BMW X3 Forum
BMW X3 Forum
      11-26-2014, 06:59 AM   #1
Sireal
Sireal's Avatar
Drives: 2014 X3 xDrive35i
Fuel Injection Cleaning for 2014 X3 xDrive35i
My dealer service center is recommending Fuel Injector cleaning at 30,000 miles. Is this service worth doing or just a rip-off at $179?
2014 X3 xDrive35i, Black Sapphire; 2008 Z4 3.0si Roadster, Space Gray, 2005 F-150 Lariat, Crewcab, 5.4 Triton, Burgandy
      11-26-2014, 09:10 AM   #2
The X Men
99
Drives: 2013 X3 35i
Unless your engine is misfiring or running rough, you do not need it. You can buy a bottle of Techron fuel injector cleaner from your local automotive store and do it yourself.
      11-26-2014, 10:43 PM   #3
bimmeupscotty
Drives: 2015 X3 xDrive 28i
you did 30k miles in one year ? :O
      11-27-2014, 01:23 PM   #4
RhoXS
16
Drives: 2002 Z3 3.0i + 2016 X3 28i
Clear rip off IMO.
I understand the minimally federally mandated detergent package in all gasoline will be sufficient to keep everything including the injectors and valve surfaces clean. I never did anything to specifically clean my injectors in any car and never perceived a problem.
I am sure services like cleaning the injectors for $179 is a very high profit item for the dealership and they train and encourage their service writers to push these services. A number of years ago we had a Lexus RX300 with a full extended Lexus warranty to 100K miles. At about 65K miles we had the car at Lexus for a warranty repair and the service writer attempted to sell a $1,200 timing belt and water pump replacement to my wife even though Toyota did not require a replacement for another 20K miles or so. Fortunately she smelled a rat and called me. IMO your dealer's injector cleaning is a similar scam.
I am in NY also so curious who the dealership is.
      11-27-2014, 09:54 PM   #5
Sireal
Sireal's Avatar
Thanks for the input. BTW- HV BMW near poughkeepsie
      12-01-2014, 02:21 AM   #6
Envyscorpio
Envyscorpio's Avatar
Taiwan
18
Drives: BMW
2001 Honda NSX  [0.00]
2009 BMW M3  [0.00]
2004 BMW M3  [0.00]
Fill up with Techron every once in a while and you're good to go. Avoid driving for short trip from the morning start. And turn off them damn auto on/off while the engine's cold.
179 buys you a lot of chevron gas
[E30 325i | E39 528i | E46 M3 | E70 X5 | E90 M3 | F25 X3 | NA1.5 NSX | 718 GT4]
      12-01-2014, 03:18 AM   #7
Bimar
Bimar's Avatar
802
Drives: Bmw X
outside cold season, isn't the car designed to self regulate, sometimes i notice it doesn't go into start stop mode.
      12-01-2014, 06:55 AM   #8
Envyscorpio
Taiwan
18
Drives: BMW
2009 BMW M3  [0.00]
2004 BMW M3  [0.00]
Hum... maybe. I usually don't get cold mornings in SoCal
But always a good idea to get enough heat into the oil to get rid of water content.
      12-01-2014, 08:38 AM   #9
n55x3
72
Drives: n55 BMWs
Depends on what the cleaning entails. Traditional cleaning by way of just running detergents through is surely a waste. Same with you purchasing aftermarket detergents. You might get more satisfaction dropping cash on a crowded floor at your nearest mall. However with the introduction of direct injection motors you don't have the benefit of gas and detergents running across the top of your valves and in turn keeping them clean. Carbon build up is a reality with these new DI motors.
Google BMW Direct Injection Carbon Builup for more details.
If the injection service entails visually inspecting your valves and confirm carbon build up and then addressing with some type of blasting medium ie walnut shells, then this is a decent deal. However, you often won't get to the bad carbon build up point until later in life, like 60k miles or later.
      12-01-2014, 08:50 AM   #10
drodnyc
drodnyc's Avatar
20
Drives: 2019 BMW X7
wouldn't this be covered under their 4 years/50k free maintenance?
none of the BMWs i have owned in the past required any out of pocket expenses for maintenance. I either extend the maintenance or I trade it in right before it expires. I follow all of their recommended service visits and they cover whatever comes up.
2019 BMW X7 M-sport
2017 Harley Street Glide Special
2018 Triumph Bobber Black
      12-01-2014, 05:59 PM   #11
Roundown
576
Drives: BMW
This.
      12-02-2014, 07:45 AM   #12
The X Men
99
Drives: 2013 X3 35i
For $179, they are not talking about walnut blasting, that would run into the thousands.
      12-02-2014, 03:21 PM   #13
woodchuck1
16
Drives: 2013 X3 X-drive 35i
At a BMW dealer, that might just be the price for a bottle of Techron.
      03-09-2019, 12:10 PM   #14
malicem3
39
Drives: 2022 X3
Bumping because we have a bad injector. I'll report back with what we do.
      03-11-2019, 11:49 AM   #15
doru
doru's Avatar
126
Drives: e92, f25, e46, e83
Actually BMW issued a statement or bulletin a few years ago concerning cleaning of fuel system - it started with the N54 engine, when they had a bunch of failed HPFP.
To make it kosher, they took the Chevron fuel system cleaner and and bottled it in a similar bottle as the Chevron, only it was grey/silver in color and re-labeled BMW fuel system cleaner, and in small letters on the back it was marked Chevron made for BMW. I assume it's the same product. Also, there was a recommended mileage interval, can't recall from the top of my head. Shell V-power has the stuff incorporated in the gasoline they sell.
I used the Techron & also the BMW product. Both had same result. On normally aspirated engines, one can feel the change, but it takes almost a tank to visualize (you see the fuel consumption improvement). The change is slow, so you can't tell, but change for better it is. One way is to record the engine sound before, then when the tank is almost empty another sound recording. You will notice.
On the turbo engines, it will clean the fuel system, but i will do squat to clean the valves. The fuel is not sprayed behind the valves, so carbon buildup is guaranteed, less on N55 compared to N54.
Walnut blasting on N54 if done professional by a shop is in the 400 bux range, money well spent. If you know what you're doing, one can do it at home, but you need to buy some tools and the media. Again careful, because you can plug up solid the engine if not 100% sure where TDC is - you have to turn the engine for every cylinder you service, and it has to be closed.
Stable:
e92is
f25 N52
e83 N52
e46ci M54B25 (e53 N62 - sold, R.I.P. e39 M54B30)
      03-12-2019, 10:19 AM   #16
malicem3
39
Drives: 2022 X3
Good news everyone, it was NOT the injector. Simply a bad spark plug!
      03-12-2019, 10:52 AM   #17
doru
doru's Avatar
126
Great news.
But keep in mind that the sparkplugs have to be changed at around 60k miles on the newer na engines and around 30-40k miles on the boosted ones. Worn plugs will damage the coils which is more expen$ive. BMW might tell you otherwise - maybe a longer interval, but not 100% sure.
Stable:
e92is
f25 N52
e83 N52
xbimmers
