50,000 Maintainace suggestions
10-30-2014, 10:03 AM | #1 |
13
Rep 59
I did some searching but could not come up with an answer, so hence the post.
I am about to go over the 50,000 mile mark on the odometer, what should I be looking at changing? Things that come to mind are: -Spark Plugs (I was not sure what the BMW interval is) -Oil change (A given) -Coolant flush . -Transmission fluid change. -Torque converter fluid replace. -Serpentine belt replacement. - Preemptive replacement of the water pump and Thermostat? (everything I can find suggests they konk out around 60,000 miles) Last year I did the break fluid and air filters and a new set of tiers. Thanks James Last edited by james0013; 10-30-2014 at 12:21 PM.. |
10-30-2014, 10:24 AM | #2 |
Fuck it dude, let's go bowling.
886
Rep 2,480
I would look into servicing your keyboard first
1M. Previously: '13 135is; '07 E90 335i; '02 325i; '99 Z3; '98 328is; '87 L6; '77 320i
10-30-2014, 11:33 AM | #3 |
1911
Rep 13,103
You left out Differential and Power steering.
Although you could maybe hold off on these awhile. I don't believe there is any torque converter fluid. What about the blinker fluid. |
10-30-2014, 11:37 AM | #4 |
90
Rep 386
Drives: 08 535xi 11 328xi
The torque converter is a fluid coupler so yes it does have fluid in it. It gets oil from the transmission, there just isn't anyway to drain it out unless you remove the torque converter.
10-30-2014, 12:44 PM | #6 |
886
Rep 2,480
I believe the TC holds ~3L of ATF. I just changed the ATF in my Acura RL. 3X flush to get most of the old TC fluid out, but that's probably overkill. For the Honda, it was about $125 for a case of ATF - much more for the BMW I think.
Decent threads out there. Here's one. http://www.1addicts.com/forums/showthread.php?t=617182
10-30-2014, 02:11 PM | #8 | |
13
Rep 59
The problem is that if it fails you run the risk of warping the head and having to replace it. Which is much more costly than a water pump. Traditionally I have always changed a water pump and thermostat at 75,000 miles when changing a timing belt. So changing a water pump at 50,000 may be early but it does not seem out of the question as a maintenance item. |
10-30-2014, 02:27 PM | #9 | |
74
Rep 776
10-30-2014, 04:34 PM | #13 |
1911
Rep 13,103
There are many useful subforums here.
They include DIY and maintenance forums. http://www.e90post.com/forums/forumdisplay.php?f=16 http://www.e90post.com/forums/forumdisplay.php?f=378 Also there are quite few DIY's on ytube and at some of the online part suppliers like Pelican Parts. Some of them have water pump themostat kits. Gasket Kits , Brake Kits etc etc... Transmission Kts with Fluid and Filter for the automatic tranmission I think it takes like 7 quarts. My Indy says unless the belts are cracked no need to replace them. Google Mike Miller BMW for the old school maintenance schedule and some history and perspective on maintenance. Transfer Case Fluid must be BMW Fluid . Last edited by ctuna; 10-30-2014 at 04:49 PM.. |
10-30-2014, 04:41 PM | #14 |
Rep 72
Belts, and tensioner should have been replaced ages ago. The tensioners are known to go bad, and shred the belt. Then big long strands of the belt get forced into the head through the cam seals. At least on the N54s.
10-31-2014, 09:50 AM | #16 |
17
Rep 259
Not quite a maintenance item but if you are passing 50k, your rear shocks are probably on their way out. I just swapped mine at 65k and I had no idea how bad they were until I started driving on new shocks, like night and day.
10-31-2014, 10:26 AM | #17 | |
13
Rep 59
no way that is a maintenance item and very disappointing if that is the case, what junk did they fit at the factory? I have never had to replace struts that early. |
10-31-2014, 11:34 AM | #18 |
17
Rep 259
Mine were OE made in Poland likely to the lowest bidder. Not sure who actually made them but the rears in these cars wear pretty easily. I probably could have driven them to 100k as others have and dealt with the rougher ride on my 19" rims, but I wanted to put on Koni FSDs in my xi. These shocks dramatically improve the way the xi handles.
