01-19-2015, 10:14 PM | #1 |
14
Rep 56
Yet another question about mirror caps
I read through the discussions about changing the stop mirror caps and watched a few videos.
I'm still not certain whether the stock caps from the factory pop off or need some "technique" to remove. Some say they pop off, some said they have screws, and a video made it look like there are clips that need to be pushed on from the inside behind the mirror. I tried a "bit of a tug" to see if they would just pop off but that didn't happen. Someone else also said it takes a substantial tug. Before I "level up" in my tugging efforts, can anyone confirm what actually needs to happen? Equipment: '14 M235i w/ folding mirrors and stock mirror caps. |
01-19-2015, 10:45 PM | #2 |
739
Rep 1,066
They pop off. Use a trim pry tool to attack the bottom edge of the cap. Once you get a lip, pull straight forward. Not up, sideways or any other direction. The force needed is the same as if you close your door, but don't close it hard enough to latch, then use your finger tips to close the door, this is the same as you want to pull with.
01-20-2015, 12:46 AM | #3 |
137
Rep 627
^ what he said.
It's A LOT easier if you pick up a plastic trim pry tool. Just make sure you wedge around and loosen it up before pulling. Definitely pull straight out or else you'd break some clips.. But even then you can always super glue them back.. Nbd |
01-21-2015, 12:47 AM | #6 |
4515
Rep 8,942
Much easier if you grab at the small corner closest to the car than the large flat portion further out. You can grip with your hand, pull hard and the cover will pop off.
You only need to pop the mirrors out for bolts if going OEM CF replacement.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
01-21-2015, 07:56 AM | #7 |
267
Rep 554
Put your pry tool here. Then get a finger or two inside for leverage. Pull straight forward to the front of the car.
The outside clip will release first. Now get a better hold and continue pulling forward. A quick forceful tug is better than slow even pressure. Also, for INSTALLATION, notice the groove (by my thumb) that runs around the outside of the mirror cap. This groove fits around the black edge of the mirror housing that is still on the car. Use this to guide your installation. I suggest you leave one oem cap IN PLACE ON THE CAR so when you reinstall the replacement cap you have a visual to make sure you get it pushed back in place properly. Notice the three large clips in right, middle and left. The other protrusions are guide pins and secondary clips. You can't touch any of them to aid removal. It's all done blindly with force. Scary, but that's how it works. Hope these pictures help everyone understand what it looks like, anyway. Good luck. .
The Stable
2015 BMW M235i | 2014 Porsche Carrera S | 2017 Porsche Macan GTS | 1996 Porsche Carrera 4S |
01-21-2015, 01:59 PM | #8 |
14
Rep 56
Great instructions! Pictures are always nice. I'm looking forward to taking a crack at it in a few days when they arrive. I'm going to see about picking up a trim tool today. It seems like a useful thing to have around anyways. Thanks all! My confidence level is now 10/10. :-)
01-21-2015, 02:12 PM | #9 | |
267
Rep 554
The Stable
01-27-2015, 07:25 PM | #10 |
14
Rep 56
UPDATE
Thanks for the help! It was an easy upgrade and worked just as you all described. I ended up using a plastic tire lever to get things started and that worked just fine. |
05-22-2015, 02:47 PM | #11 | |
Rep 14
05-22-2015, 04:59 PM | #12 |
267
Rep 554
Good luck! It's easier than you think!
The Stable
05-23-2015, 05:34 AM | #13 |
Rep 14
just got it installed, apparently it is easy lol.. you just gotta overcome your fear of breaking the mirror housing and just pry the cover out..
its an aftermarket mirror cap as well, and it doesn't fit properly, but it is un noticeable.. I got a schedule at the dealership for them to change my grills, I tried removing it earlier but there is just no way without taking off the fender.. now that, I am afraid of breaking lol |
06-06-2015, 02:51 PM | #15 |
267
Rep 554
Yea! Congrats!
The Stable
06-23-2015, 07:50 PM | #16 |
Little Deuce Coupe
391
Rep 635
Drives: SO M2C
Thanks to you guys for posting this. It does sound like every clip breaks when you pull these suckers off. I have the same Harbor Freight trim removal set which worked great. Now I have the color matched mirror covers the car deserved to start with (thanks, ska///235i).
ex: 2004 Thermonuclear Yellow RX-8|6MT
ex: 2015 Estoril Blue M235i |6MT|slicktop|MP exhaust - PCD 2020 Sunset Orange M2C|6MT|Black 788s |
