01-07-2015, 02:21 PM | #1 |
59
Rep 242
sticky brake pedel
Does anyone else notice that the brake pedal sticks up at the top if very lightly pressed on after driving for a while?
My car is in service right now and I took a long drive with service foreman in which he could "sort of feel it". To me it's more noticeable, sort of like the feeling of a magnet breaking loose. If it sticks and then I lightly press again on the pedal right away, it's silky smooth (not sticky). But after driving a short distance, I will feel that light resistance and breakaway again. I hope they can resolve this. Chris |
01-07-2015, 03:18 PM | #3 |
205
Rep 1,864
Drives: F80 M3
Garage List 2016 Porsche GT4 [0.00]
1999 Porsche Spec B ... [0.00] 2014 Ram 1500 Laram ... [0.00] 2007 Porsche GT3 RS [10.00] 2013 Tesla Model S 85 [0.00] |
Glad you mentioned this, thought it was just me. It's like a detent.
F80 M3 / Mineral Grey-Silverstone / CCB
01-07-2015, 04:04 PM | #5 |
812
Rep 7,888
01-07-2015, 06:44 PM | #6 |
59
Rep 242
Just got word back from service department that "this is normal".
The 328 loaner they gave me sure had a silky smooth brake pedal. That was the only part of the 328 that I liked more than my M3 Chris |
01-08-2015, 12:38 PM | #7 | |
59
Rep 242
Chris |
01-22-2015, 03:37 PM | #8 |
59
Rep 242
I'm starting to think this is a mechanical stickiness vs some sort of vacuum.
In the morning, when I start the car, it sticks the first time I press it in too. Anyone have any ideas? I'd really like to get rid of this annoyance. Chris |
01-22-2015, 04:56 PM | #9 |
1901
Rep 5,678
I've noticed it myself. I personally find the first 1/2" of brake pedal travel to be too soft. I suspect it was engineered this way to provide smoother application but I lick super touchy, super firm brake pedals
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery 2016 M2 | Long Beach Blue | 6MT 2015 M4 | Austin Yellow | DCT 2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3 |
04-27-2018, 04:04 PM | #10 |
59
Rep 242
Anyone have a solution for this randomly "clicky" brake pedal when pressing down on it after driving a while? Also happens in the morning every day when starting up. I can feel the pedal "click" down. IS THIS NORMAL?
I have the cover removed from the pedal area now so I can see up there and have been trying to figure out where the stickiness comes from, but it's a mystery. |
04-28-2018, 12:49 PM | #12 |
59
Rep 242
Thanks for chiming in!
Each day I crawl under the pedals and try to figure out why it's clicking in the morning before starting the car. I'm assuming this click is related to the random one that happens when driving. I've moves some parts around but it's just no apparent what could be causing this |
05-23-2018, 05:46 PM | #13 |
59
Rep 242
I don't think it's the brake lamp switch because it seems to be non-contact some sort of capacitive sensor switch.
The medium duty spring on the brake pedal mechanism doesn't seem to be causing the stickiness either. Removed it and still having the problem. Not sure what that spring even does? Rod and linkage that goes into cylinder? is loose, but no way to tighten it. Not sure if that's it, or if it's in the cylinder? |
10-12-2018, 12:22 AM | #14 |
59
Rep 242
UPDATE: I got this problem fixed. Cost me a fortune. Not so happy about that, but what a relief the random click when pressing in brake pedal is finally gone!
11-11-2018, 06:48 PM | #15 |
287
Rep 595
11-16-2018, 07:35 AM | #17 |
287
Rep 595
05-22-2020, 01:17 AM | #18 |
59
Rep 242
OK, I fixed this!
F u Crevier BMW. F u Irvine BMW. F u BMW NA. Sort of in that order. With that said... I'd been thinking this over for a very long time. I actually purchased a used brake pedal assembly to better see what's going on with the pedal linkage. (No need to remove brake pedal from car) Being at home during this Covid time, I've been working on my cars and finally decided to try something on the brake pedal I've been mulling over in my head. I pulled the trim cover off the pedal area *again* and looking at that, in combination with analyzing the eBay pedal assembly I found this: When you let off the brake pedal, the return spring pulls the rod coming thru the firewall all the way back until it stops. However, there is some slop in the linkages, so the after the rod is fully back, the return spring actually pulls the pedal back just a tiny bit more! Now if for any reason, the rod gets sticky after driving around for a while, when you I press on the brake pedal, it moves about 1/16" to take up the slop before actually pressing on the rod. That's the clicking sensation - a slight pedal movement before a click to get the rod moving. So, what I've been wanting to try, is to take up this slop. Get rid of that pre-movement and just start off up against the rod. Using the eBay assembly, I fabricated a high precision spacer. OK, no I didn't, I cut a piece of wood I had in my garage and put some felt on it for good measures. I did measure my car's pedal position with some digital calipers to find out where it was sitting when not depressed. Using that measurement, I added a little thickness to take up that "slop". Before, my F80's brake pedal will ALWAYS click very noticeably in the morning one time when starting the car cold. Always. (Subsequent presses are silky smooth) While driving, it would randomly click every 1-5 minutes or so. I was never able to figure out how to force it to click. Car has 40K miles on it now. I press fit the wood block into the brake pedal channel. First morning, no click! Test drive no click! It hasn't clicked since. In fact, brake pedal feels better than ever beyond the no clicking, not totally sure why. Here's some pics. YMMV on measurements. https://www.dropbox.com/sh/xbshwkox7...mGxwvk3ja?dl=0 Audihere Last edited by audihere; 06-24-2022 at 03:47 PM.. |
07-06-2021, 12:59 PM | #19 |
Rep 17
Hi,
I read that you solved the brake pedal problem. But don't your brake lights always come on with such a wooden block in between? I have an F30 LCI 320i with also an annoying brake pedal. Every time I don't brake for a while I feel a resistance at the beginning of the pedal. Brake shortly afterwards and all is well. After a while back the same resistance. Thanks in advance! Greetings Greg Last edited by BMW 130i Greg; 07-14-2021 at 09:13 PM.. |
07-13-2021, 02:28 PM | #20 |
59
Rep 242
Hi Greg, I just replied to your PM. Brake light switch is a simple ratcheting adjustment after the fix is in.
Yes, this COMPLETELY FIXED the sticky feeling in my M3 brake pedad that BMW could not figure out for the life of them. Looking at my post, it's been over 1 year and I have not had one single click of the brake pedal ever since fixing it! |
07-14-2021, 10:06 AM | #22 |
Rep 17
@audihere:
You are a HERO!!! I am so glad you made a topic about this. I did exactly the same as you did and NO RESISTANCE anymore!!! Maybe a whole new brake pedal will fix this too? Greg Last edited by BMW 130i Greg; 07-14-2021 at 09:13 PM.. |
