
74
Rep 776
02-04-2015, 12:08 PM | #22 | |
149
Rep 1,995
silly waste of money. Sport brake fluid?? |
