245/40/18 square PSS on LCI E90 xdrive
10-28-2014, 03:59 PM | #1 |
39
Rep 592
With stock suspension and no spacers.
What offsets would work for this? Anyone running this setup?? Anyone have pics??? TIA.
Evolution Racewerks FMIC and Charge Pipe with TIAL-Q.
Wedge Tuned 93 Oct, K&N Panel, Conti DWS 245/275. |
10-30-2014, 10:44 AM | #2 |
Rep 197
10-30-2014, 08:41 PM | #3 |
39
Rep 592
Now to find something before spring. thanks.
10-31-2014, 07:05 PM | #4 |
684
Rep 1,434
I run 18x8.5 35 et with 15 mm spacers which is the same as running a 20 offset along with 235/40 square set up with no issues, so you shouldn't have a problem running a 35 offset.
2022 x5 m50i - Dravit grey
2005 evo 8 (current) built 2.3 488/409 mustang dyno Old stable mates - 87 325i, 88 m3, 90 m3, 97 m3 4dr, 04 325xi, 91 gmc Syclone, 08 335xi, and 13 x3 35i msp 2014 x5 50i msport |
11-01-2014, 02:37 PM | #5 |
BMW enthusiast
58
Rep 386
I run 235/40/18 on 18x9.5 ET 35 Apex Arc-8 stock xdrive suspension. I run a 5 mm spacer up front (so final ET 30 up front - probably only need a 3 mm) because the wheel shop that balanced the wheels put a clip weight on the inside rim which without a spacer hits my strut. They will fit with about 3 mm clearance if that wasn't there (tried another wheel that didn't have it and it fit).
I went with this size because I plan on lowering a bit. If I didn't lower, I bet a 245/40/18 would fit, but probably not michelin pss as they run wide. The rubbing would be when you turn, they would probably hit the fender liner. I had the same dilemma when I was thinking of purchasing tires. Hope that helps Scott |
07-03-2015, 12:18 AM | #7 | |
39
Rep 592
