Idle stumble...New Plugs...Fixed...NOT FIXED - Need Help..and UPDATE w codes - FIXED
01-30-2015, 06:07 PM | #1 |
17
Rep 254
BACKGROUND:
So, I started a thread last week on an intermittent stumble I had at idle that didn't throw any codes for months. Eventually, it began to stumble more and then badly (even past idle) and threw a code for misfire in #6. I started by replacing the coil. That didn't fix the issue. So, I replaced plug #6 - didn't have time to do them all that night. That helped, but I still had the intermittent stumble where it might stumble once or twice every few times I stopped and dropped to idle. I replaced all the plugs last weekend. It was great for a day or two. Now it's back to an occasional stumble when at idle. Original thread: http://www.e90post.com/forums/showthread.php?t=1080477 QUESTION: What's my next step? Try replacing all the coils? It seems like it must be an ignition issue, since changing the plugs made a difference, even if it didn't solve the issue. If it were an injector issue or a vacuum issue - rather than ignition - is there any reason the stumble would have gotten better by changing out the plugs? UPDATE The thing went off the F@*ing rails today. Got about a mile from my house when it started fully misfiring, SES came on, pulled the codes: Fehler: Failure detection cyl.7 / Misfire cyl. 5 / Short circuit to ground intake Code: 29D1 Fehler: Misfire at low tank capacity / To misfire at low fuel level / Inlet air temperature is too low / Verbrennungsaussetzer bei niedrigen Kraftstoff-Fuellstand / Misfire detection with low fuel level Code: 29D9 Fehler: Failure detection cyl.11 / Intake air temperature sensor / Misfire cyl. 6 / Lambda probe before catalyst pump current line Code: 29D2 Fehler: Failure detection checksum / Misfire detection error summation / Intake air temperature sensor temperature is too high / Central control timeout Code: 29CC Update 2 Chased down a bad coil in #5 by swapping coils and checking misfire code. The bad stumble is gone, the intermittent stumble is back. Looks like at the least there is more than one bad coil. And who knows what else. Will change the rest of the coils this weekend. Update 3 Changed coils last Saturday morning, no stumbles at all since. At the moment, I'm tempted to say the problem seems to have been resolved. Last edited by ny330xi; 02-11-2015 at 06:10 AM.. |
01-30-2015, 06:50 PM | #3 |
352
Rep 1,403
When was the last time you changed the plugs and coils? How many miles are on your car?
You probably do need to go ahead and change the rest of your coil packs if they've never been changed. This may not fix the problem but it needs to be done regardless. What brand plugs and coil pack did you use? Did you check your gaps on the plugs? |
01-30-2015, 07:07 PM | #4 |
352
Rep 1,403
After replacing the rest of the coil packs, if the problem still persists I personally would go straight to the VANOS solenoids.. From there I'd go to the coolant temp sensor.. Before you do any of that though check for codes first. VANOS solenoids have been known to not throw faults before..
01-30-2015, 07:13 PM | #5 |
51
Rep 605
Id buy a coil or two, only twenty bucks on amazon. try swapping them out. And you can switch the vanos solenoids with each other. that works sometimes. clean them off too.
http://www.bmwfanatics.co.za/showthread.php?tid=37935 http://www.pelicanparts.com/BMW/tech..._Replacing.htm |
01-31-2015, 12:10 AM | #6 | ||
17
Rep 254
No, it only threw the code once, when the stumble got really bad. I cleared it, changed #6 plug, and it didn't come back.
01-31-2015, 06:09 AM | #7 |
295
Rep 2,202
What are you using to pull codes?? Reason I ask is that it will be better to use a BMW scan tool rather than a generic one.
Vanos can sure be an issue and there are codes for them when it happens. That's actually how I replaced both.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
01-31-2015, 11:13 AM | #8 |
129
Rep 1,052
my stumbling was 2 leaking fuel injectors.
'08 328i | TiAg | 6MT | CDV Mod | RevMotoring Silicon Intake Tube | AG M310 | Cold | Premium | HiFi | V1 Hardwire | AirPlay - FiiO DAC
'15 Golf SE Sport | Pure White |
01-31-2015, 03:55 PM | #9 | |
17
Rep 254
Interesting. What codes were you seeing? Last edited by ny330xi; 01-31-2015 at 06:26 PM.. |
01-31-2015, 03:56 PM | #10 |
17
Rep 254
Fehler: Failure detection cyl.7 / Misfire cyl. 5 / Short circuit to ground intake Code: 29D1 Fehler: Misfire at low tank capacity / To misfire at low fuel level / Inlet air temperature is too low / Verbrennungsaussetzer bei niedrigen Kraftstoff-Fuellstand / Misfire detection with low fuel level Code: 29D9 Fehler: Failure detection cyl.11 / Intake air temperature sensor / Misfire cyl. 6 / Lambda probe before catalyst pump current line Code: 29D2 Fehler: Failure detection checksum / Misfire detection error summation / Intake air temperature sensor temperature is too high / Central control timeout Code: 29CC So, now I'm seeing multiple misfires. WTF? Cleared the codes, took it around the block, and just the cylinder 5 code came back. Last edited by ny330xi; 01-31-2015 at 04:28 PM.. |
02-02-2015, 06:01 AM | #12 |
17
Rep 254
Still chasing this thing around:
Yesterday, since now it would pop an SES immediately on startup, I tried swapping coils to see if the code followed the #5 coil. It did. So, I swapped out the #5 and that stopped the severe misfire. The #5 coil apparently died. However, it's gone back to an intermittent miss. A couple stumbles fairly consistently when at idle. I ordered more coils. I'll change them this weekend and check the plug gaps again. I'm not sure what would make more than one coil go bad at once, but it seems there's another underlying issue. Will update again after this weekend. |
02-02-2015, 07:34 AM | #13 |
138
Rep 2,731
02-02-2015, 02:38 PM | #14 | |
17
Rep 254
I did buy OEM plugs, NGK iridium, the current part revision #; they were pre-gapped. I checked a couple, they were fine. I'm going to take them all out and check again. |
02-02-2015, 02:43 PM | #15 |
138
Rep 2,731
If the gap is too great, the coils are overworking trying to create that spark, can lead to premature coil failure. On my car I had 1 coil go out, then another a month later, then one more shortly after that. In the end i said fuckit and just replaced them all instead of doing them one at a time. Turns out the electrodes on my plugs was pretty much gone, so the coils were probably having a hard time delivering a full spark.
02-02-2015, 09:14 PM | #17 | |
17
Rep 254
You're reading this in real time. Still working on it. |
02-11-2015, 06:13 AM | #19 |
17
Rep 254
UPDATE 3
Last Saurday, I went in checked all the plug gaps, no issues, changed out coils 5 and 6 with OEM Bosch parts - the two cylinders which had associated codes. Since, I've had no stumbles at all. Fingers crossed. As a side note, I decided not to replace all the coils for purposes of isolating the issue. I'll replace the rest after a couple thousand miles if there are no further issues. |
