01-25-2015, 01:30 AM | #1 |
15
Rep 95
Sound system question
hi everyone, I just got my 2015 435i Gran coupe, I love it expect the sound system, it is the basic 9 speaker system and it is suck!!!!!!!!!!!!
I am planing to replace the speakers with BAVSOUND and planing to get a amp. Did any one did this? Also what Amp should i choose and how can I connect it with Idrive? Waiting for your help!!!THX Last edited by joeyaoyp; 01-25-2015 at 12:26 PM.. |
01-25-2015, 03:05 PM | #5 |
Rep 24
I just installed the bavsound without replacing the stock amp to replace my hifi system and it is a noticeable difference but I wasn't really "blown away" as some others have been but it is definitely an improvement. You will immediately notice a difference in the quality of the speakers all around though and the magnets from all the stock speakers put together equal roughly 1 magnet from one of the bavsound speakers. The cones are much better quality as well and I am more than pleased with the investment. I can't really elaborate on the addition of a new amp though obviously but I can say the bavsound is going to be much cleaner sound using the stock amp in the 4 series. The install is also very straightforward and even taking the time to add additional soundproofing and tape down or fix everything with a potential to rattle the whole install took me about 2-3 hours but that also included some beer drinking
2014 428i - Glacier Silver 6mt rwd
01-25-2015, 05:49 PM | #6 | |
15
Rep 95
I was wondering to replace an amp too since it is not optical line signal. |
01-25-2015, 06:29 PM | #8 | |
Rep 24
I will say though that The bav sound mids and highs should complement an additional subwoofer very well. I saw the ghost sub that bavsound puts out but unfortunately they aren't available for the 4 series yet. I was also thinking that adding a kicker solobaric l7 (the square ones) right behind the armrest for the back seats would look pretty amazing. This is actually where bavsound actually puts there ghost subs in the available models but I think a square sub in that spot would look pretty clean. If you do end up upgrading the amp and adding subs please be sure to post about it. Also if you chose to go with focal also let us know how the install process and quality are. It would be good for future upgraders to have a good comparison and there is already quite a bit of bavsound information around.
01-25-2015, 06:42 PM | #9 | |
15
Rep 95
01-25-2015, 11:43 PM | #11 | |
568
Rep 1,035
01-26-2015, 12:05 AM | #12 |
15
Rep 95
As the bavsound web said, this speaker will work with oem amp perfectly. I do some research and found out that the oem amp(hifi) is only 200+ watts. That means either the rms power of the bavsound stage 1 or peak power will not be that much. So I just buy techinc's harness and add my own aftermarket amps. He said all the amp come with balance input will work with that harness.
01-26-2015, 12:10 AM | #14 |
15
Rep 95
http://www.crutchfield.com/p_109GTO5....html?tp=35808
this one look really good!! |
01-26-2015, 05:26 AM | #15 |
5937
Rep 3,291
That thing is huge and likely won't fit in the OEM spot, I don't think. Also, I looked at it once and wasn't clear on it if accepted balanced inputs. If you are going for a plain amp, stick with the JL 600/6 or /8 as they have been tested by tons of folk and we know they work.
01-26-2015, 11:12 AM | #16 | |
15
Rep 95
01-26-2015, 07:00 PM | #17 |
215
Rep 558
@joeyaoyp,
I needed a 23" monitor to see the pix you posted. Don't even bother to research the wiring harness yourself, someone has done it -- pay him. Technic's harness probably saved me at least 10 hours if I have to figure it out myself. I'm running a JL XD800 for the fronts, rears, & woofers. Very low level hiss that you can only hear from the tweeters if the car is parked and the windows are rolled up. Some advice, if you are going to replace/run the 8" woofers under the seats with the upgraded amp, sound dampen the thing, otherwise they will rattle out to the side skirts. You may need to dampen the side skirts too if you crank up the volume. My setup sounds very nice on the inside, but sounds like sh*t standing outside. Normally you would hear the clean bass note. My car sounds like an '87 corolla that is about to fall apart. I'm taking it apart, again - to dampen the whole thing with dynamat. Last edited by _bdiddyb_; 01-26-2015 at 11:45 PM.. |
01-26-2015, 07:26 PM | #18 | |
15
Rep 95
01-26-2015, 08:08 PM | #19 | |
568
Rep 1,035
01-26-2015, 08:49 PM | #20 |
568
Rep 1,035
hmm... i'm considering a JL XD amp ... wondering if this is a characteristic of JL amps in general or just a isolated situation you are are encountering with your particular setup?
01-26-2015, 11:17 PM | #21 | |
215
Rep 558
http://www.diymobileaudio.com/forum/...osconi-am.html Here's a side view of the woofer pod (BMW's version of a ported woofer enclosure). It's light, and definitely will vibrate with the bass notes: Here's a picture of where that port is vented: Stick your hand in the vent and feel around; you will notice there are holes that lead directly to the side skirts. I have no idea why this is -- BMW's fart vent? Here's a picture of my pod dampen from vibration: Last edited by _bdiddyb_; 01-31-2015 at 06:34 AM.. |
01-26-2015, 11:24 PM | #22 |
215
Rep 558
I'm running an AudioControl DQDX to give me band-pass for input/output 7 & 8 on the XD800 to run the woofers under the seat. This may have added to the XD800 noise floor.
