12-18-2014, 06:05 AM | #1 |
56
Rep 198
No Ceramic Brake option??
Went to the builder to configure an X5M and don't see a ceramic brake option? WTF!!!!!!
Any information out there if they will be available? |
12-18-2014, 06:40 AM | #2 |
83
Rep 346
Well E70 didn't have them either, did it? I think BMW understands that X5M is not a car you're going to track - and that is the only reason why someone might actually need CCBs installed. And if it's pure show off mode, then you can always shop non-OEM CCBs for pretty much anything, i.e. Brembo.
01-04-2015, 10:09 AM | #5 | |
83
Rep 377
LE: anything can be fitted if wanted. From what i see in pics, X6M/X5M have the same brakes as M5/M6. But for sure the caliper carriers are different, due to different hubs (how cool would it be that F16/F15 have the same hubs as F10/F13?). Found M6/M5 CCBs on ebay.de at 6800EUR. A good shop can make new rotor bells and caliper carriers in order to make them fit to X6M/X5M. But after this comes the problem of brake/ABS pump. On realoem.com at M6 Brake section, you have CCB retrofit kit for 15k $ which also includes a different ABS pump. |
