Please help. Car Overheating
10-27-2014, 11:30 PM | #1 |
36
Rep 228
Drives: 2013 E92 Melbourne M3
Delete
10-28-2014, 01:25 AM | #2 |
435
Rep 686
Drives: 06 330xi (TRADED IN)
Seems like a clog/kink somewhere in the lines. Also, was the coolant properly cleared of air bubbles? You activate the pump with the engine off using a certain pedal sequence, not by running the engine with the cap open like you do with mechanical pumps.
10-28-2014, 01:27 AM | #3 |
36
Rep 228
I will have to ask the mechanics about this. Thank you for the information. I will look into this for sure
10-29-2014, 12:24 AM | #4 |
36
Rep 228
delete
10-29-2014, 12:29 AM | #5 |
36
Rep 228
delete
10-29-2014, 02:21 PM | #7 | |
964
Rep 3,854
Drives: 330i, 135i
10-29-2014, 02:28 PM | #8 |
208
Rep 1,161
You might want to check that the tech did the proper coolant system purge protocol, which can be done without a factory tool. I'm sure you can find the process here on the forum.
10-29-2014, 04:09 PM | #9 |
36
Rep 228
These are all great ideas, thank you! I just emailed the shop to have them check all of these things out. The OFHG might very well be the cause if it is not a failed thermostat.
I noticed that when I picked the car up from the shop after the pump was changed that the OCI had dropped from 7000 to 2500 miles which I thought was strange but I also thought that the shop had calculated this change. I believe that the car sensed something was jacked with the fluid. Hopefully I'll hear back soon from the shop and can report on whats going on. |
10-29-2014, 06:57 PM | #10 |
36
Rep 228
Heard back from the mechanic. Was informed that the DME was melted. Hoping that replacing it will solve all of the issues.
10-30-2014, 10:59 AM | #11 | |
296
Rep 2,015
was it exposed? DN |
10-30-2014, 11:07 AM | #12 |
36
Rep 228
I have no idea. Some sort of a short probably?
11-06-2014, 05:11 PM | #13 |
36
Rep 228
Just an update. DME was melted so now the engine has to be pulled to figure out what is going on with the engine harness that caused the short
11-07-2014, 10:31 AM | #15 |
296
Rep 2,015
Have you read this thread.
http://www.e90post.com/forums/showthread.php?t=779832 |
11-11-2014, 08:55 AM | #16 |
36
Rep 228
My car is a 12/2007 build. I am hoping this shop figures things out quick. I am getting a new DME and engine harness so hopefully that fixes things...
