Seafoam on an N54?
01-30-2015, 02:33 PM | #1 |
Nerd
125
Rep 437
Seafoam on an N54?
Has anyone used SeaFoam on their N54? What were your results?
Just curious if it's worth buying for a 75,000 mile car. I know walnut blasting is a better choice, but until I arrange for that, I was hoping SeaFoam might help.
2009 E92 335i Sport 6AT - Finished, sold
Transport for Ireland - LEAP Pass with TFI smartapp because cars are stupid expensive in Ireland |
01-30-2015, 02:43 PM | #2 | |
Objects in the mirror are losing
105
Rep 1,133
Drives: 2007 BMW 335i E92 AW/CR 6MT
01-30-2015, 02:45 PM | #3 |
530
Rep 2,083
I put a can in the tank every now and then but there is probably no point since it's direct injection. It would only help clean the injectors.
2013 135is DCT Carbon Black Metallic |
01-30-2015, 02:45 PM | #4 |
Nerd
125
Rep 437
SeaFoam is like $10 and takes fifteen seconds to pour in your tank. Walnut blasting is several hundred and takes hours.
Also, I'm not terribly likely to drive to SoCal for it. Thanks.
01-30-2015, 02:55 PM | #5 |
388
Rep 1,945
01-30-2015, 03:05 PM | #7 |
530
Rep 2,083
He could also be referring to the process where you suck the seafoam into the intake via a vacuum line, in which case some would get onto the valves. But honestly, that carbon is so caked on that nothing will get it off other than walnut blasting or equivalent.
01-30-2015, 03:05 PM | #8 | |
167
Rep 2,210
So pour all the SeaFoam you want in it as it's only 10 bucks and takes fifteen seconds, but it's a waste of money and time |
01-30-2015, 03:23 PM | #9 |
181
Rep 1,681
By using Seafoam, you'd waste $10 and 15 seconds of your life. It will do nothing for your valves since fuel never sees them. That's the entire reason there is even buildup, no fuel is sprayed over the valves. Maybe it will help your injectors, but you're probably better off getting a dedicated fuel treatment.
Seafoam isn't magic, it's not any different than any of the other additive. It was created for outboard motors to clean up varnish. It's just marketed well, but there isn't anything special about Seafoam. It's biggest ingredient is very lightweight oil, then a solvent, then alcohol, that's pretty much it. People just think it works because when they suck it into the intake, their cars start running badly and blowing smoke out the exhaust. Somehow people equate that with deposits being burned off. It's mostly just the Seafoam burning; it's mostly oil and solvent so it's going to smoke. Pour some oil into your intake, I bet the car will start running rough and blowing smoke too. |
01-30-2015, 04:04 PM | #10 | |
Nerd
125
Rep 437
01-31-2015, 12:40 PM | #13 | |
43
Rep 303
