Cornering Light replacement
12-27-2014, 08:49 PM | #1 |
Rep 87
Anyone have a DIY on how to change out the cornering lights for an E90 335 LCI? I found some for an E92 but seems different from the E90.
E92s seem pretty pretty easy to swap out so hoping it's just as easy for the E90. Bulb size would help too thanks!
2011 E90 335xi BSM
12-27-2014, 11:00 PM | #2 |
Pura Vida
13
Rep 297
If its anything like swapping the DRL/HighBeam bulbs (H in the pre-lci headlight, its a PITA. I bookmarked this thread with a list of bulbs:
http://www.e90post.com/forums/showthread.php?t=46758 Once again, not sure of the difference in PreLCI and LCI bulbs so if that's no good you could try the Sylvania website. Good luck tho! |
12-29-2014, 03:31 PM | #4 |
Rep 106
Drives: E90 06 320D
If its like the Pre-LCI, bulb size is dependent on the car, mtech or standard ( Standard uses h11, mtech is 9006 or 9004, not sure on this)
On mine (Pre-LCI) I only need to remove the bolts under the fender, after that I can bend the plastic away and reach in with a hand. |
12-29-2014, 05:46 PM | #5 | |
Rep 87
2011 E90 335xi BSM
12-30-2014, 04:14 AM | #6 | |
Rep 106
Drives: E90 06 320D
My car uses h7 in those lights, but it`s also only used for high beam. Didn`t find it to hard to change them |
