Need to pass AZ inspection with JB4 and catless DP's
01-26-2015, 12:10 PM | #1 |
14
Rep 46
Hey everyone! Just got a notice saying my 2010 335i must go through an inspection to renew my registration. I'm currently running catless DP's (VRSF) with the JB4 G5 board. What steps do I need to take in order to pass inspection? I'd rather not revert to stock, and was hoping someone could offer advice. Thank you!
01-26-2015, 12:13 PM | #2 |
65
Rep 385
I have heard that AZ allows 1 "not ready", so as long as everything else is fine, you'll pass. I know of two people that have passed with their cats "not ready". Make sure everything else is on point. If it were me I'd just get a dpfix in and turn auto-clearing off.
2007 E90, 6MT, VRSF 7" FMIC, RR DP's, Vargas Stage 2+ (19t unclipped), CP-e Charge Pipe/Tial BOV, BMS DCI, Fuel-it! Stg 2 LPFP, E66, 118k+ miles Brentuned
01-26-2015, 12:14 PM | #3 | |
14
Rep 46
01-26-2015, 12:22 PM | #4 |
65
Rep 385
That I don't know -I have Cobb. A few guys in my local circle have JB though, which is what I was trying to re-state for you.
01-26-2015, 12:47 PM | #7 |
BimmerPost Supporting Vendor
24295
Rep 190,975
No.
The Jb4 will help auto clear the engine light but it will still show as not ready during inspection .
01-26-2015, 12:50 PM | #8 |
Joint Chiefs of Staff
4920
Rep 115,999
You need a DP fix. The JB4 only removes the code for day to day driving but does not allow the system to reach readiness. You will need to install the Dp Fix and turn the auto code clear off or better yet set JB4 to map0. Once thats done you will need to drive cycle the car for 30-100miles in varying conditions to get all the parameters to show readiness.
You are usually allowed one parameter not to be ready. Mike |
01-26-2015, 01:08 PM | #9 | |
14
Rep 46
01-26-2015, 01:27 PM | #10 |
16
Rep 219
Check your local laws before you you buy anything. Some areas allow you to have one or two not readys and still pass. Some do not. If your area allows one "not ready" code then you can simply disable the cat code with a cobb tuner or bbflash. The cats will show not ready but you'll still be able to pass (since they allow one to be not ready) and you won't have any codes since you disabled them in software. No need for the dpfix.
01-26-2015, 01:29 PM | #11 | |
4920
Rep 115,999
Mike |
01-26-2015, 01:40 PM | #12 |
533
Rep 2,872
Pickup the DP Fix from a vendor, VRSF and Wedge make them, almost every vendor sells them.
As previously stated, the JB4 only clears the code, it doesn't actually bring the O2 sensors to readiness. |
01-26-2015, 02:56 PM | #13 |
Rep 16
I am in AZ and had to pass last year with downpipes. I ran JB4 with the downpipe fix in and drove according to the readiness thread elsewhere on this forum. Passed without issue! Hope that helps
07 335-Monaco Blue 6MT FBO JB4/BMS Backend Race Flash, BMW SSK, Stg 1 LPFP, BMS OCC
01-26-2015, 02:56 PM | #14 |
3441
Rep 79,211
01-26-2015, 10:02 PM | #16 |
71
Rep 510
Haven't checked the laws here in AZ, perhaps we are allowed to pass with at least one ready signal not showing.
'2018 F87 M2 LCI | LBB | GC Camber Plates | Ohlins R&T 90/190N/mm | 18x10 et33 square 275/35 | MPe | Poly Transmission Mounts | Recaro Sportster CS
01-28-2015, 09:55 PM | #17 |
Rep 334
http://www.azdeq.gov/environ/air/vei...monitor-fs.pdf
According to this you can have 1 not ready for 2001+ cars
COBB|PTF PROTUNE|VRSF 5" IC|VRSF DP|DMS DCI|KW v2|HUPER OPTIKS|VALENTINE1|AKEBONO|ZIMMERMAN
01-29-2015, 10:15 AM | #18 | |
16
Rep 219
