Cobb users who switch maps from reg. to E30 - do u get P2AAF (Fuel Pump) codes?
11-03-2014, 11:16 AM | #1 |
73
Rep 978
So I had run out of E30, so switched to regular gas and 2+ map. Then when I filled up with E30, switched back to the OTS Cobb map, and did a few 3 gear WOT runs and logged them. No CEL's.
When I stopped and checked for codes though, to my surprise, there was a P2AAF (Fuel Pump Plausibility) code. I've yet to check out my logs for fuel trim and the LPFP pressure, but here's the other strange thing: After clearing the code, I did two more WOT 3rd gear runs, and got no code at all! So can it be that when you first switch from a regular map to an E30 map, the car throws the fuel pump code, and then doesn't, because it's now adjusted to the extra fuel flow? I'm hoping I don't have a HPFP problem! |
11-03-2014, 11:22 AM | #2 |
Rep 305
p2AAF is nothing related to hpfp. Had that ever since I replaced the lpfp pump to an e85 complaint pump and running e85. You'll always be seeing it. Harmless if you asked me...
11-03-2014, 12:23 PM | #3 |
65
Rep 385
I have been running an ethanol pro-tune for a couple years and pretty much always had the p2AAF. Not a big deal.
2007 E90, 6MT, VRSF 7" FMIC, RR DP's, Vargas Stage 2+ (19t unclipped), CP-e Charge Pipe/Tial BOV, BMS DCI, Fuel-it! Stg 2 LPFP, E66, 118k+ miles Brentuned
11-03-2014, 01:28 PM | #5 |
73
Rep 978
Interesting. Thanks guys.
I know another case when 2AAF is harmless. I know it comes up when gas is low, if you make a sharp left turn, when accelerating. That's happened to me a few times, and I even felt a hiccup during acceleration. @JStang - So an ECU reset with Cobb won't do the trick? |
11-03-2014, 01:40 PM | #6 | |
563
Rep 3,625
