BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > M3 vs....
      01-07-2008, 08:18 PM   #1
gbb357
68
Drives: IS300
MINE'S GT-R exhaust makes 501 hp at the flywheel:
Originally Posted by Autoblog
Eric Hsu, one of the many men behind XS Engineering and also a veteran of A'PEXi and Cosworth, got a hold of the February 2008 issue of Japan's Option magazine in which the pub strapped the MINE'S-modified Nissan GT-R to a Dynapack and ripped off a couple of runs. The GT-R was equipped with the prototype catback exhaust we featured a couple of weeks back, and although the design is far from streetable in its current form, it still created just over 20 hp over the stock setup by reducing backpressure and allowing a 1.42 psi increase in boost. Although Hsu maintains that the Dynapack might skew the results by up to five-percent, the 507.9 ps (500.95 hp) rating at the flywheel is still impressive considering that nothing was done to the GT-R's ECU.
[Source: JDM-Insider]
http://jdm-insider.com/Blogs/Eric/?p=540
The dyno test was taken at the flywheel, so If this is the case, then the 480hp rating that Nissan is giving seems to be accurate.
      01-07-2008, 09:39 PM   #2
InJapan
Drives: E46 M3 Cab, imola/imola
Those numbers were at the wheel hubs. Not at the flywheel. After the transmission and differential losses. But does not include the tire / wheel losses which are seen with the Dynojets.
      01-07-2008, 11:53 PM   #3
OzCarfreak
OzCarfreak's Avatar
Australia
Drives: Merc / BMW /Audi
this thing is a monster
      01-08-2008, 01:44 AM   #4
swamp2
swamp2's Avatar
609
Drives: E92 M3
Further evidence of an under-rating.
501 with exhaust - 20 exhaust = 481 at the hubs. 5% higer than a dynojet = 457 at the wheels, "with dynojet". So we are back to 5% total drivetrain loss which is simply not possible on this car with the extra drive shafts.
      01-08-2008, 02:47 AM   #5
footie
footie's Avatar
No_Country
1094
Drives: i4M50
Explain why Eric Hsu, one of the many men behind XS Engineering and also a veteran of A'PEXi and Cosworth would get it wrong and say that it's at the flywheel and not the wheels, this doesn't make since to me. The guy clearly knows more about engines than almost anyone here if not everyone.
      01-08-2008, 07:10 AM   #6
gbb357
68
Drives: IS300
It clearly says at the flywheel. Do we have to make another discussion about what the article says and what's a flywheel.
      01-08-2008, 07:14 AM   #7
gbb357
68
Drives: IS300
Here's what the article said.
Originally Posted by Beyond the Dyno
You should go and pick up a copy of the February 2008 copy of Option Magazine. Hiro the editor in chief just sent me a copy because there’s a feature of Cosworth in it. Aside from the fact that there’s a bitchin feature of Cosworth in it (and a picture of yours truly with a stupid ass smile), the main focus of this issue is the R35 GT-R. There’s also a R35 GT-R catback exhaust test in it where some shop fabricated a titanium catback exhaust and the car made 507.9ps (500.95hp) at the flywheel. Granted, this test was conducted on a Dynapack so it probably read 5% or higher than any other dyno, but the gain of 22ps is for real. If you can’t do the math, that’s 485ps from the factory which is pretty god damn buff already considering the car is rated at 480hp at the flywheel. The boost went up by 0.1kg/cm^2 (1.42psi) due to the reduced backpressure, but this also tells you that the car has some serious potential from the factory. By looking at this exhaust I can guarantee you that it’s louder than hell so I wouldn’t expect a 22ps gain on a production catback exhaust though.
It looks like Nissan calibrated the fuel map to go leaner after peak torque. This is done to increase peak horsepower and is probably fine at low boost and horsepower levels where the cooling effect of a rich mixture is not necessary. Keep in mind that Nissan is shooting to compete with supercars so they need that peak horsepower number so rich baller dudes can tell their buddies, “It makes 480hp. That’s the same horsepower as your Porsche 997 Twin Turbo for $60k less!!!”. The R35 is buff.
Here's the link again: http://jdm-insider.com/Blogs/Eric/?p=540
Clearly he's talking about from the flywheel.
      01-08-2008, 09:09 PM   #8
swamp2
swamp2's Avatar
609
Drives: E92 M3
Despite the fellow being an expert there is no way he can really have flywheel results. It is simple - the only way to have that is to have complete information about entire drive train loss (less the tires since it is a hub dyno) as a function of rpm. The only way to really get that is to test the drive train in isolation or to have the actual at the flywheel dyno results and the hub results and subtract. If he doesn't have that then he is estimating drive train loss.
Of course this contradiction weakens my point above about evidence for under-rating....
      01-08-2008, 09:16 PM   #9
Los Angeles
Steve Forte Rio
No_Country
149
Drives: 08' 328i
Hmm, so the expert isn't correct?
Are you an expert?
      01-08-2008, 10:45 PM   #10
bruce.augenstein@comcast.
99
Drives: 2017 C63
Don't know much about that dyno, but many chassis dynos, including the Dynojet, allow you to do a coast down so as to get good (not perfect)approximations of friction and rotational losses. Yes, it's still an estimate, however, because such losses may not be linear to the power produced.
I got the impression from one or more of Artpe's notes and others that this particular brand of dyno allows you to simulate engine HP thru allowances for drivetrain losses.
Bruce
      01-08-2008, 11:48 PM   #11
InJapan
I also saw the article. There is no mention about if the numbers were calculated or modified with coast down static drivetrain losses calculated. The article shows the car strapped to four Dynopacks at the hubs. The graphs appeared to be straight acceleration graphs with the numbers peaking at 508 ps with the exhaust and 485 ps in stock form. So, I'm assuming that drivetrain losses were not accounted for.
Unless someone has more information about how the test was done. You must assume that these numbers were at the wheel hubs. I'm guessing that Eric Hsu just mis spoke / typed.
You can also get a hint from what he wrote... 5% higher than other dynos... Dynopacks in general only lose about 10% compaired to 15% from a Dynojet because there are no rotational / frictional losses from the wheel and tire. If he meant flywheel, then he would have said 15% higher than other dynos.
Engine dynos... at the flywheel
Dynopacks... at the wheel hubs... 10% losses
Dynojet... at the tires... 15% losses
Mustang / Dyno dynamics... at the tires... 15-20% losses.
This is all approximations for a clutched tranny. Lots of other variables.
I am somewhat of a dyno expert. I arranged the distributorship of Dynojets to Korea.
      01-09-2008, 01:58 PM   #12
swamp2
swamp2's Avatar
609
Drives: E92 M3
Are you an expert?
No, but it does not matter. What if someone told you they made a perpetual motion machine. Would you believe them? Do you have a Ph.D. in physics with a focus on thermodynamics? See the point?
      01-09-2008, 04:07 PM   #13
gbb357
68
Drives: IS300
His point is Eric Hsu is just not anyone, it's someone with a decent reputation and knowledge in that field. It's like Schumacher making a statement about driving F1 cars, most people like you and me probably would'nt question him. Not to say that he's never wrong.
      01-23-2008, 02:07 PM   #14
sdiver68
Expert Road Racer
59
Drives: 07 335i e90, 09 335i e93
I think the dyno already had a drivetrain-to-flywheel correction factor of 5% built into the report on the screen.
Here's an explanation from another forum:
Hello,
The Dynapack measures power at the axle - one of the only machines that actually does - most machines measure what the roller did, which isn't ever the same thing. The reason we have a "flywheel" screen is because most chassis dynos for years have been incorrectly displaying measured torque. We show the measured torque, because we can - we actually measure it directly.
If you have a car making 300lb/ft at the flywheel and run it through a drivetrain that has a 4:1 gear reduction, the gears will multiply the torque and divide the rpm. So your actual "wheel torque" or axle torque will be something like 1200lb/ft - minus a little bit of efficiency loss. So why do most if not all roller dynos display the torque as 300 minus a little loss? Beats me. It is completely incorrect, but those are the numbers people are used to seeing. It is probably because most roller machines are measuring the roller and back calculating everything from there - and dividing it by the engine rpm, instead of the axle RPM. Their torque numbers are calculated several steps away from the original measurement. By comparison, we measure torque at the source, and RPM at the source, so it is direct measurement. Because people aren't used to seeing 1200lb/ft of axle torque (even though it is correct) we have the "flywheel" screen. The flywheel screen takes our measured torque number and divides it by the vehicle's gear ratio to get it back to a "flywheel" torque number that people are expecting to see. True, it isn't actual flywheel torque because we aren't measuring it there - but it is much closer to being flywheel torque than wheel torque. After seeing the explanation, I think you'll see that calling 300lb/ft the "wheel torque" is ridiculous - but it has become the standard. We show you the real numbers as a default and have the Flywheel screen to show the numbers the other way if you want them. Because of all of this, most of our operators use the flywheel screen to give the torque numbers that they are expecting to see.
The TCF function is there if you want to use an estimate for drivetrain loss and add it to the "flywheel" numbers. If it is at 1.0 - nothing is done. If it is at 1.15, then the measurements are multiplied by 1.15 on the flywheel numbers only. Also, the flywheel screens show the TCF number - to discourage people from being sneaky about using it.
Sorry it is so long winded, but I think it is important to show why we do what we do so people understand it. If you have any other questions, just let me know.
Thanks,
John Card
Dynapack USA
jcard@dynapack.com
Phone (559) 292-3800
Fax (559) 292-4900
Sent:
Sent: Tuesday, December 18, 2007 10:31 AM
To: dynapackusa@earthlink.net
Subject: RE: Dyno Graph Questions??
Hello John,
Thank you for the detailed response to my questions. So the dyno sheet I sent shows a TCF of 1.00, does that mean that the results displayed are at the hubs, or an estimate of flywheel power with the Dynapack software adding a correction factor in?
Response:
Date: Tue, 18 Dec 2007 10:55:11 -0800
Hi,
1.0 means that no correction has been added in - so it is as measured at the hubs.
Thanks,
John
IMHO the dyno graph shows the hub number with a 5% torque correction factor built in.
So...
501HP * 5252/6515 = 403 ft-lbs TQ after 5% correction factor which = 384 ft-lbs MEASURED HUB TQ (@ 6515 RPM before 5% correction factor) = 476 HP actual measured at the hubs with NO drivetrain loss consideration.
      01-24-2008, 01:54 AM   #15
swamp2
swamp2's Avatar
609
Drives: E92 M3
Originally Posted by sdiver68 View Post
So...
I liked John's explanation, thanks for that. However, I am not following your analysis/interpretation above. Under-rated, and if so by how much? Thanks.
      01-24-2008, 08:23 AM   #16
sdiver68
Expert Road Racer
59
476 = actual measured hub HP.
Times a drivetrain factor, let's use 10% because we do not have roller losses associated with a typical dyno.
= 523 HP
Minus 22 HP claimed for the exhaust
= 501 HP stock...underrated by ~21 HP using the above assumed drivetrain loss of 10%.
= 525 HP stock using 15% drivetrain loss, so ~45 HP underrated.
      01-24-2008, 01:49 PM   #17
swamp2
swamp2's Avatar
609
Drives: E92 M3
Thanks, this is consistent with my previous analysis as well as the N'ring regression analysis by lucid.
      01-24-2008, 02:18 PM   #18
gbb357
68
Drives: IS300
Consistent?!
Originally Posted by Swamp
My post directly following his was:
OMG how many times did I have to say it??? Totally under-rated. Even conservatively this thing has a 15% total transmission and drivetrain loss. With all the extra shafts it could be closer to 20% (more efficient maybe than a RS4 drivetrain but more shafts/bearings as well). This means the engine is putting out about 560 - 590 crank hp.
Now we know the whole story...
I also just re-ran the power to weight vs. N'Ring lap time regression with 560 hp and found it to be outperforming the linear fit by a mere 1.7 seconds. Previously, we found in the regression thread that is was 25 seconds faster than the model predicted. If the car really had that good of a driver and tires as good as I expect they are the time is ABSOLUTELY NOTHING SPECIAL. It is just like a drag car getting a good drag strip time. hp rules even at the N'Ring.
Talk about dishonest and over-hyped...
That being said 560 hp for $70k is amazing and the car is darn fast.
How is this even remotely close on being consistent?
      01-24-2008, 02:24 PM   #19
gbb357
68
Drives: IS300
Thanks sdiver, good post.
So i guess it's not really "MASSIVELY UNDERRATED". Anywhere from 21hp to 45hp of under-rating. I wonder how are they going to pass the final SAE certification.
      01-24-2008, 06:16 PM   #20
swamp2
swamp2's Avatar
609
Drives: E92 M3
If you would stop quoting me completely out of context you would appear at least marginally "on the ball". As you know, since you participated in the bloody discussion, I admitted "massively" was both slightly premature and too aggressive of a word choice. How many times did I say this exact same thing above in those threads, 5, 10?
And by the way 45 hp is very close to 10% and that is pretty darn large.
      01-24-2008, 07:38 PM   #21
gbb357
68
Drives: IS300
^^^^ RIIIIIIIIIIIIIGHT. "On the ball" by what standards. The new estimates are between 21hp to 45hp under-rating, your estimates are 80hp to 110hp under-rating, you call that "on the ball", are you kidding me. I agree that 45hp is huge, but it could possibly be as low as 21hp as well. Either way, it is still under-rated if this is correct.
m3post
