12-03-2014, 09:03 AM | #1 |
F31 330d M Performanced up.
109
Rep 464
Why can't I fit a tow bar with 20" wheels?
According to BMW fitting a tow bar isn't allowed on F31 and F33 models when 20" wheels are fitted. One would assume the wheels meet the same requirements regardless of size.
I only want to fit a bike rack for two bikes |
12-03-2014, 09:27 AM | #3 |
155
Rep 1,224
Could it be the assumption of carrying load which usually adds a load to the rear of the car (Suspension) causing the car to sit lower and scraping against those rather large wheels with less room to play?
12-03-2014, 09:28 AM | #4 |
165
Rep 942
If its only for a bike rack then I wouldn't worry anyway.
Which towbar are you going for? They aren't tricky to fit yourself.
2016 F80 M3
12-03-2014, 09:31 AM | #5 |
1402
Rep 8,092
No it's not that - 16" wheels & tyres have exactly the same overall diameter as 20" wheels because the 20" wheels have an extremely low profile and 16" have tall sidewalls, but the overall is exactly the same (otherwise speedo etc would be compromised)
The issue is that the suspension is a combination of the spring and the tyre - on 20" wheels the tyre provides little, if any, compliance and therefore all the work, combined with heavy wheels, is done by the springs. Add the nose weight of a trailer and you're over the limit.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
12-03-2014, 09:32 AM | #6 |
8571
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
It's because the 405m wheels are not rated for the rest axle load that could occur when towing.
It's nothing to do with size of overall wheel and tyre as this unchanged whatever wheels you have, assuming you've got the correct tyres on!
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
12-03-2014, 09:37 AM | #7 | |
310
Rep 1,314
Weights shown here http://felgenkatalog.auto-treff.com/ |
12-03-2014, 09:40 AM | #8 |
1402
Rep 8,092
Ok not the weight then but the compliance of the whole package.
Ian
12-03-2014, 09:45 AM | #9 |
8571
Rep 19,982
I'm pretty sure it's not 20inch wheels per se but the 405M and 664M wheels.
Tyre compliance is equally crap across all the runflats!
12-03-2014, 09:46 AM | #10 |
109
Rep 464
I have a Thule bike rack from my previous E90 which had a detachable tow bar, I had planned just to shove it in the boot but the car is too nice to shove a filthy MTB in the back.
Was just looking into at this stage. Will never fit anything more than a bike rack. I thought all BMW wheels would have had to have the same TUV approval but I take it that's not the case. I almost specced the factory Towbar when ordering the car but it's was a pricey option. |
12-03-2014, 09:48 AM | #11 |
109
Rep 464
12-03-2014, 09:50 AM | #12 | |
8571
Rep 19,982
12-03-2014, 09:50 AM | #13 |
165
Rep 942
I've only fitted mine for the same reason - http://f30.bimmerpost.com/forums/sho....php?t=1037668
2016 F80 M3
12-03-2014, 10:07 AM | #16 |
The artist formerly known as AC Schnitzer UK
3610
Rep 4,518
So yes then, according to BMW: http://www.bmw.co.uk/en_GB/topics/ow...ryId=8612.html
Although the alloy in a forged wheel is formed under pressure, unlike a regular cast wheel, and this makes the alloy itself "stronger" it is often the case that forged wheels are then machined to be lighter, with slimmer spokes etc. This is partly to get a reduction in gyroscopic effect and inertia which can result in quicker steering and improved acceleration but is also sometimes just to achieve a slimmer design. Unfortunately this also means that the resulting slimline wheel can end up with a lower load rating (in kg) than a regular cast wheel. |
12-03-2014, 10:37 AM | #17 |
6659
Rep 15,858
Excluding the bike rake application in this topic, I think we all know we can spec' up a car and build in fragility.
BMW have had enough trouble with wheels over the past few years. Putting limits on application makes a lot of sense, to protect themselves from warranty issues, if nothing else. HighlandPete |
12-03-2014, 11:00 AM | #18 | |
109
Rep 464
