FS: Nokian or Dunlop winter setup.
11-06-2014, 08:26 AM | #1 |
Rep 86
edit*
http://www.kijiji.ca/v-view-details....dId=1030810353 17" - will clear larger calipers 225/50/17 all around Nokian Hakkapeliitta. Cost me about $300 each new from Kal Tire all 4 tires - well over 50%, probably 75%. 2 of the tires have camber wear from BMW negative camber settings in the rear so they are at about 50% or just under on the side treads on one side only. Good for this winter no problem. I would replace for next winter. This winter I would run them in the front to maximize traction in the rear. 3 options available - 1) Current setup as is - $500 2) Current setup replacing two tires with Dunlop run flat winters (70-80% tread) +$200 (700 total) 3) Replace all 4 tires with Dunlop run flat winters, all with 70-80% tread. - $800 total 3 rims are near mint as shown in pics 1 rim has some curb damage, still looks great on the car and doesn't effect performance anything like that. Just cosmetic. These rims WILL clear larger brake calipers as well. Last edited by 99wolfie; 11-06-2014 at 03:38 PM.. |
