Single-digit weather, bouncing idle, SES: P112F (MAP problem)
11-20-2014, 08:36 AM | #1 |
Is it the shoes!?
3884
Rep 5,112
An odd thing happened two days ago. We had single-digit weather, and my car was outside for a large majority of it. Upon starting it, I noticed that the idle was bouncing from 1000 RPM to close to 400. As I drove, power felt intermittent, and each time I put my foot on the clutch, the revs would drop to 400, rev up to 600-800, and repeat.
After 3 duty cycles, the SES came on: Code: P112F Description: Throttle-valve angle - intake-manifold pressure, correlation: Limit value exceeded People-friendly description: The fault is recognized when the relationship between the indicated intake manifold pressure and the mass airflow calculated based on throttle-valve angle is not correct. The next day, temperatures went up to a Florida-like 26 degrees. When I started the car, it idled and drove as if nothing was wrong. The temperature has been slowly climbing, and the symptoms have not come back since. Common fixes:
Two things have been done in the recent past (~3 weeks ago): 1. VANOS Recall 2. Oil change The two possibilities I am thinking are: 1. Since it only occurred during extremely cold weather, icing causing the throttle valve to stick is very plausible 2. The VANOS recall involves removing the valve cover, meaning things like the intake and crankcase vent connections are removed. I noticed that the left-side rubber intake boot was ever-o-slightly not flush. I corrected this, but it did not seem to make any air leaks. Note that this is an aFe sealed intake, and not stock. I did not see anything awry on the valve cover, albeit there were oil stains coming from the oil cap. They did not look fresh, so I am guessing that it occurred during the oil change. Maybe someone spilled something and did not notice it. The cap does not appear to be leaking, but I will clean it and check later. I did not have any leaks in this area prior to having the recall and oil change done. I'm hesitant to take it to the dealer for reasons of them saying something like it's unrelated to the VANOS recall, and then charging me a diagnostic fee...though, I am under CPO I'm more likely to believe it has to do with the cold weather and icing. What are your thoughts on this, before I ask the dealer to look at it in case they made a mistake? Last edited by Welcome to NBA Jam; 11-20-2014 at 09:04 AM.. |
11-20-2014, 09:37 AM | #2 |
65
Rep 204
I'd be interested to see what you find out. When this happened to me, I was told it was a tuner code and nothing to be concerned about... not exactly a plethora of information available about it though.
Are you tuned or modded at all? |
11-20-2014, 09:49 AM | #3 | |
Is it the shoes!?
3884
Rep 5,112
Really the only thing I care about is, am I going to get an SES every time it gets down to single digits? I've got a bluetooth scanner to reset it, but I would definitely like to know the exact cause. |
11-20-2014, 02:09 PM | #5 |
245
Rep 1,595
Drives: 2011 335i xDrive Msport
Do you have an intake or is it stock airbox? Boost leak check would be the first thing. Symptoms show up more when it is cold out.
11-20-2014, 02:51 PM | #6 | |
14
Rep 279
01-08-2015, 08:14 AM | #7 |
Is it the shoes!?
3884
Rep 5,112
Grr. Came up again. Whenever it gets below freezing, I'll get these symptoms + a CEL. I am under CPO warranty and am tempted to bring it in. I'll hear the engine knocking for a bit in the morning, then about 10 seconds later it'll rev to about 1.2k and settle down.
My best guess is that the throttle plate is sticking, even though it doesn't actively use the throttle plate beyond warmup. I'm going to first try cleaning it, and if that doesn't work, I'll bring it on in. |
01-08-2015, 08:35 AM | #8 |
245
Rep 1,595
When it is below zero mine has been cranking 6-8 times before it finally fires up. I put straight gas in it last night and forgot to pay attention this morning to see if it started up faster without E30 in it. My idle has been pretty solid though and no CEL.
01-09-2015, 09:07 AM | #9 |
Is it the shoes!?
3884
Rep 5,112
One other thought before I take things apart this weekend:
I completely forgot that the charge pipe goes directly into the throttle body Cold weather = plastic shrinks = small cracks widen. Charge pipes cracking at the neck is common on both the N54 and N55. It is also plausible that the charge pipe has a small crack near the neck that opens when it's sufficiently cold, allowing air to escape. This could account for the mass air pressure measured by the MAP sensor in the intake manifold to differ from the mass air pressure measured by the angle of the throttle body, which is at a slight angle on warmup. This would also help explain the engine running normally after warmup, since the plastic will expand and close the gap again. |
01-09-2015, 10:44 AM | #10 |
245
Rep 1,595
Metal contracts more than plastic does, so that would not be the issue. Air is more dense though, so if you have a boost leak at all it will cause more of an issue in the cold than the warm. If you did have a crack in the charge pipe it would cause a bigger issue now than when it is warmer.
01-12-2015, 09:05 AM | #11 |
329
Rep 1,739
Mine had the same issues last winter, and would even die on every cold start.
I've returned to stock for this winter (with the exception of the JB4) and haven't been having the issues. Do you have a catless downpipe by any chance? |
01-12-2015, 04:23 PM | #12 | |
Came to the N55 Darkside
1114
Rep 12,740
01-12-2015, 11:32 PM | #13 |
245
Rep 1,595
Running straight pump gas I no longer have the long cranks on startup. I am really leaning towards getting an AP to stack with my JB4.
01-13-2015, 08:34 AM | #14 |
245
Rep 1,595
It was -21*F this morning and the car took about 10 cranks to start. No way it would have started on E30. I am glad I switched!
12-20-2021, 05:10 PM | #16 |
Is it the shoes!?
3884
Rep 5,112
