e92 door alignment
01-29-2015, 01:36 PM | #1 |
78
Rep 375
e92 door alignment
Today I noticed my driver's side door doesn't quite sit flush with the rear quarter panel. It sticks out maybe about 1 mm, it's most noticeable right where that crease is by the door handle. Is there any way I can adjust the door to fix this?
01-29-2015, 02:13 PM | #2 |
2341
Rep 3,539
Same here, both driver a passenger from day 1.
After some googling, the resolution seems to be the adjustment of the striker bar. Moving it slightly towards the interior of the car (1-2mm) will do the trick. Mine never really bothered me that much and you can only see it if the car is dirty and if I tell you where to look. Keep in mind when you start messing around with the striker bar, you may have to do some window adjusting as well (due to the wind noise which may or may not be the case). Last edited by Wolf 335; 01-29-2015 at 02:33 PM.. |
01-29-2015, 02:33 PM | #3 |
36
Rep 311
All you need to do is adjust the striker. Just slightly loosen the torx screws and move the striker inward. Make very small adjustments.
Supposedly the front of the door is tucked in a little and the rear is out slightly to reduced wind noise. |
01-29-2015, 06:44 PM | #4 |
143
Rep 451
I just did mine today following the diy in the diy section, super easy and actually reduced wind noise a bit. I haven't done the windows yet though. The doors shut with a solid thud now too.
Instagram: @dasianoak
01-30-2015, 10:21 AM | #5 |
armchair enthusiast
221
Rep 1,019
Just adjusted mine, and I'm almost mechanically inept. Simple DIY for the striker. The window adjustment, a bit more advanced.
http://www.e90post.com/forums/showth...92+window+seal Just be careful not to overtighten the striker torx, I managed to strip one with what I thought was not excessive force.
'18 340i xDrive EB/Dakota, 6-speed manual, M-sport
'02 325Cic vert AW/Montana leather, 5-speed manual, premium/removable hardtop '93 850Ci Oxford Green/Parchment, auto '71 Buick Riviera, 455 V8 land yacht |
01-30-2015, 10:53 AM | #6 |
Is it the shoes!?
3884
Rep 5,112
Be careful with the windows. The job can turn into a real pain real fast. I did this on my E46. If you loosen too much, the bolt will fall out, and you need to take apart the door to get it all back together.
01-30-2015, 09:05 PM | #7 | |
143
Rep 451
