Strut/Wheel Clearance - KW Street Comfort vs Stock?
12-02-2014, 01:13 PM | #1 |
30
Rep 685
Hello all. I am looking at lowering my car. I have an e92 335i with stock sport suspension. I am running 20x9 up front, and 20x10.5 rear +5mm spacer as it rubbed a tiny bit during compression. Offsets not shared by company, so I don't know what they are.
My question is this: Will KW Street Comfort coilovers need more or less strut clearance than stock? Rear ride height is okay, but front is too much for me right now. I want to lower it and maintain stock like ride quality. As a side note, I just ordered an m3 control arm kit for the front and m3 guide rod kit for rear. THey needed replaced, so I figured I would upgrade. Don't know how much this will change things. (Front doesn't I know for sure.) Thanks! Some pics as it sits currently for reference: #1 #2 |
12-03-2014, 01:48 PM | #5 |
164
Rep 2,556
KW strut tubes are the same diameter as oem, but if you lower the front the KW adjustable spring perch may rub the inside of your front tires. My KW spring perch is positioned just above the front tires but my front isn't super low and my tires are 235/40-18.
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
12-04-2014, 12:01 PM | #7 |
30
Rep 685
Thanks guys. I have about 8mm clearance from the stock strut tune up front. Just trying to avoid causing a bunch of issues while attempting to improve the stance.
12-06-2014, 12:11 PM | #8 |
102
Rep 1,903
Drives: e92 335i 6MT
It all depends on what your front wheel offset is. If its et31 or less, you should be OK. Otherwise you might need a 5mm spacer.
FYI. I have 245/35R19 tires on 8.5" et35 rims with KW S/C with no issues. |
