FMIC worth it on a DD?
11-03-2014, 10:26 PM | #1 |
Normal Person
148
Rep 862
Drives: 2011 E90 335i
So I got my suspension dialed in and my car is handling great. Got a custom engine tune from Pro Tuning Freaks using a Cobb AP and got a nice boost of power over the BMW PPK I had before. Now I'm kinda hungry for even more power and starting to think about bolt-on engine mods. Thing is this is a street car and while I do have a long commute and enjoy spirited driving I don't want the car to get any louder in the exhaust department. So that leaves me with an FMIC and maybe a CP on my short list of bolt on mods that won't increase the exhaust volume.
Do you guys think I'll feel a noticeable increase in power from a FMIC and another round of tuning? I'm looking to get as much oomph as I can out of the N55 without making it sound like I have an after market exhaust. TIA, Robert |
11-03-2014, 10:42 PM | #2 |
28
Rep 300
Drives: '11 335i
You can do everything but a catless dp and the sound won't change. But the do will give you the most power after a tune.
11-03-2014, 11:35 PM | #3 |
324
Rep 2,014
The DP really isn't crazy loud when you have the stock exhaust. It's basically only loud when you want it to be aka when you're laying into the accelerator. Under normal, light throttle it is slightly louder than stock. Under light throttle, the sound is comparable to a stock N55 after a cold start.
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3 Michelin PSS | M3 Control Arms LUX v4 LEDs | Shadowline Grills | Lip Spoiler |
11-04-2014, 12:48 AM | #4 | |
44
Rep 340
11-04-2014, 06:45 AM | #5 |
38
Rep 427
I think you should pull the trigger on the FMIC....I'm FBO minus DP on my 11 e90, im xdrive so i removed my secondary cats / resonators, and added a BMW PE, as of now i love the sound but i may want more and get an Eisenmann Race....point being about the FMIC, im protuned from Brentuning (Local tuning shop in MA) my numbers on the dyno before and after my FMIC / CP were phenomenal, here are my dyno numbers (To The Wheels) throughout my performance upgrades:
Stock: 255hp / 255tq Cobb S1 Tune, K&N Drop In, BMW PE, Alpina TCU: 263hp / 305tq Brentuning Protune, K&N Drop In, BMW PE, Alpina TCU: 302hp /365tq Brentuning Protune, K&N Drop In, BMW PE, Alpina TCU, Secondary Cat Removal, VRSF 5" Stepped FMIC, BMS CP: 325hp / 408tq Future Mods: BMS Meth Kit This car has drastically improved performance wise and would 100% change for the better if i put DP's but here in MA as my DD i want to pass my inspection w/out the hassle of removing my DP yearly....if i were you and wanting more power, i would def pull the trigger on the FMIC as well as Upper CP |
11-04-2014, 07:19 AM | #6 | |
329
Rep 1,739
11-04-2014, 07:27 AM | #7 | ||
38
Rep 427
11-04-2014, 09:26 AM | #8 |
245
Rep 1,595
Drives: 2011 335i xDrive Msport
You can always do a stage 1 turbo too. It really helps the pull up top as it pulls nicely to 6500 now instead of 5500. I love being able to rev it out now when I want to!
11-04-2014, 09:36 AM | #9 |
38
Rep 427
11-04-2014, 09:44 AM | #10 | |
40
Rep 156
I'm Full FBO N55. if you can get a catless dp at this point....one of the greatest mods you can do besides tuning. You wouldn't know if I had a DP or not. My start up is loud but I also have can flap set to open. IF they were set to close....you would never know. So noticeable increase from an FMIC....no way. but you won't lose so much doing multiple runs. |
11-04-2014, 10:36 AM | #11 |
Normal Person
148
Rep 862
Thanks for the replies, guys. My indy mechanic said an aftermarket DP would be louder. Are there 2 different types of DP - cat and catless? What is the difference? I live in CA where emission standards are strict, don't want to have to undo anything every time DMV makes me get a smog check.
I understand about replacing the plastic OEM CP - what about the diverter valve? Does that need to be replaced on an N55 or can I keep the OEM DV? |
11-04-2014, 10:43 AM | #12 |
329
Rep 1,739
Catted has a catalytic converter, - necessary to pass emissions in most places - catless does not. By removing the catalytic converter, you free up the flow of air through the car, thus producing more power.
Generally, N55 owners do not replace the bypass valve. It is integrated into our turbos, whereas the N54's bpv is located on their chargepipe. |
11-04-2014, 10:50 AM | #13 |
Normal Person
148
Rep 862
Got it, thanks. Is there any difference in volume between a catted and catless DP? Does anyone know if a N55 E90 w/ catted DP would pass a smog check in CA?
11-04-2014, 11:06 AM | #14 |
324
Rep 2,014
I've read that some catted DPs do pass emissions but also that some do not. I've also heard that the high flow cats in catted downpipes deteriorate over time. Overall, catless will be better for performance because it's a straight pipe with no airflow being restricted. We have yearly inspections where I live and there are plenty of people that get away with not removing the DPs.
11-04-2014, 11:24 AM | #15 |
Normal Person
148
Rep 862
Will have to look into that, thanks. But I'm getting off-topic in my own thread! Thinking of starting w/ a black ano ER FMIC and CP + another round of tuning, for now at least.
11-04-2014, 04:15 PM | #16 |
245
Rep 1,595
11-04-2014, 06:52 PM | #17 | |
136
Rep 1,192
Drives: 2011 335i MT
PTF Map, Pure Turbo Stage 1, GFB DV+, Mfactory LSD, AA FMIC, B12 Pro Kit, M3 FCA, AR DP and
Dynavin N6, Mosconi AS100.4, AS100.4, AS200.2, Micro Precision tweeters & woofers, Esotar2 1200 |
11-08-2014, 03:45 AM | #18 | |
45
Rep 531
And what do you do for warranty work when you have to go to dealer? Do you remove DP? |
11-08-2014, 02:35 PM | #19 | ||
388
Rep 1,945
