Fix a flat and TPMS don't mix well...
02-01-2015, 08:34 AM | #1 |
426
Rep 2,136
Hey guys,
I was out of town a few days ago and drove over a nail, started losing pressure slowly in my passenger rear tire. I don't have run flats so I thought it would be a good idea to have a can of fix a flat in my trunk at all times for occasions like this... I emptied the can in the tire, pressurized the tire back up to 35psi. While it worked slowing down the leak rate enough to get me to a tire repair shop without having to call AAA, it ended up messing up the TPMS... Lesson learned. Can I just buy a replacement TPMS and have a local tire shop put it on or does it have to be coded by BMW?
JB4 G5 w/ Backend flash - Walbro 450lpfp - VRSF DPs - VRSF 5" stepped IC - DCI - ER CP w/ Tial BOV - 335is clutch |
02-01-2015, 10:54 AM | #4 |
138
Rep 2,731
I have found that the best solution is to carry tire plugs and a cheap air compressor. No mess. You stick the plug in the tire from the outside, then pump it up again. When you get time you go to the tire shop and have them replace the plug with an inside patch.
02-01-2015, 11:07 AM | #5 | |
681
Rep 3,696
So its hard for me to understand that a self contained sensor broke (it might just need to be removed and cleaned of all that fix a flat gunk) i've washed my sensors with soft soap and warm water to make them look brand new in the past. If your sensor is truly failed and you do replace it... I would like you to keep your busted sensor and mail it to me to see what i can do to revive it cuz its going to be a problem for others as well and i would like to have a solution or reason for the failure to discuss. |
