11-24-2014, 09:07 AM | #1 |
Rep 13
Bluetooth question
Want to be sure that I 100% understand correctly from reading through other threads before I deal on a car soon.
WITHOUT the tech package, it is IMPOSSIBLE to use bluetooth music from a smartphone. You can only make voice calls. I sat in a 228i NON TECH and saw bluetooth functions in the menu, but not sure if that was just for phone or I can stream from itunes through the speakers. Please let me know. not sure if different between 2014 and 2015 and 228 v 235. |
11-24-2014, 09:31 AM | #2 |
4516
Rep 8,942
Non tech calls only. Can either code for music or add an aftermarket Bluetooth receiver in armrest for $10 or so.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
11-24-2014, 10:21 AM | #3 |
Rep 13
11-24-2014, 10:25 AM | #4 |
What goes here?
452
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
It can be coded in.
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
11-24-2014, 10:45 AM | #5 |
Rep 73
11-24-2014, 11:51 AM | #7 |
95
Rep 809
Drives: 2014 228i Msport
I thought that feature was now standard on the 2015s ?
A peasant and proud of it
Save The Manuals!!! |
11-24-2014, 12:44 PM | #8 | |
4516
Rep 8,942
2022 Macan S
11-24-2014, 03:53 PM | #9 |
12
Rep 59
I didn't purchase it separately, and I don't have NAV. The car came with Bluetooth. The "Enhanced Bluetooth" option, which I didn't get, adds the ability to pair two phones, and other features I don't need. http://www.2addicts.com/forums/showthread.php?t=999781
11-24-2014, 05:06 PM | #10 | |
Rep 73
11-24-2014, 10:48 PM | #11 |
Rep 13
I understand the bluetooth still works without nav, but getting mixed signals from these responses. Can you stream Pandora and iTunes music via Bluetooth without the tech package or can you only use phone call functionalities
11-25-2014, 03:01 PM | #12 | |
13
Rep 60
11-25-2014, 03:17 PM | #13 | |
Rep 73
But that would explain why my streaming wouldn't work when hers was shut off. Thanks for the info, I'll have to try this regardless to test the theory but this explains a lot. |
11-25-2014, 03:18 PM | #14 |
Rep 73
I believe that answer is a "YES" you can stream without the Enhanced BT USB option. Standard on MY 2015's I believe.
11-25-2014, 08:34 PM | #15 |
27
Rep 111
just to ring in here. i just drove the 2015 model with no enhanced BT, no tech, no nav.. i was able to stream music via BT just fine on android using google play music. gps directions came through also as did calls. so i'm pretty sure its safe to say its standard.
11-27-2014, 07:10 AM | #16 |
Rep 10
I have the 2015 228i, no tech package and no Bluetooth integration and I can stream music via Bluetooth from my iPhone. I was actually surprised since I wasn't expecting this functionality. Just make sure you turn up the volume on your phone because otherwise the audio from the car will be really low
11-27-2014, 08:46 AM | #17 |
103
Rep 1,254
Check out this thread. you may be able to just code the EBT if the hardware exists in your car.
http://f30.bimmerpost.com/forums/sho...d.php?t=928616
11-27-2014, 10:13 AM | #18 | |
44
Rep 119
