Jack Stand Adaptor
01-03-2015, 03:59 PM | #1 |
108
Rep 474
Does anyone sell an actual Jack stand adapter? Not the thing attached but an actual V shaped stand adapter to accommodate for the lift point
01-03-2015, 04:29 PM | #2 |
40
Rep 823
Drives: 2008 335i Coupe TIAG
01-03-2015, 04:42 PM | #3 |
1233
Rep 3,778
Drives: '11 328i '19 M6
Never seen one. But you can cut up some short pieces of 1x1 and they'll fit perfectly into the jack points and then deform under weight into the saddle of the jackstand. Been doing this for some time without any issues. Eventually the blocks will wear out but I always carry a few in the tool box.
2011 E90 328i 6MT, BMW Aero, CF hood/boot, PI+CAI+RM+3IM+BPC, SS+CI528+ThermoTec+SS#1+2XBurns, AKG 75D eng/trans, Al/Delrin diff/RS, CM 850, UCP, CAE, AKG DSSR, DiffsOnline 3.91 30/90 LSD+BW cooler, C&R, Setrab, Accusump, AST 3-way+Swift, Aurora PR+BW spherical, Vorshlag CPs, M3 brace+UR bar, ARC-8 18x8.5, 255 R1R, RB/CSL rotors+cooling, 135i calipers, RS29, RT700, Safecraft, OMP HTE-R+804F+QD Superquadro, 6pt cage+FIA, Braille, RT DL1Mk3
01-03-2015, 04:43 PM | #4 | |
108
Rep 474
01-03-2015, 04:59 PM | #5 |
1233
Rep 3,778
01-03-2015, 05:00 PM | #6 | |
108
Rep 474
01-03-2015, 06:11 PM | #7 |
1233
Rep 3,778
Pretty sure it's 2.25" but will check when I get home.
01-03-2015, 07:07 PM | #8 |
1233
Rep 3,778
Nope, I was wrong, it's 2-1/8"
01-04-2015, 05:23 AM | #9 |
17370
Rep 18,769
Why not just get the proper stands that have a flat rubber top? You are using axle stands that are meant to be placed under an (live) axle of a truck or car.
01-04-2015, 07:49 AM | #10 |
1233
Rep 3,778
Because the weight of the car will be unevenly applied to the walls of the jack points instead of to the inner surface that's bearing directly on the intended stress points of the chassis. And they'll fail, distorting the opening in the jack point due to the high pressure of all that weight on the thin edges of the plastic walls making them increasingly difficult to use. Using a block of some kind to transfer the weight of the car from the chassis jack point itself to the stand is a better solution than improper use of the walls of the plastic jack point to transfer the weight to a non-standard jackstand, ime.
01-04-2015, 07:59 AM | #11 | |
17370
Rep 18,769
01-04-2015, 08:56 AM | #12 | |
1233
Rep 3,778
A flat top jackstand will apply the load unevenly to the jack point since by definition the top of the jackstand isn't parallel to the bottom of the jack point when the car is lifted at one point rather than at all four as it is on a lift. The pad isn't soft enough to evenly distribute the load and by definition cannot eliminate the slight side loading of the walls so it's not the best solution although definitely better than a standard jackstand without a spacer of some kind. Initially I was going to get some Esco stands but the above engineering analysis told me they weren't the best solution so I use made-in-the-US Norco forklift jackstands at home (way more expensive than Esco jacktands) which have a more shallow v-shaped top but still need spacers to avoid damage to the jack points. And you can see the deformation and compression that occurs in the wood blocks due to the uneven application of load. On one you can see how a damaged rear wall on one jack point makes it impossible to get the wood block fully into the jack point and thus the end of the block gets crushed when used there. OTOH, if a flat top jackstand has enough play so its riser can tilt enough to remain flat against the jack point at least the chance of causing damage is minimal. And a typical floor jack will damage the rocker cover if not spaced off the jack point in the first place, at least my Brunnhoelzl will as will any decent floor jack that I know of anyway. The only time I need to use a rubber pad is on the lift point of my AC Hydraulics DK13HLQ when lifting on the diff body but of course never on the front center jack point. That's a recipe for a punched through oil pan... However, I wasn't talking about using a lift but about using jackstands and the point that cheap blocks of wood and a cheap jackstand will work as well or better than an Esco stand in the long run for a lot less money, which was my only point. Mainly because it's kinda difficult to carry a lift to the track I carry the Brunnhoelzl and a small Jet screw jack that sits in the middle of the Brunnhoelzl and supports the lift point from underneath for safety and with a small wood spacer to apply even pressure and avoid damage from the top of the screw jack to the aluminum jack structure. And I still use a wood block between the jack and the jack point to avoid damage to the rocker cover as well as to avoid unevenly loading the jack point walls.
01-04-2015, 09:25 AM | #13 |
146
Rep 295
DO NOT USE WOOD BLOCKS!!
I tried this in the past, had the wood unexpectedly split and the car almost fall off a jackstand. I use the above ECS adapter for my floor jack and cut hockey pucks for jack stand pads. |
01-04-2015, 09:52 AM | #14 | |
Leeeroy Jankins
31
Rep 423
No need
e90 LCI w/ -= VRSF 7" FMIC =-
-= Cobb: Stg1 +FMIC Aggressive ST =- Last Install: BMS DCI + Caliper/Drum Paint "If you're not 1st, you're last" -Ricky Bobby |
01-04-2015, 09:56 AM | #15 | |
1233
Rep 3,778
Note that it wouldn't be a good idea to use a wood block with the grain oriented vertically since it'd be weaker that way and it's likely to be smaller than the jack point leaving plenty of room to collapse, especially if it's much taller than the inside height of the jack point. A section of 1x1 even after it's compressed under load has most of its volume inside the jack point. The sections of 1x1 aren't much different in size than the rectangular section of the ECS adapter which I also decided not to buy for the simple reason that it won't deform to accommodate the uneven loading produced by a single point support. It is however better than using nothing and unevenly loading the jack point.
01-04-2015, 10:00 AM | #16 | |
1233
Rep 3,778
If the wood block is sized to fill the volume of the jack point with only a small percentage left outside after compression then there's no point of failure, it just fills up the volume of the jack point and provides a resting point on the jackstand. Admittedly using a block of wood under the jack point would be really stoopid.
01-04-2015, 10:37 AM | #17 |
146
Rep 295
I did exactly what you described and had it split. Plus if you notice from the pictures you took, you cut across the grain rather than with it. Much higher chance of splitting.
Remember you have nearly two tons of weight sitting on four points when the car is up on jack stands. Even the most subtle shift can be very unpredictable and knock a car off the stands. Wouldn't risk it but do what you want; unfortunately if it does go wrong it's a self correcting problem. I got lucky and wouldn't advise anyone do the same. |
01-04-2015, 10:57 AM | #18 |
1208
Rep 2,835
Or just buy 4 decent jack stands and do this....
http://www.e90post.com/forums/showthread.php?t=727131 |
01-04-2015, 11:10 AM | #19 | |
1233
Rep 3,778
But jackstands are never to be used except in pairs on either end of the car in conjunction with wheel chocks on both sides of the grounded tires, never with the car on four stands, that's pretty much standard safety stuff right there. Yeah, people do it all the time but it's unsafe as hell because the jackstands aren't rigidly fixed to the floor and can easily topple from the overturning moment when the car experiences sideways applied forces. Like I said before the piece of 1x1 is entirely captive within the jackpoint, in the horizontal plane. After compression the blocks are about 11/16" thick and half of its thickness is contained in the jack point. If it were to split no lateral movement can occur unless the split is entirely or close to entirely below the jack point. The car can't easily shift appreciably since this split would then have to be predominantly in the horizontal plane resulting in a mostly normal loading in the split plane. And by definition it's unlikely to split if the forces aren't appreciably in shear. Note one block is simply deformed sideways without splitting. And the top of the Norco jackstands as well as the lift point on the Brunnhoelzl are wide enough to handle it with plenty of margin as would any axle-type jackstand and floor jack. Again though, there's no significant side load from working on the car as much as there is when the car's on a single lift point which it is only long enough to adjust a camber plate and/or change a wheel, change brake pads, etc. Since I don't use more than two jackstands at a time knocking the car off of them is virtually impossible with the Norcos. It's even less likely using the Brunnhoelzl jack. I wouldn't recommend the wood blocks when using four jackstands since I would never recommend using four jackstands.
01-04-2015, 11:13 AM | #20 | |
1233
Rep 3,778
01-04-2015, 11:28 AM | #21 | |
1208
Rep 2,835
01-04-2015, 11:35 AM | #22 |
1233
Rep 3,778
Cool, that's the safe way to get the whole chassis lifted high enough to work under it. As long as the cribs are as wide or wider than their height the car's virtually impossible to tip. Even better if the cribs are attached to dollies so no overturning moment can exist between the cribs and the floor.
