02-02-2015, 06:57 PM | #1 |
38
Rep 130
Remove the iDrive trim
Hi,
Is there any easy way to remove the iDrive trim? I found it is quite tight and I can't hardly use a pry tool to insert into the gap between the trim and the car console. I'm thinking about using a thin thread to slot into the gap and then pull up the trim from the top side. Any good idea? |
02-02-2015, 08:46 PM | #2 |
2810
Rep 5,316
Drives: G80 M3 6MT
You really should just be able to pop a trim tool underneath it on the sides and pop it up.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
02-10-2015, 12:17 AM | #3 | |
38
Rep 130
I think starting at the middle of the iDrive controller trim will be easier because it is looser there and easier for you to insert the pry tool. |
