Mo Reviews
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      01-30-2015, 12:11 AM   #1
goosey2099
13
Drives: 2015 M4/2001 GALANT AWD
Seat memory
Is there any way to code the seat to move back when the ignition is turned off and to go to preset 1 on startup???
      05-13-2015, 07:12 AM   #2
Unixed
37
Drives: 2015 F80 - M3
I have been looking for that option for a long time now. I don't believe it is possible.
I do have a work around. Program the seat memory button 1 with the get in or out of the car setting (seat all the way back). Program seat button 2 with your perfect driving setting (seat positioned the way you like to drive).
Now, open the driver side door with the ignition off. Push button 1 or 2. The seat auto adjusts without having to hold the button!
Once the seat is positioning itself, you may shut the door and turn on the ignition and the seat will continue to adjust. However, if you put the car in gear, the seat stops adjusting.
Sometime if the car has been in the off position for a long time, when you press the button 1 or 2 with the driver side door open, the seat does not move continuously. Press the brake peddle firmly and then press the button once again. It will then auto position. Remember, the key is the driver side door must be opened and the ignition off when you begin to adjust your seat.
Hope this helps.
      11-25-2015, 11:12 AM   #3
G4BR13L
G4BR13L's Avatar
Belgium
521
Drives: BMW M4
I am interested in this as well!
      11-25-2015, 11:27 AM   #4
geneatals
Ninja
geneatals's Avatar
390
Drives: 2019 530e
yes there is, alex@alpine coded this very feature for me...sorry don't know the actual module or code but just wanted to confirm this feature is possible...
seats slides back a few inches at engine shut off, upon returning to vehicle: with door closed and electronics turned on the seat will slide forward the same distance it traveled in reverse...
2019 AW G30 530e l ZPP l ZMP l ZDH
Retired: 2016 F80 M3, 2012 E90 M3, 2008 535i
      11-25-2015, 11:34 AM   #5
dmnc02
dmnc02's Avatar
920
Drives: 2015 M4
All you have to do is : take a look at this thread.
2015 Mineral Grey ///M4 6MT
      11-25-2015, 12:16 PM   #6
G4BR13L
G4BR13L's Avatar
Belgium
521
Drives: BMW M4
This isn't the first time you tell me to use search but believe me I have how else did I get here? So either something is wrong with the mobile site or the search sucks but ni matter what keywords I search on.
For example this is the crap the search gives me when I search on force brake flashing:
http://f80.bimmerpost.com/forums/sea...rchid=41896987
So I don't know what I am doing wrong.
      11-25-2015, 12:25 PM   #7
dmnc02
dmnc02's Avatar
920
Drives: 2015 M4
It wasn't directed at you (or at anybody in particular): I just like that smiley.
Anyhow, this one was admittedly tricky, since the title of the thread is not very suggestive: it is easier if you know that BMW calls this feature "Easy Entry".
BTW, did I really tell you to use the search before?
      11-25-2015, 12:51 PM   #8
G4BR13L
G4BR13L's Avatar
Belgium
521
Drives: BMW M4
Thx for your help! I just coded it based on that thread and it works. I just have to figure out how I can move the seat further back... But I will continue in that thread.
Next on the list is the force brake flashing coding. I want to enable it at lower speeds and faster meaning at a lower deceleration.
      11-25-2015, 01:17 PM   #9
dmnc02
dmnc02's Avatar
920
Drives: 2015 M4
I think you will be able to figure this out if you read the whole thread
Try FEM_BODY > ESS_AKTIVIERUNG_GESCHW (speed) and ESS_AKTIVIERUNG_REALE_VERZ (deceleration).
      11-25-2015, 01:28 PM   #10
G4BR13L
G4BR13L's Avatar
Belgium
521
Drives: BMW M4
Figured out how to move the seat further back and tomorrow I will give the force brake flash parameters a try.
      11-26-2015, 06:48 AM   #11
Nonopr01
122
Drives: 2017 BMW M3
How did you figure de seat option. I have coded for it and it doesn't work. Tried everything here
      11-26-2015, 08:36 AM   #12
G4BR13L
G4BR13L's Avatar
Belgium
521
Drives: BMW M4
There are 3 settings and all three are as I recall it in the SM2(D6) module, there is also a SM2(E6) module but in that module I could not set the value for EINAUSSTIEGSHIELFE to "Modus_FA_SLV".
3000 SM_GLOBAL -> EINAUSSTIEGSHILFE = "Modus_FA_SLV"
3012 EAH -> EAH_VERFAHRWEG_SLV_PHYS = Werte=00, 28
3012 EAH -> EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS = Werte=00, 3C
      11-27-2015, 12:35 AM   #13
Brasko
#LSBM3
Brasko's Avatar
No_Country
1418
Drives: 2016 BMW M3
The easy entry feature should be something programmed from the factory. Why does BMW cut these features out? Ridic!
/// M3
      11-27-2015, 03:29 AM   #14
G4BR13L
G4BR13L's Avatar
Belgium
521
Drives: BMW M4
By the way with EAH_VERFAHRWEG_SLV_PHYS you specify in a hexadecimal value how many milimeters you want the seat to move back, so if you want for example to move back the seat with 5 centimeters then you must set EAH_VERFAHRWEG_SLV_PHYS to Werte=00, 32
With EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS you specify how many milimeters of free leg space you want to keep for the passengers sitting on the back seat.
So basically you can set EAH_VERFAHRWEG_SLV_PHYS to Werte=00, FF which is then move the seat back with 25.5 cm (imho the maximum) and then play with the EAH_SCHUTSFREIRAUM_HINTEN_SVL_PHYS setting.
This has the advantage that no matter how far your seat is set, that the seat will be moved back the maximum number of milimeters but always respecting the free leg space for the passengers in the back.
And converting hexadecimal to decimal and vice versa can for example be done here:
http://www.binaryhexconverter.com/he...imal-converter
Appreciate 2
      11-29-2015, 02:16 AM   #15
G4BR13L
G4BR13L's Avatar
Belgium
521
Drives: BMW M4
I guess that the SM2(D6) module is for the driver side and the SM2(E6) for the passengers seat. Can someone confirm this and I would to know if we can enable easy entry/exit for the passengers seat.
      11-29-2015, 08:59 AM   #16
G4BR13L
G4BR13L's Avatar
Belgium
521
Drives: BMW M4
To answer my own question I set EINAUSSTIEGSHILFE in the SM2 (6e) module to werte=03 and now the passenger seat also returns to the last position.
      12-02-2015, 12:23 PM   #17
Nonopr01
122
Drives: 2017 BMW M3
That work out this time like I wanted.
      02-07-2016, 11:28 PM   #18
rcw119
rcw119's Avatar
116
Drives: 16 F82 Sakhir Orange
I coded these and it isn't working. Looked again and they are set right in SM2 6d. Recoded just to be sure and still not working. I coded other things and they work just fine. Dvd in motion, cameras at any speed, etc. FY16 F82 Ideas???
Rob - rcw119
- 2016 F82 - 6MT - Sakhir Orange
- 2014 E84 xDrive28i - Valencia Orange
- 2008 E92 335i - 6MT - Sparkling Graphite (Retired)
      01-20-2018, 05:21 PM   #19
Marky Mark
42
Drives: 2014 xDrive35i
I got my 2014 X5 35i programmed to move the seat all the way back, but how about programming it it go all the way down (for easy exit)?
2014 X5 xDrive35i:
MPPK+MPE, Premium Package, xLine, Driver Assistance Plus, Driver Assistance Package, Lighting Package, Luxury Seating Package, Cold Weather Package, Night Vision w/Pedestrian Detection, ACC Stop& Go + Active Driving Assistant, harmon/kardon Surround Sound System, Space-Saver Spare, 4-Zone Automatic Climate Control, Poplar Wood Trim, towing package
      08-09-2022, 10:58 AM   #20
njavier03
82
Drives: BMW F82 M4
Is it possible to deactivate or just the passenger seat? BimmerCode doesn’t have an unassigned value option, only active. Any help with the expert coding is appreciated.
Search this Thread:
Advanced Search
f80post
