01-06-2015, 01:28 PM | #1 |
142
Rep 931
TV Retrofit BMW F30
Hello everyone
Soon I'm going to do the above retrofit on my car I need two connectors ranging respectively unity 'NBT (A42 * 3B) and unity' Video (A25 * 1B) and their "feet" to be crimped to the cable FBAS For if someone has the original codes BMW or know where I can find them
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
01-06-2015, 01:29 PM | #2 |
142
Rep 931
I need the male connector number one :
01-06-2015, 01:30 PM | #3 |
142
Rep 931
... and the male connector for the DVBT tuner
01-20-2015, 11:56 AM | #4 |
142
Rep 931
ok solved.......
01-20-2015, 04:34 PM | #5 |
142
Rep 931
Now The AH3 with original TV tuner Retrofitted
Hanzo Nagamoto17.00 |
01-22-2015, 04:30 AM | #11 |
142
Rep 931
Not easy to tell.
You need TV modul based on your country (ECE - US DTMB etc etc see REALOEM for info) CIC or NBT with video in (see my first picture of NBT or CIC, connector 1 ) FBAS cable 2 FBAS connector (12pol) Fiber Optic for join on the MOST ring of the car (the lenght depends of the car) Coding
01-22-2015, 04:32 AM | #12 | |
142
Rep 931
Retrofitted the OEM TV MODUL2 ECE
01-22-2015, 04:36 AM | #13 | |
142
Rep 931
DMB is for asian and Corea.
01-22-2015, 06:31 AM | #14 |
108
Rep 524
01-22-2015, 07:19 AM | #15 | |
142
Rep 931
it's a standard OTA european television. It's a classic TV tuner optional present on BMW car Since 90' (analog TV on the paste, digital tuner on the present after the European Switch-off)
01-22-2015, 08:06 AM | #17 | |
142
Rep 931
I think the USA don't have a great TV OTA Standard like the Europe
01-22-2015, 11:21 AM | #19 |
568
Rep 1,035
01-29-2015, 09:24 AM | #20 |
31
Rep 42
Very nice job!
Would you mind sharing the required part numbers? The TV module number is easy to find, but I have some problems finding the rest. How did you connect the antenna and MOST ring to the TV module? I could see in Rheingold that the antenna is connected to the trunk lid but I cannot find more info about the MOST ring. |
01-29-2015, 09:41 AM | #21 |
142
Rep 931
For antenna is good TWO AMPIRE AMP600 with phantom 5V.
One rear and one front for the diversity tuner FBAS 4.8Mt cable is in the realoem.com Use a F10 car in order to find all you need Most cable depends on car (CIC or NBT) You find a classic cable on EBAY with BMW connectors (Search BMW MOST Cable) This part is not present in realoem
07-22-2015, 11:52 PM | #22 |
Rep 20
hey Franz, would you please share in details what you connected from head unit to TV tuner, also what's the pinout of the connector of the TV tuner.
Did you need to modify VIN or anything in the module? Thanks |
