Obd/USB cable with
11-08-2014, 02:54 PM | #1 |
Rep 81
Obd/USB cable with bmw standard tools
I just Recived my USB/obd cable with a cd that had instructions in Chinese. I don't think il ever get the software loaded using the supplied cd. Can I just download bmw standard tool from the sticky on here and use my cable?
11-09-2014, 02:16 PM | #2 |
Lord Scrip
1820
Rep 3,016
Drives: 2011 M3 Coupe
Is it two DVD's? Usually you have to unzip (2) huge files which expand to something like 10g-30gig. Then there's 1 main installer. After the install you can edit the INI files of NCSExpert, WinKFP tools to put things into English.
11-09-2014, 02:21 PM | #3 |
Rep 81
The files are in English
It's the instruction vid sent with it. It's in Chinese. I've watched the vid and it look like lots is being clicked. I just can't follow the vid as everything on his PC is in Chinese 😄
11-09-2014, 03:05 PM | #4 |
529
Rep 2,503
I've found the easiest install for BMW Standard Tools is to download:
"BMW CODING PACK MAY 2013" Then download the latest E89 daten files and update using: "BMW CODING TOOL" Both can be found by Google and both have clear instructions inside... |
11-09-2014, 04:24 PM | #6 | |
Lord Scrip
1820
Rep 3,016
11-12-2014, 01:42 PM | #7 |
Rep 81
please help
I'm confident once I have the bmw standard tools I will be able to work it out but...
I cant download it. even the box.com link on here does not seem to work. All I need is a clean download that I don't have to sign up for. can you help? all I want to do is read any fault codes that pop up (i.e DPF warning, see what sensor is faulty) |
