12-04-2014, 11:56 AM | #1 |
281
Rep 473
Downpipe DIY?
Has anyone attempted to DIY downpipes on the F8X yet? I've done a ton of N54 downpipe installations, was wondering if it would be a similar process for S55?
Thanks in advance! |
01-20-2015, 08:51 AM | #5 |
408
Rep 2,171
Akrapovic has a fairly comprehensive install posted on their site. I plan to do it myself when I get them. But I do have a lift in my garage which makes jobs like this easier.
01-20-2015, 09:14 AM | #6 | |
Gone Fishin’
7316
Rep 12,125
Akra is the only one with flex pipe. Wonder if its worth the extra $$. |
01-20-2015, 10:01 AM | #7 | |
408
Rep 2,171
that's why I decided to go with Akra. They always make a very well engineered product - perhaps over engineered but I'll have peace of mind knowing my downpipe connections to the turbos aren't under unnecessary stress. |
01-20-2015, 10:04 AM | #8 |
346
Rep 1,656
Eisenmann has flex and for sure Zima does as well. I didn't go with Zima version 1 because the diameter gets small although I don't think it makes much difference. Their version 2 are almost done and will have flex of course. Oh yea much more cheaper cost than Akra or Eisenmann of course.
01-20-2015, 10:07 AM | #9 | |
Gone Fishin’
7316
Rep 12,125
01-20-2015, 10:07 AM | #10 | |
408
Rep 2,171
01-20-2015, 10:35 AM | #11 |
346
Rep 1,656
Zima version 1 ----- http://f80.bimmerpost.com/forums/sho....php?t=1036265
If I recall they were around $1000 Their version 2 doesn't taper down so much and are going to be priced the same. version 2 |
01-28-2015, 09:14 AM | #12 |
2093
Rep 43,350
Those are expansion bellows in the OEM exhaust, it's not a flex section. It's in place because of the added heat from the OEM cats. The restriction from the cat traps heat which is why they are generally recommended for catted downpipes. A stainless steel pipe will actually flex quite a bit without the expansion joint and the expansion joint is actually in place to preserve the seal on the catback connection (hence its location).
We've sold thousands of downpipes for various different turbocharged platforms and have never had a turbo or a downpipe fail due to a lack of expansion joint. You actually increase the risk of failure of a part when you start adding components. Any long time mechanic can confirm that most exhaust failures happen at the flex section or the cat. As far as the install goes, it's pretty straight forward and there's definitely more clearance than the N54. You don't have to unbolt the steering rack and the v-bands are more accessible. The only major difference is the catback has to be removed/lowered/pushed aside in order to remove/install the new pipes. The E90/E92 catbacks would move back without having to unbolt the entire assembly but the F80/F82 is bolted up pretty tight. |
01-28-2015, 09:57 AM | #13 | |
Gone Fishin’
7316
Rep 12,125
01-28-2015, 11:08 AM | #15 | |
262
Rep 658
2015 Alpine white M4\black leather, carbon fiber trim,manual,exec package, 19 inch black rims, M suspension, HK stereo, LED lighting
01-30-2015, 04:04 AM | #16 | |
43
Rep 1,147
You be the judge. |
