new springs vs new coilovers
11-20-2014, 05:38 PM | #1 |
52
Rep 405
Hey e90post,
can I install new springs on a stock OEM suspension and get better handling or do I need to get coilovers? kind of on a tight budget, so coilovers may be out of the question until spring. |
11-20-2014, 10:42 PM | #2 |
16
Rep 238
As far as I know the only reason to get new springs without new suspension is going for a lowered look... But it'll cost you ride quality for sure.
I may be wrong anyways |
11-21-2014, 09:35 AM | #3 |
52
Rep 405
11-21-2014, 09:43 AM | #4 |
1233
Rep 3,778
Drives: '11 328i '19 M6
What kind of handling improvement are you looking for? Sounds like a dumb question but different aspects of weight transfer appear at higher speeds and faster transitions. This leads to a progression of changes that can get costly when stepping up from one set of mods to another but isn't exactly cheap to do all at once.
2011 E90 328i 6MT, BMW Aero, CF hood/boot, PI+CAI+RM+3IM+BPC, SS+CI528+ThermoTec+SS#1+2XBurns, AKG 75D eng/trans, Al/Delrin diff/RS, CM 850, UCP, CAE, AKG DSSR, DiffsOnline 3.91 30/90 LSD+BW cooler, C&R, Setrab, Accusump, AST 3-way+Swift, Aurora PR+BW spherical, Vorshlag CPs, M3 brace+UR bar, ARC-8 18x8.5, 255 R1R, RB/CSL rotors+cooling, 135i calipers, RS29, RT700, Safecraft, OMP HTE-R+804F+QD Superquadro, 6pt cage+FIA, Braille, RT DL1Mk3
11-21-2014, 09:50 AM | #5 | |
52
Rep 405
so basically looking for something that Is track friendly, but also decent for daily driving. |
11-21-2014, 10:05 AM | #6 | |
1233
Rep 3,778
Not cheap but it's a factory tuned suspension that avoids trying to mix and match parts to get a decent improvement especially if you're not DIYing it. Your tires are going to make a difference. The chassis bushings are compliant enough to make the ride reasonable on stiff sidewall RFTs. Ride is going to be vastly different between tires. Most think it'll be better on non-RFTs but this isn't necessarily true. For instance Pirelli P-Zero RFTs weigh within a pound of non-RFTs and have a sidewall stiffness not that much different from non-RFTs yet they have excellent traction for an RFT. These are now only used as winter tires since they got swapped out for Toyo R1R tires on the same rim diameter and with an aspect ratio that yields the same rolling diameter for use on the track. The Pirellis are a staggered setup but the Toyos are 255/35 square. The difference is the Pirellis make using the phone in the car a bit of a problem on rough stretches of freeway whereas the Toyos make it impossible because they're non-RFTs with a much stiffer sidewall. But then they're designed that way for track handling.
11-21-2014, 10:10 AM | #7 | |
52
Rep 405
11-21-2014, 10:26 AM | #8 | |
1233
Rep 3,778
The PE comes with a new front bar, you'll likely want to leave the rear bar stock. A stiffer rear bar will create the sensation of crisper turn-in but it adds to the risk of lifting the inner rear wheel in aggressive situations or at the very least increasing the chance of spin causing the e-diff function to react and pulse the inside rear brake to steer torque to the outer wheel since the car runs an open differential. The stock rear bar will minimize this and keep the rear tires on the road. Crisper turn-in can be achieved with M3 front control arms, spherical bearings in the LFCA, and camber plates, etc. The ride quality suffers as does the steering sensitivity for street use though. As usual YMMV. If you keep the rolling diameter the same as stock with the new wheels and tires the only thing to watch out for is interference with the front strut if the new rims and tires are too wide.
11-21-2014, 10:40 AM | #9 | |
52
Rep 405
I have so much to learn about suspension.... |
11-21-2014, 10:42 AM | #10 |
1233
Rep 3,778
They will but if you need them then you need to have the fenders rolled and likely pulled. Increasing camber can help with clearances to the fender/bumper but will decrease clearance to the strut.
11-21-2014, 04:32 PM | #11 |
255
Rep 2,547
Here is a popular and recommended order of improvement - go as far as you need to:
1. Change to good non-rft tires 2. Bilstein B12 kit (eibach springs and bilstein B8) 3. M3 front control arms 4. M3 rear subframe bushings 5. e93 M3 front sway bar 6. LSD (for 335) and M3 rear sway bar |
11-21-2014, 05:09 PM | #12 | |
44
Rep 604
Drives: 2009 328i xDrive
11-21-2014, 05:35 PM | #13 |
300
Rep 4,040
Drives: 130i coupé ;)
Coils give you fresh shocks - those make things nice with the stiffer springs
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff "The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is |
11-21-2014, 06:55 PM | #14 |
255
Rep 2,547
11-21-2014, 07:01 PM | #15 | |
1821
Rep 5,337
And the 323Ci only made 170HP. On a good day. The right answer would have been, no, the 330Xi would need a limited slip up front, limited slip in the rear, and a central locking diff, otherwise it'll send power to the wheel that doesn't have traction, because it splits the power 2 ways (front and rear) between two open diffs.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
11-21-2014, 07:11 PM | #16 | |
1233
Rep 3,778
And it's not just on the track, the car is vastly better handling on the street.
