BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > My Eisenmann Has Finally Arrived!
      01-07-2006, 12:43 AM   #1
siriusinvestor
siriusinvestor's Avatar
67
Drives: 1989 Ugo
Damn, the eisenmann exhaust is huge! So in reality, my exhaust along with hunters is the exact same thing, due to the fact that both engines are the same except for the 330i being tuned abit more than the 325i?
VIDEO CLIP of the Exhaust here! : http://www.e90post.com/goodiesforyou...sinvestor1.wmv
      01-07-2006, 12:49 AM   #2
poldim
Vroom Vrrooooom
poldim's Avatar
Russian Federation
300
Drives: 330i
2006 330i Sedan  [0.00]
2003 GSX-R 600  [0.00]
Cool! The stock one is huge too, just look under the car...
When's it going on?
-Dmitriy
06' BMW 330i & 03' Suzuki GSX-R600
SG | Beige Dakota | Poplar || iDrive w/MP3 | PP | SP | CWP | PDC | Comfort | Shades || 40% Tint
| Black Line Tail Lights | Hardwired V1
      01-07-2006, 12:50 AM   #3
siriusinvestor
67
Drives: 1989 Ugo
So im gonna try to setup a before (Stock)/ after (eisenmann) video like hunter did.
My primary question is, how difficult is it to remove the stock exhaust? Is it simply just removing the bolt on the stock and disconnecting it? In which after you would hook on the hangers to the chassis and bolt eisenmann exhaust? Because my father is actually considering taking on the task of installing the eisenmann exhaust himself without the assistance of a qualfied mechanic. I regret to say that I did not recieve any photos or illustrations from eisenmann on how to install the exhaust onto the E90.
      01-07-2006, 12:54 AM   #4
diesel007
Not Stock
diesel007's Avatar
160
Drives: 325I
2006 325  [0.00]
I believe the old exhaust needs to be cut and the new one will slip on with a sealant and clamp.
***Wallpaper of the month***
1/1/072/1/07
      01-07-2006, 01:01 AM   #5
siriusinvestor
67
Drives: 1989 Ugo
Ok, so that shoots down my dads ingenious idea of installing it himself. I have to look for a reputable muffler/exhaust installer in my area or surrounding areas. Can anyone help me? I basically live in the in northern nassau county area which boarders northern queens.
      01-07-2006, 09:01 AM   #6
bschott
Drives: 2006 BMW 330i
I know nothing about this exhaust, but I've installed diffrent sorts of cat-back exhausts on other vehicles that I've owned. If this is a slip on, then installation should be fairly easy. Essentially cutting the old exhaust is typically the worst part, but can be accomplished via sawzall, or similar device. Then is the matter of reutilizing the hangers.
      01-07-2006, 11:48 AM   #7
nine4surfah
nine4surfah's Avatar
62
Drives: 325i Electric Red
2006 325i  [0.00]
I took a look at the stock set up just now and you are correct. Unfortunately the OEM piping does not have bolts that connect the muffler to the front pipes. The muffler and pipes appear to be welded together.
      01-07-2006, 11:58 AM   #8
RichP
RichP's Avatar
144
Drives: F80
I had an eisenmann on my E46, install is about the same, if you are doing it yourself.
Get the car in the air (ramps are best), and detach the whole exhaust system, right off the cat/header. (4 bolts). Disconnect all the other brackets, etc etc and remove the whole exhaust system. Compare the eisenmanns connection point to the OEM, and cut the OEM with a sawsalll, or a hacksaw. Measure twice, cut once!
Reinstall the OEM pipes etc. Then install the eisenmann onto it.
Note: for 100 bucks a muffler shop will cut your stock exhaust off and weld on the eisenmann, which is a lot less hassle, and you will have a better connection; the clamps tend to leak.
      01-07-2006, 11:59 AM   #9
RichP
RichP's Avatar
144
Drives: F80
Also, post up when you have it done, I would like to hear it!
      01-07-2006, 02:56 PM   #10
agarbati
agarbati's Avatar
39
Drives: E90, Saph Blk 330i
Pardon my ignorance but what are the benefits of an 'Eisenmann' over the stock?
      01-07-2006, 05:43 PM   #11
Hula-Hula
Hula-Hula's Avatar
No_Country
91
Drives: ♥
Well... For me.. Better music in and outside the car!
And very minimum performance increase I think?...
      01-08-2006, 10:56 AM   #12
nine4surfah
62
2006 325i  [0.00]
Ear Candy!!!
      01-08-2006, 11:43 AM   #13
vm
11
Drives: 2018 Alfa Romeo Giulia
What about weight? is it much lighter?
      01-08-2006, 12:23 PM   #14
Chesmu
Chesmu's Avatar
89
Drives: 2013 X6
2006 330i  [0.00]
2006 330i  [0.00]
hey vm, before you ask srius more q's about this exhaust, checkout his other thread about "problems with my eisman"
"Teach the ignorant. Ignore the stupid."
      01-08-2006, 12:51 PM   #15
BMW0
BMW0's Avatar
237
Drives: AW E90 330i
2006 330i  [0.00]
Why can't it be a bolt-on cat-back systems? Your paying good money for it. It does look nice and shiny, just needs a little bit more pipe.
330i 6MT l 255 HP @ 5900 rpm 214 lb-ft Torque @ 3500 rpm l Alpine White l Beige l Aluminum l ZSP l 494 l PDC
"Freude am Fahren" = "Joy to Drive"
      01-08-2006, 03:04 PM   #16
kal-el
son of Jor-el
kal-el's Avatar
33
Drives: I fly
2005 X3  [0.00]
2006 325i  [0.00]
2006 325i  [0.00]
2006 325  [0.00]
2006 325  [0.00]
awesome ! congrats!
      01-08-2006, 11:08 PM   #17
hotsand5
hotsand5
hotsand5's Avatar
49
Drives: 2006 BMW 330i 6spd
2006 330i  [0.00]
what did it cost you?
      01-08-2006, 11:58 PM   #18
cannonspike22
Drives: 06 325i
it should cost near a G
06 325i | Black Sapph | Leatherette | Alum | Steptronic | ZSP | Xenon Adapt. |
      01-09-2006, 02:35 PM   #19
Ryan.M
75
Drives: E46 M3..E30 325i..72' 2002
The Eisenmann systems is 19lbs
      01-09-2006, 10:57 PM   #20
UCSBMW
UCSBMW's Avatar
68
Drives: G05
niiice....sound clips?????
Ex's: E46 325i, E90 330i, E92 335i, E60 550i, E46 M3, F30 335i, m235i, G30 540i
Current: G05
      01-10-2006, 12:30 PM   #21
siriusinvestor
67
Drives: 1989 Ugo
Hey guys I finally got it installed! Will make a comparison movie in a few days. For now heres some pics! The exhaust sounds absolutely sinister! Especially when you first start the engine. Hunter's movies do the exhaust no justice! You have actually be hearing straight with your own ears to appreciate this wonderful exhaust! I can't stop smiling as I drive! IMO it was well worth every penny!
      01-10-2006, 12:50 PM   #22
Ryan.M
75
Congrats Just wait until you hear what it sounds like after the 500 mile break-in
