12-30-2014, 06:29 AM | #1 |
Rep 57
Dashcam installation
I am considering buying a camera for the front and back windows and am looking at this brand called "BlackVue".
From what i researched, it's a korean company with good build quality reputation although a bit expensive. "DR 650GW 2CH" is the designation of the particular model i intend to buy but have not been able to get all the answers i need. Firstly, if i plug the camera into the normal cigarette lighter port in my 328i, will the camera turn off cause of the ASS function of the car? For example, i stop at a red light and the ASS function turns off my engine, will the camera keep running or just automatically turn off? Second, this "BlackVue Car Black-Box Power Magic Pro", is described as follows "Power magic is a device that supplies power to BlackVue from the car's battery according to the configured voltage or configured timer to prevent the vehicle battery from being discharged." Specifications Rated Output Voltage 12-24V DC Output current Rated current 1A, max 2A Output voltage cut-off 11.6~11.8V (±0.05V) 22.8~23.2V (±0.1V) on the basis of the input Output voltage restoration 11.7~11.9V (±0.05V) 22.9~23.3V (±0.1V) on the basis of the input Output Voltage Cutoff Timer 1 ~ 72 hrs PRODUCT features · Multi-booting · Prevention to discharge Vehicle Battery · Prevention to Reboot Black box/Navigation · Configuring the Voltage to Cut-off the Power · Configuring the Timer to Cut-off the Power · Timer setting : 6hrs ~ Infinity · Semi-permanent fuse usage · Cigar jack connection socket · For 12-24V Will it cause any problems if i use this "power magic pro" to directly connect my car's battery? How difficult is it to DIY? Or just stick to using the lighter port? Hope someone with experience using these devices can provide their input Thank you |
12-30-2014, 07:04 AM | #2 |
352
Rep 1,772
Due to complexity of the electrics if you want to connect magic pro then direct connection to battery is recommended. Difficulty is getting the wiring all the way from battery in back to camera in front.
I use the power supply which is underneath the dash in the passenger side. Works fine, just won't be able to use magi pro that's all. Will shut down approx 15 mins after turning off car. Ass will not affect the camera. |
12-30-2014, 08:51 AM | #4 |
32
Rep 144
12-30-2014, 09:40 AM | #5 |
Rep 57
omg i didn't know that, thanks so much!
so if i leave it plugged in after i turn off the car and come back the next day, the battery will still be ok right? it won't be drained? |
12-30-2014, 10:30 PM | #7 |
Rep 21
so i have a 2014 335i and wired the DR550GW-2CH in myself. i use power magic pro and left the default settings (6hrs or 12v) and had no issues so far. the power magic pro is wired between the wireless module and the fusebox in the trunk/boot, and all wires that come with the device are long enough to reach everything you need. i'll post pics of my install tomorrow if you'd like.
12-31-2014, 08:02 AM | #9 |
126
Rep 1,893
I also have the drg550-2ch with power magic. ran the wires along headliner, into the trunk and to the fuse box. Used fuse 162 for the live wire.
12-31-2014, 08:44 AM | #10 | |
Rep 20
Please if you can post the installation pics. I am thinking of installing but i am not about the wires? Thanks in advance |
12-31-2014, 02:59 PM | #11 |
Rep 21
here you go:
the dashcam behind rearview mirror driver's side onto the battery for the BATT source for power magic pro power magic pro and fusebox rear camera passenger side by high mount tail light |
12-31-2014, 03:20 PM | #12 |
2006 TIME Person Of The Year
9720
Rep 6,445
Nooooooooooooooooooo!
Just tapped power off the battery without a fuse?
12-31-2014, 03:21 PM | #13 | |
14
Rep 38
I have just bought one a Blackvue DR600 which I plan just plugging into the plug underneath the glove box for now but I would like a more permanent always on solution.
Are there are drawbacks to connecting the Power Magic straight to the battery in the boot? aside from running the cable back there, I'm concerned about voiding my warranty as the car is only a week old. Quote:
12-31-2014, 05:53 PM | #14 |
Rep 21
glennqnyc, it is fused, it's mounted behind the fusebox before the power is brought into the power magic pro. i'm an engineer, everything is fused
12-31-2014, 07:01 PM | #16 | ||
352
Rep 1,772
I had the Blackvue and Magic pro installed in my previous 135i. Much easier than the F30. As well as fuse box being in front I could tap the fuse directly ie there was one which was always on and another which is switched. The f30 fuse box is in the back and I don't know if there is a fuse which is always on. Besides I couldn't be bothered running cables all the way to the trunk and so just used the power supply under the glove box. However, when you turn off the car the power to this cigarette lighter will cut after 15 mins |
12-31-2014, 07:34 PM | #17 |
Rep 21
the existing fuse tap should be switched/acc 12v, and the other should go directly to the battery (using a fuse inbetween) for your constant 12v. when the power magic pro sees the ACC 12v go away, it pulls from the auctioneered constant 12v until it detects =<12v or has exceeded 6hours (defaults)
12-31-2014, 08:04 PM | #18 | |
300
Rep 3,969
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
12-31-2014, 10:02 PM | #19 | |
Rep 21
yeah, that's fine. 2ft doesn't make a difference vs 1ft IMHO. if the OP wants to keep to 1ft, that's up to him/her, but i personally don't care |
01-01-2015, 06:35 AM | #20 | |
352
Rep 1,772
Ie a healthy battery is actually > 12.3/4 volts If allowed to fall below 12v then the battery has actually reached <20% state of charge which is not good! |
01-01-2015, 12:52 PM | #22 | |
Rep 21
http://www.blackvue.co.kr/common/img....02_121008.jpg |
