anyone replace a rear wheel bearing?
01-29-2015, 09:24 PM | #1 |
Rep 122
Question guys what method are you using to get the rear hub off? also does the axle need to be removed before you pull the hub? how are you getting the axle out mine didn't simply slide out apparently.
01-30-2015, 05:18 AM | #2 | |
DIE ANTWOORD
68
Rep 640
https://www.youtube.com/watch?x-yt-c...-ts=1422503916 You can't press in a new bearing unless you haven't removed the axle. Give it a good whack with a hammer and it should slide out. Protect the threading either by the nut (you should buy a new nut anyway) or a piece of hard wood. The bearing is secured by a spring retainer. Do not forget. Press the new bearing in applying force only to the outer race. If you press it in at the inner race expect the need for a new bearing in less than 10.000miles. For pulling in the new bearing you can use the outer race from the old bearing as a stamper. For this take an angle grinder and make one cut to get it into an open C -like shape. This prevents the stamper from beeing stuck and you can retract it easily.
King of the road says you move to slow
03-27-2015, 05:54 AM | #3 |
Rep 18
I used a hub puller that you bolt onto the hub and then use the center stud to push the axle out, I have a picture of the puller and of doing the job but can not figure out how to post a picture
03-28-2015, 06:06 PM | #6 | |
453
Rep 2,973
Funny though, I've been driving BMWs for 25 years and never have had to replace a wheel bearing.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
03-29-2015, 04:48 AM | #9 | |
DIE ANTWOORD
68
Rep 640
Never use force that will charge axial pressure to the bearing balls unless you want hem to become cubically
03-29-2015, 12:24 PM | #10 |
Rep 122
Some people are saying the axle slides right into the hub.....I literally have to use a hammer and socket to get the Axle into the hub. Brand new axle brand new hub they don't just slide together like any axle I've ever swapped.
03-30-2015, 02:03 AM | #13 |
DIE ANTWOORD
68
Rep 640
I always bought used axles so I'm not sure. Maybe there's a thin layer of resin / laquer on the cogged part (for corrosion protection)
03-30-2015, 03:59 PM | #15 |
Rep 32
Yup. Knew it would be difficult, wasn't sure how difficult, thought I could get it done in one night... I had to cycle to work the next two days
My advice, if you're not 100% sure you can do it, take it to an Indy. |
03-30-2015, 04:04 PM | #16 |
Rep 122
Oh yeah with out a doubt. Put it like this the first time I did it, broke my carrier at about 28 tons getting the stock axle out! Shit by now I'm pretty quick with it this next time should be the last lol! And I'm using the proper tools for bearing and hi removal. This is not so diy friendly for those less skilled.
03-30-2015, 07:27 PM | #17 |
453
Rep 2,973
In my other post I should have said rear bearing.
I've replaced front bearings on both my previous e30 M3 and e36 M3. For sliding anything on a spindle. My mechanic told me to put them in the oven at about 200-250. Not hot enough to do any damage but will cause the race to thermally expand and slide on the spindle. Worked great on the front bearing of my e36.
