GetBMWParts
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Suspension | Brakes | Chassis
      12-23-2014, 06:55 PM   #1
purdyawesome
purdyawesome's Avatar
26
Drives: 2015 F80 M3, 2014 F15 X5
Don't need fancy coilovers. Don't want the back end any lower at all. Want to drop the front end just a little bit- like 1/2"-5/8". Want to close the wheel gap very subtly while minimizing any affect on the stock suspension ride quality and performance handling. Doesn't seem like there is a solution at this time- but do you guys think there will be? If Eibach designed the OEM springs, couldn't they just immediately offer a front-end solution with nearly identical spring rates to the stock setup? I know the sleeve kits are decent- but they are expensive for what I want and like I said, I don't want to touch the rear end. Long story short- I want OEM or equivalent springs for the front end only. Was anything like this offered on the e92?
      12-24-2014, 05:21 AM   #2
Bob MG
Moderating
Bob MG's Avatar
United Arab Emirates
418
Drives: like a muppet
Doesn't exist. Try height adjustable springs from KW
Actually the best ride heights for balance on these cars appears that fronts are higher than the rears as far as wheel arch gap is concerned.
Lowering the front only causes geometry changes that affect cornering under braking performance and traction on the rear end. Read the other KW threads for more details.
      12-24-2014, 12:15 PM   #3
edwinm3
edwinm3's Avatar
980
Drives: F82
OP doing what you're asking is completely throwing off the suspension and taking away from what makes these M cars so great, their handling, there are a lot of threads on suspension upgrades, balance, etc.
Not really sure where you got that Eibach makes the springs on our cars, I'm assuming that from the early pics showing the prototype M with eibach springs on, that was never confirmed though. BMW could've easily used different set ups at that time during testing.
Grigio Telesto M4, 6MT.
Coyote 5.0 F-150
991 GT3
      12-24-2014, 12:39 PM   #4
MasterC17
329
Drives: 2015 BMW M3
$65k+ car, and the sleeve kit is expensive? Huh? Do it right or don't do it at all...
2009 X5d | 2007 E90 Track | 2002 M3 Track | 1991 535i Track
      12-24-2014, 12:53 PM   #5
purdyawesome
26
Yes. $1800 for the sleeve kit (installed and aligned) is imo expensive for what I'm trying to achieve. I want a 1/2" drop in the front. That's it. I don't need adjustability. If I have to do all four corners I could get a spring kit for a third of the price.
      12-24-2014, 01:18 PM   #6
purdyawesome
26
Thanks. That helps. Think I'll just keep her stock for the time being. With all the mods we do to the engine, exhaust, etc it's hard to imagine a half inch with an oem spring-rate causing this much fuss. I mean, I have 12mm spacers on the car and notice zero changes. They've gotta have an affect on handling as well, no?
      12-24-2014, 01:25 PM   #7
purdyawesome
26
I get that the geometry would change. I'm no engineer, but I'd be surprised tho if it, "totally threw it off"... Are you in the "don't touch the stock suspension" camp? Because I can't imagine other solutions guys are using wouldn't have an equal or greater impact on the stock setup. I'm talking equal spring rate, super small drop. The HR kits are way more aggressive, as are the coilovers (admittedly ignoring the ability to properly setup the KW systems).
      12-24-2014, 01:41 PM   #8
Black Gold
592
Drives: M3
Sleeve kit = doing it right?
If by doing it right you mean ruining the handling and balance of your car, sure.
      12-24-2014, 02:33 PM   #9
MasterC17
329
Drives: 2015 BMW M3
I'm not saying the HAS kit is ideal, but it's better than leaving the stock rear coil spring and throwing some random springs on the front purely for aesthetic purposes. And if set up properly, I don't think the HAS kit "ruins the handling and balance of the car", not saying it would improve it either though.
OP I think you should just buy a set of H&R or equivalent springs for what you are trying to accomplish.
      12-24-2014, 02:37 PM   #10
Freshprinceofhp
Freshprinceofhp's Avatar
36
Drives: 2015 Alpine White F82 M4
You can always do this...
      12-24-2014, 02:39 PM   #11
Freshprinceofhp
36
lol just kidding don't ever do this!
      12-24-2014, 02:46 PM   #12
MasterC17
329
Drives: 2015 BMW M3
Please, no one ever do this haha
      12-24-2014, 06:36 PM   #13
edwinm3
edwinm3's Avatar
980
Drives: F82
If the "Are you in the "don't touch the stock suspension" camp" was directed to me then no I'm not because I always go with coilovers but I have my cars corner balanced. Big difference there. At the end of the day it is your car and you'll do what you want but to do one set of springs in the front and another in the rear is just wrong and yes I would prefer stock suspension over that any day.
Coyote 5.0 F-150
991 GT3
      12-24-2014, 10:48 PM   #14
M4LAKA
114
Drives: 2022 M5 Comp
Too late :-(
      12-25-2014, 02:00 PM   #15
Tonymiabmw
Tonymiabmw's Avatar
552
Drives: Nardo F90 M5 on order
you really did?
      12-25-2014, 03:14 PM   #16
M4LAKA
114
lol, nope. KW HAS just arrived yesterday, installing it this weekend.
Currently:
2022 M4 Comp xDrive
2022 M5 Comp
Past:
2019 M5 Comp
2015 M4
      12-26-2014, 10:03 AM   #17
hellrotm
4143
Drives: F80
Someone is charging you $1000 for install/alignment? Ouch
      12-30-2014, 09:57 AM   #18
purdyawesome
26
$500 install
$960 sleeve kit after tax
$250 alignment
$1710. Guess I was a little high.
Still pricey for what I want. Gonna leave it stock for now and wait for Eibach springs.
      12-30-2014, 01:30 PM   #19
CSanto
636
Drives: 2015 BSM/SO M3
Eibach's spring kit supposedly drops the rear .2" and the front .8"
If that's not sufficient wait for coilovers that are made specifically for the F80.
      12-30-2014, 04:25 PM   #20
LIYMBM3
LIYMBM3's Avatar
Drives: '15 YMB M3
Any word on when the Eibach's is supposed to be released? I'm getting impatient here, gotta close the gap!
      12-31-2014, 08:05 AM   #21
jzmundy
jzmundy's Avatar
991
Drives: F97
$500 install
$250 alignment
Wow.
Then - E53, E85, E92, E82, F15, F80, G01
Now - F97, Macan S
      12-31-2014, 08:45 AM   #22
purdyawesome
26
$500 install
$250 alignment
Wow.
4 wheel alignment done by a guy that charges a premium because he can.... It's about $100 more than some other guys...
f80post
