2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Cosmetic and Lighting Modifications How in the hell do you replace the front side markers?!?
      12-24-2014, 05:16 PM   #1
M235eye
Enthusiast/Former CA
M235eye's Avatar
17
Drives: 14 M235i
I already read the ind install guide but can't seem to take the markers out in the first place. They are tight! Anyone have any advice for a man with average Grip strength? I asked my bro with bigger hands and even he couldn't get it out.
      12-24-2014, 05:17 PM   #2
BMWKLR
BMWKLR's Avatar
143
Drives: white m235 cp RED w/gray pop
hair dryer and old credit card did it for me. Its not just going to pop out, you gotta work it.
      12-24-2014, 05:36 PM   #3
nzw212
Drives: M235XI, Maserati, Ducati
There are a few bolts inside the fender which can be unscrewed and your hand can fit in between the plastic liner and the bumper. I don't recall the exact details but there is definitely a DYI on the forum. It's pretty simple.
Good luck.
      12-24-2014, 05:37 PM   #4
nzw212
By inside the fender, I meant in the wheel well, in front of the wheel/tire. Essentially behind the lens you're removing.
      01-06-2015, 06:40 PM   #5
benes136
Drives: 2014 M235i Estoril Blue
I used needle nose pliers to squeeze the top clip and then used them to push and just force the bottom clip out if your still having trouble. Broke the clip on the reflector though...
      01-06-2015, 06:44 PM   #6
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
http://www.2addicts.com/forums/showt...ange+reflector
just remove 3 or 4 of the screws so you can fit your hand and then push and squeeze the top clip out... then just pull from the reflector and the bottom will come off
      01-22-2015, 08:52 PM   #7
MrBallooKnot
14
Drives: Like I Stole It
If you crank the wheel all the way to the inside it will be easier to do your business in there. I still had a hard time with the inside clips and broke at least one clip on reflector. No damage to the car though.
      01-22-2015, 10:43 PM   #8
configt
configt's Avatar
150
Drives: 2015 EB M235i
My index finger still hurts a bit from doing mine earlier this week. You have to put a TON of pressure inwards on those clips to get them out. I actually ended up forcing one out a bit as I lost my patience and it bent the clips a bit. I didn't care since I won't ever be using them again.
Then I moved on to the door handle key lock cylinder delete. Tried that for hours and eventually gave up and sent the item back to iND.
2addicts
