Recommended Offsets
01-08-2008, 01:56 PM | #1 |
Rep 123
Recommended Offsets
I need some help for my E92. I am thinking about getting the Works VS-XX with the option of the following...
19 X 8.5 19 X 10 option 1 235 X 35 265 X 35 OR option 2 245 X 35 285 X 25 Since these rims are custom, what offset is recommended?? Should I go option 1 or 2? My car is not dropped on anything now and I plan to go with Falken FK452 tires. |
01-08-2008, 04:21 PM | #5 |
517
Rep 3,612
I run 9.5 rears with 265/30 tires, and a et27 offset would work on my car without rubbing. Currently I have a et30 with that set up, but I have about 3-5mm of room still, thats why I am saying a et27 would be insane looking without rubbing or fender rolling
01-08-2008, 04:30 PM | #7 |
3573
Rep 9,788
Yeah you can actually go lower than 35 on the E92. However, because some tires have bigger sidewalls than others, you could have rubbing issues.
01-08-2008, 05:16 PM | #8 |
517
Rep 3,612
Very true Kenny! almost all tires are different even though they say the same "size" on the side wall so it makes it hard to garuntee anything especially when you are running super aggresive offsets where you only have one or two mm to spare!
01-08-2008, 05:29 PM | #9 |
236
Rep 3,303
Exactly! I would love to go with an offset as low as 30, but I want to run Mich's PS2 265, which tend to run big, so they prob would run at an offset as low as 30.
"...it's not about the money and not about the brand of the car, it's about handling,performance and passion......And that, no other car has all together like an M3........when you talk about the most complete car the M is invincible." --Tony Kanaan. |
01-09-2008, 10:24 AM | #12 |
1569
Rep 29,202
People with et30 and 275 have reported rubbing on the e92.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
01-09-2008, 01:09 PM | #13 |
3573
Rep 9,788
I wouldnt go with an offset lower than 30 on the E92. Even then you'll have to get tires with small sidewalls to avoid rubbing. This is the reason why I suggested going with 35- it's the safest offset for your car. You could go with 35 and get 5mm spacers to push the wheels out. If it rubs you can simply sell the spacers rather than selling the tires or wheels because you've gone with a low offset.
01-10-2008, 09:38 AM | #14 | |
755
Rep 2,736
It is an Xi coupe which I plan to lower .75 in the rear. The configurator tells me that the wheels will move 5mm more outward than my stock 8.5" wheel with 255's. What do you think? |
01-10-2008, 09:45 AM | #15 |
151
Rep 2,757
i've you want 19x10 at the rear, go with ET35 and 265/30/19 tires and fender rolling.
by the way: Work VS-XX are very nice wheels! good choice! |
01-10-2008, 11:12 AM | #16 | |
143
Rep 3,523
01-10-2008, 01:40 PM | #17 | |
755
Rep 2,736
Thanks, the tire diameter is fine. I am running the same diameter tires on all four corners that come with the sport package on the front. I just want to know if the offset will be okay with the aforementioned wheels. |
01-10-2008, 01:55 PM | #18 | |
3573
Rep 9,788
It should be just fine with that set up. |
