2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Cosmetic Maintenance (Wash/Wax/Detailing/Exterior Restoration & Repairs) 2 small chips on mirror
      11-18-2014, 12:40 PM   #1
Enovoc
Enovoc's Avatar
49
Drives: 12' 135i - 15' M235i
Hey guys I have two small chips on my passenger side mirror. Does anyone know an easy solution to fix them?
      11-18-2014, 02:49 PM   #2
InTheSound
InTheSound's Avatar
Drives: BMW M2 '18
Finding replacement parts
Pretty hard to repair the shadowline trim. I haven't found any suitable repair ideas/solutions to date. Replacing the part is probably the way to go!
Sadly, I have similar damage and have been searching online for the replacement part - can't seem to locate in Shadowline Trim (High gloss Black). In the attached Mirror Parts diagram, it's referenced as a Supporting ring (#3). My local parts department hasn't gotten back to me yet, but my fingers are crossed it won't cost a fortune. If anyone can suggest an online source for the part I'd appreciate it.
Good luck!
      11-19-2014, 01:57 PM   #3
InTheSound
InTheSound's Avatar
Drives: BMW M2 '18
Found the correct part numbers
If this is helpful, here are the correct part numbers for the replacement surround:
Left Mirror (Driver):
51-16-7-284-125
Right Mirror (Passenger):
51-16-7-284-126
      11-19-2014, 02:47 PM   #4
Enovoc
Enovoc's Avatar
49
Attachment 1119781
Good luck!
Yeah thank you it's in a tough spot. I'm going to see if touch up paint will make it look less noticeable.
      11-24-2014, 05:15 PM   #5
tehone628
Drives: 2281
Touch up paint and use the Langka system. Similar to Dr Colorchip, however you built up the surface and then use a solvent to remove the 'blob'. Works well.
http://www.langka.com
      11-24-2014, 05:33 PM   #6
overcoil
3074
Drives: M235i 6spd
I'm not so sure I would use the Langka system on the gloss black mirror.
      11-24-2014, 06:13 PM   #7
tehone628
Drives: 2281
Would you use it on gloss black fender paint?
      11-24-2014, 06:59 PM   #8
overcoil
3074
Drives: M235i 6spd
I wouldn't.
Black is crazy to work with.
On a piece down low near a front dam or sill - that's where I would use the Langka system of Dr. ColorChip before going to a more visible spot.
Tags
mirror chips
2addicts
