10-21-2014, 03:11 PM | #1 |
16
Rep 111
Dinan springs installed
I didn't find a lot of pictures showing the drop with the Dinan springs, so I thought I'd take some. This is on stock wheels. I have a new set of wheels coming later this week, I'll add some more pics with those once they're installed.
aFe Momentum Intake, Dinan springs
10-21-2014, 03:44 PM | #2 |
***** noob
1369
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
Wow awesome
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
10-21-2014, 04:17 PM | #3 |
150
Rep 659
Looks great! Can you describe the difference in ride quality on the different settings? Also, what wheels do you have in transit?
F97 X3M
F80 M3 (Sold) E90 M3 (Sold) EB M235i (Sold) E92 M3 (Sold) |
10-21-2014, 04:40 PM | #5 |
16
Rep 111
I've only been on a few drives with them, but so far the difference is relatively minor. Comfort mode is almost the same as stock, with a slight bump up in stiffness and responsiveness in the Sport modes.
The wheels coming are VMR V705 in gunmetal. The sizes are 18x8.5 ET35 on front and 18x9.5 ET45 on the rear.
10-22-2014, 07:31 AM | #8 |
16
Rep 111
I noticed that Dinan did a slightly different drop and figured since they specialize in BMW's there must be a reason. The price was a little more, though, which made me consider the H&R as well. But, with the sale (I think that is still going on), I was able to get the Dinan springs for about the same cost.
I also had a preconceived opinion (could be wrong, just what was in my head) about H&R from my old days modifying MR2's. The H&R spring usually had the lowest drop, but also had the least daily driver friendly ride. The roads around here aren't race track smooth, so figured the Dinan was a safer choice for that. The H&R also keeps more rake, so for looks I thought a more even stance would look good and also be less likely to cause even more scraping of the front bumper.
10-22-2014, 08:02 AM | #9 |
What goes here?
450
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
Looks great! Did you self-install?
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
10-22-2014, 08:07 AM | #10 |
16
Rep 111
Yeap. I generally do all of my own work. I briefly considered being lazy and having someone else install them, but the cost was high enough to shoot that idea down pretty quick. I'd much rather buy more parts with that kind of money.
10-22-2014, 09:17 AM | #11 | |
What goes here?
450
Rep 1,356
Is there any guide you used, i.e. some other BMW car where the process is generally the same?
2019 G30 M550i
10-22-2014, 11:49 AM | #12 |
16
Rep 111
I watched a couple of these videos for a quick overview. They're not exactly the same, but close. I've installed a few lowering springs on my other cars, but first time on a BMW. Most modern car suspensions I've worked on are relatively similar, at least close enough you can figure out the few differences pretty easily.
My biggest issue was I had trouble getting the shock body pulled out of the lower mount on the fronts, I just couldn't seem to find enough room to get them all the way out. I improvised and found an easier way, though, since I wasn't replacing the shocks and didn't really need to remove them. First, I removed the sway bar linkage to give more wiggle room for the shock body, then I removed the 4 bolts holding the upper mount onto the shock tower. I then used a spring compressor to compress the spring slightly to keep it from releasing on it's own. Then I removed the top nut holding the shock to the upper mount. I was now able to pull down the suspension enough to get the mount out of the way and remove it for now. Then I removed the spring compressor. Now, if you twist the spring while pulling it out, you can actually remove it right through the top of the shock tower. I was also able to switch out the bump stops through this same hole. Then, simply twist the new spring back down through the hole and reverse the steps. The new spring was enough shorter/softer that I didn't need to use the spring compressor to reassemble. I simply pressed down on it with my body weight enough to get the nut started and then used the impact gun to finish tightening it. That part would be tougher without air tools as a normal ratchet would cause the whole shock to want to spin. The impact also made the sway bar linkage much easier as it kept it from spinning as well. Just be careful not to over tighten.
10-22-2014, 12:06 PM | #13 |
What goes here?
450
Rep 1,356
Yep, I too have done it on other cars but never a BMW. I am used to the coil over damper setup. I appreciate your description as I am looking to potentially go this route myself.
I'm just evaluating options now as you say the difference is 'relatively minor'?
2019 G30 M550i
10-22-2014, 12:11 PM | #14 |
150
Rep 659
I am hoping that KW manufactures a sleeve over solution but I have a feeling that this will never see the light of day...
F97 X3M
10-22-2014, 06:28 PM | #15 |
3909
Rep 3,128
Looks great! Love the color as well! Thanks for choosing Dinan!
10-22-2014, 06:51 PM | #16 |
83
Rep 236
10-23-2014, 07:55 AM | #17 |
16
Rep 111
I took a longer drive last night with them on. I had to pick up the wife at the airport, so it was in comfort mode with mostly highway driving. I think comfort mode has improved quite a bit. It seems much more controlled and less floaty, but the softer shocks in that mode means it still soaks up bumps well. I still feel the initial bump about the same as before, but it's a much more staccato motion with less movement after the fact as the suspension settles after the bump.
I'm guessing when I get a chance to do some more spirited driving in sport, I'll see the same control and reduction of extra movements and float. It's still not going to be super stiff like you could get with a set of coilovers, but I think for a daily driver this is a great setup.
10-23-2014, 01:55 PM | #19 |
2038
Rep 25,989
Can't wait to see them installed!
VMR|Wheels | 714.442.7916 |
10-24-2014, 07:31 AM | #22 | |
16
Rep 111
No, this is a lease. So, if I don't end up buying the car after the lease, I'll want to put the stock wheels back on.
Tags |
dinan, lowering springs |
