Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Style 249 on e92 335i
      11-16-2014, 12:43 AM   #1
OPe92
OPe92's Avatar
30
Drives: 2008 335i 6AT SGM
I've searched and searched for someone running this setup. I'm my mind I think it will work. Style 249s are 19x8.5 et14 and 19x9 et14. I'm thinking a 225/35/19 in the front and a 255/30/19 in the rear. I have shaved fenders in the rear, no camber plates but pulled the alignment pins to get -1.5 camber in the front. What do you guys think? Doable or will I need more camber? Also if anyone has pics of this setup please post
GIAC, Alpina TCU Flash, Ohlins, Brembo, Eisenmann, Quaife, Evolution Racewerks, Wagner Tuning, AFE, M3 suspension bits
      11-17-2014, 01:48 PM   #2
OPe92
OPe92's Avatar
30
Anyone?
      11-18-2014, 12:02 PM   #3
MonacoBlueE90
MonacoBlueE90's Avatar
Finland
163
Drives: BMW E90 320D Half-LCI
Since you have already done fender work and have front camber you should be just fine. Go for it, maybe consider getting narrower front tyre like 215/35/19, maybe even narrower rear tyre and push rear more out with spacers.
Closest i could find is this e90 with m6 wheels http://www.e90post.com/forums/showthread.php?t=598490
      11-18-2014, 06:38 PM   #4
OPe92
OPe92's Avatar
30
Thanks man. I saw a set of 249s on Craigslist I might just pull the trigger
      11-18-2014, 08:51 PM   #5
Isaiah5411
Isaiah5411's Avatar
187
Drives: 2008 Montego Blue 328i E93
Here ya go:
http://www.e90post.com/forums/showthread.php?p=2128824
2008 Montego "330i" /3.0 manifold /AA /Eurobox /PE /Alufelgen CS7 /Macht Schnell /Michelin PSS /XPel
"O thou afflicted, tossed with tempest, and not comforted, behold, I will lay thy stones with fair colours, and lay thy foundations with sapphires." (Isaiah 54:11)
      11-19-2014, 12:10 AM   #6
OPe92
OPe92's Avatar
30
Originally Posted by Isaiah5411
Would look better with smaller tires
      11-19-2014, 02:17 PM   #7
Isaiah5411
Isaiah5411's Avatar
187
You're right. They should have used 235/35-19s or 245/35-19s in the front. (245/40's are outside then recommended variance.)
